5 Best Power Banks for TV in 2024
Blackouts and extended power outages can be life-threatening events.
However, if you’re well prepared with emergency supplies like food, water, and medication, your family’s biggest problem may be boredom.
Thankfully, there are robust and affordable power banks that can operate a television, charge laptops and smartphones, and even keep essential appliances like refrigerators running for the duration — even in extended outages.
Check out this guide to the best power banks for televisions, portable electronic devices, gaming consoles — and even major appliances.
The fun doesn’t have to stop — even when the lights go out.
EcoFlow’s Top Power Banks for TV in 2024
  1. Best for Back-Up TV Watching: EcoFlow RIVER 2
  2. Best for Average TV Watching: EcoFlow RIVER Pro
  3. Best for LED Televisions: EcoFlow DELTA 2
  4. Best for Long TV Watching: EcoFlow DELTA Max
  5. Best for Streaming: EcoFlow DELTA Pro
If you’re looking for an affordable way to keep your television powered during a short blackout outage, EcoFlow RIVER 2 is an excellent option.
Featuring lightning recharge times and a 256Wh storage capacity, EcoFlow RIVER 2 can keep most TVs operating — and charge smartphones and laptops — for several hours.
Let’s say you have a 42-inch LCD television that uses 120 watts to run. The EcoFlow RIVER 2 would have the AC output necessary to power your television for a short time while you wait for the grid to get back up and running.
Of course, the actual wattage required to run your television may vary. Make sure to check the power requirements of your specific model to confirm that the EcoFlow portable power station you choose is up for the task.
The EcoFlow RIVER 2 is an excellent source of grab-and-go power, and it can run up to 99% of consumer electronics, making it a great choice for a wide range of applications.
Extremely lightweight, it’s a highly portable solution for short power outages.
Specifications
  • Storage Capacity: 256Wh
  • AC Output: 300W total (surge 600W)
  • Solar Charge Capacity (Maximum): 11-30V, 8A, 110W Max
  • Weight: 7.7 lbs (3.5 kg)
  • Dimensions: 9.6 x 8.5 x 5.7 in (245 x 214 x 142 mm)
  • Operating Noise Level: ~60 decibels
  • Charging Options: Solar/AC/Car/USB-C Charging
  • Battery Chemistry: Lithium Iron Phosphate (LFP/LiFePO4)
  • Depth of Discharge: 100%
  • Warranty: 5 years
  • App Monitoring and Control?: Yes
Pros
  • Lightweight  and portable
  • Fast charging
  • Offers grab-and-go power
Cons
  • Low storage capacity
  • Low AC output
Looking for a power bank with a little more oomph?
EcoFlow RIVER Pro has an impressive 720Wh storage capacity that’s expandable to 1440Wh if you need more juice to keep movie night going during load shedding.
The EcoFlow RIVER Pro features impressive charging times, recharging from 0-80% within just an hour, and it can power a wide range of appliances, including many televisions.
Double-check to ensure that the AC output and storage capacity are sufficient to keep your TV running and charge your smartphones for as long as you require.
EcoFlow RIVER Pro is an outstanding choice for those with average TV-watching habits.
Specifications
  • Storage Capacity: 720Wh (Max 1440W)
  • AC Output: 800W total (surge 1600W)
  • Solar Charge Capacity (Maximum): 11-50V 13A, 220W Max
  • Weight: 17.2 lbs (7.8 kg )
  • Dimensions: 10.6 x 10.2 x 8.9 in (270 x 260 x 226 mm)
  • Warranty: 5 years
  • App Monitoring and Control? Yes
Pros
  • Supports 220W solar charging. You can recharge with EcoFlow’s 220W Bifacial Portable Solar Panel even if Eskom is offline for extended periods
  • Powers up to 9 devices at once from the built-in AC, DC, and USB-C outlets
  • Expandable to 1440Wh of storage with EcoFlow RIVER Pro Extra Battery
Cons
  • Might not have sufficient storage capacity or AC output for your application
Looking to take things to the next level? Consider the EcoFlow DELTA 2 Portable Power Station, which offers 1-3kWh of expandable storage capacity and 1.8kW AC continuous output (2.7kW Surge), rapid AC charging, and more.
An excellent choice for entry-level home backup power, EcoFlow DELTA 2 is perfect for higher-wattage LED and 4K televisions, as well as 90% of home appliances.
Specifications
  • Storage Capacity (Minimum): 1024Wh
  • Storage Capacity (Maximum): 3kWh
  • AC Output: 1.8kW continuous output (2.7kW Surge)
  • Solar Charge Capacity (Maximum): 11-60V, 15A, 500W max
  • Weight: 27 lbs (12 kg)
  • Dimensions: 15.7 x 8.3 x 11.1 in (40 x 21.1 x 28.1 cm)
  • Operating Noise Level: ~50 decibels
  • Charging Options: Solar/AC/Car Charger
  • Cycle Life: 3000 Cycles to +/-80% Capacity
  • Warranty: Five years (no cycle life restrictions)
  • Federal Solar Tax Credit Eligibility?: No
Pros
  • Expandable storage capacity up to 3kWh
  • Entry-level home backup power
  • Power over 90% of home appliances
Cons
  • Expanded storage capacity requires additional batteries
Best for Extended TV Watching: EcoFlow DELTA Max
Looking to watch a double feature during load-shedding?
The EcoFlow DELTA Max might be your ideal choice.
You can even plug in your microwave and pop some popcorn for the show!
This EcoFlow portable power station features a 2-6kWh expandable capacity and can power heavy-duty appliances with 2kW of continuous output (5kW surge).
Need to get charged up quickly?
No problem.
You can charge EcoFlow DELTA Max from 0-80% in just 65 minutes.
Add up to 2 x 400W rigid or portable solar panels, and you can recharge using the power of the sun in as little as 2.5 hours.
DELTA Max is an affordable option to keep your television operating and your personal electronic devices charged during every stage of load-shedding.
Specifications
  • Storage Capacity (Minimum): 1612 Wh
  • Storage Capacity (Maximum): 2.8 kWh
  • AC Output: 2kW total (5kW Surge)
  • Solar Charge Capacity (Maximum): 11-100V 13A, 800W Max
  • Weight: 48 lbs  (22 kg)
  • Dimensions: 19.6 × 9.5 × 12 in (49.7 × 24.2 × 30.5 cm)
  • Battery Chemistry: NCM
  • Cycle Life: 500 Cycles to 80%+ Capacity
  • Warranty: 24+12 (Registration for warranty extension)
  • Federal Solar Tax Credit Eligibility? No
Pros
  • Expandable capacity up to 6kWh
  • Powers heavy-duty appliances
  • Fast and convenient dual charging
Cons
  • Shorter cycle life than other options
Want to have the power to get you through a wide range of circumstances? The EcoFlow DELTA Pro has got you covered in a variety of circumstances. Depending on your setup, it’s suitable for everything from your television to emergency backup power to whole home backup.
The EcoFlow DELTA Pro is truly a powerful power solution and offers an expandable capacity all the way up to an astounding 25kWh. You can power just about anything with its impressive AC output, and you can even be eco-friendly thanks to its compatibility with solar charging.
You can control and monitor it using the EcoFlow app. If you want to stream off-grid, the EcoFlow DELTA Pro is your best bet.
Specifications
  • Storage Capacity (Minimum): 3.6kWh
  • Storage Capacity (Maximum): 25kWh
  • AC Output Minimum: 3.6kW continuous output (7.2kW Surge)
  • AC Output Maximum: Expandable to 7.2kW continuous output (14.4 kW surge) with 2 x EcoFlow DELTA Pro + Double Voltage Hub
  • Solar Charge Capacity (Maximum): 3.2kW with 2 x DELTA Pro (16 x 400W EcoFlow Rigid Solar Panels)
  • Weight: 99 lbs (45kg)
  • Dimensions: 25 x 11.2” x 16.4” inches (63.5 x 28.4x 42cm)
  • Charging Options: Solar/AC/Car Charger/Smart Home Panel/EV Charge Station
Pros
  • Massive expandability
  • AC output expandable to 7.2kW (14.4kW surge)
  • Suitable for whole-home backup
  • Integrates with household circuitry for seamless switchover during an outage
Cons
  • Priciest EcoFlow option
EcoFlow DELTA Pro | Expandable Home Backup Power
DELTA Pro integrates seamlessly with your existing wiring to provide uninterrupted power in a blackout. Expandable to 7.2kW of AC output and 25kWh of LFP battery storage. Recharge with solar panels, household electricity, EVSE, or an inverter generator. Keep your whole home running during extended outages.
Television Electricity Consumption by Size and Wattage*
*All wattages are averages. Your TV may vary. Estimated watch time is for fully charged power bank running the television only.
What To Consider When Buying a Power Bank for a Television
If you want to power your television during load shedding or unscheduled blackouts, EcoFlow portable power stations are a great way to accomplish this.
When selecting the ideal option for you, here are the factors to consider:
Duration of Television Usage During an Outage
How long do you want to watch TV during load shedding or unscheduled blackouts?
Are you looking just to watch for 20 minutes to wind down before you go to sleep. or are you looking for something that can accommodate long binge-watching sessions while you stream the latest season of your favourite television show?
Ask yourself what you’re expecting from your power bank to guide your decision and ensure you make the right choice.
Use-Case
In what situations are you hoping to use your EcoFlow portable power station?
Will you use the power bank primarily to watch TV off-grid? Or are you looking for a source of backup power that you can use to pass the time during load shedding or an unscheduled blackout?
Consider factors like how quickly you need your device to charge up, portability, AC output, and storage capacity.
Powering Additional Appliances
Is the TV the only appliance you seek to power?
If you’re looking for a way to keep your home operational during a power outage, consider the other devices you’ll want to run, such as lighting, your refrigerator, and more.
The more devices you power, the more AC output you’ll need. You’ll also consume more electricity, meaning you’ll need higher storage capacity to keep things running.
Consider other factors, including whether or not you have the appropriate number and type of outlets available on your power bank or portable power station.
There are many factors to consider when choosing the right power bank to run your television during load shedding or an unexpected outage.
Carefully evaluate your use case and consider the factors outlined above to make the right purchase decision.
At EcoFlow, we have a wide range of home backup power solutions to meet your needs.
To find your ideal fit, browse our selection of EcoFlow portable power stations today!
