How to Stay Powered and Safe During Unexpected Summer Storms
Being in the middle of an intense storm can be daunting. But the real danger starts after the storm has passed. Downed power lines, blackouts, and relentless summer heat can turn a short storm into a long and dangerous ordeal.
In this article, we’ll discuss four essential steps to help you stay powered and safe during the unpredictable summer weather. From backup power solutions to safety basics, we’ll keep you one step ahead.
Why Unexpected Summer Storms Can Be So Dangerous
Summer storms can strike at any moment and won’t always give you time to prepare. One second, it’s hot and humid, and the next, the power’s out, and the wind is howling and snapping tree branches.
What makes these storms especially dangerous is how fast they form and how unpredictable they can be. Lightning, flash flooding, and high winds are the most obvious threats, all of which the US has already seen this year to devastating degrees. However, even when the storm passes, the intense heat and other hazards remain a problem long after the power has gone out.
If the power grid goes down in the middle of a summer storm, your home can heat up rapidly. Your home's AC, fans, and other powered devices stop working while food and medications spoil in the refrigerator. In some situations, phones and the internet may go out, leaving you without a way to communicate or get help.
The storm itself is certainly dangerous, but the aftermath of outages and lack of communication can be just as devastating. That’s why it’s essential to prepare for those sudden summer storms the same way you would for a blizzard or hurricane. Having a plan and knowing how to stay powered during the outages can provide a necessary layer of added safety.
EcoFlow DELTA Pro 3 installed in garage of house at night
Step 1: Secure a Reliable Backup Power Source
Having a backup energy source is key when a power outage occurs. A portable power station or your solar house battery system provides a safe and quiet alternative to fuel-based generators. You’ll want to find one with enough energy to power essentials like your refrigerator, lights, fans, and phone.
The EcoFlow DELTA Pro 3 is designed for this precise scenario and offers scalable power options for when the grid goes dark. You should always keep your backup power source charged and ready for emergencies. It should also be easily accessible, so keep it in your closet or garage.
Step 2: Charge Devices and Keep Communication Lines Open
Keeping lines of communication open during and after a major storm is high on the priority list for safety. A charged phone lets you receive weather updates and alerts, contact emergency services if needed, and check on loved ones nearby. When a storm watch is issued, you will want to ensure that your phone, tablet, and portable radios are charging.
A power station like the EcoFlow DELTA 3 Plus can charge multiple devices simultaneously and keep them powered long after the grid fails. Be sure to keep charging cables and adapters staged and ready to go so you won’t have to search for them in the dark.
Get 1–5kWh expandable capacity with multiple battery options. Deliver up to 2200W output (3600W surge) with X-Boost. Recharge fast with 5 versatile methods, and enjoy peace of mind with a 5-year warranty.
Step 3: Power Your Essentials First
Once the power is out, you’ll want to prioritize the things that keep you safe and functioning. Lighting like LED lanterns or rechargeable bulbs will be the first step to preventing injury in the dark. Powering your refrigerator is the next step. Plug it into a portable power station and keep precious perishables and medications from being ruined.
After that, medical devices, fans, and anything else tied to health are paramount. Don’t waste energy on luxuries like TVs and gaming systems unless your power source can handle them after you’ve provided for the essentials. Power stations with smart controls will help you monitor your energy usage and prioritize the right devices and appliances.
Step 4: Follow Safety Basics for Summer Storm Conditions
Even without power and supplies, safety during a summer storm comes down to a few key habits. Avoid doors and windows during high winds due to potential debris or fallen tree intrusion. Do not use corded devices if lightning is present. If you suspect flooding, move important electronics away from the floor and unplug them. With that in mind, never wade through standing flood waters as they may be electrified.
Ensure any power stations are also elevated and dry, especially if they’re in the garage or at an at-grade level of the home. Be cautious when heading outside after a storm. Beware of loose debris or trees and stay clear of standing water in case of downed power lines.
Good preparation goes a long way, but calm decision-making during and after a storm is equally important.
Is It Safe To Use a Portable Power Station Indoors During a Storm?
Yes, it is. Unlike gas generators, portable power stations don’t produce fumes and are safe to use inside. Keep them away from standing water and heat sources while ensuring any connected devices are in good condition. They’re ideal for indoor use when storms make outdoor generators dangerous or impractical.
What’s the Best Type of Backup Power for Summer Storms?
The best option is a battery-based power station with enough output to cover your essentials. It’s quiet, safe for indoor use, and doesn’t require fuel. Battery-powered energy sources are beneficial for longer outages thanks to their scalable capacity and compatibility with solar recharging.
How Much Backup Power Do I Need to Get Through a Short Summer Storm?
For a short outage, 1,000 to 2,000 watt-hours is usually enough to power lights, charge phones, and keep a fridge running. If you expect multiple outages or need to run medical devices, aim for more capacity and recharging options like outlets, car chargers, or solar panels.
Reliable Power Restores Function, Protects Food, and Powers Essentials
Summer storms may not give you much warning, but you can still stay prepared with the right tools. A solid backup power plan, charged electronics, and intentional safety habits will go a long way when the weather turns ugly. If you're looking for a reliable home backup during sudden blackouts, the EcoFlow DELTA Pro 3 will provide the performance to keep you safe.
Off-Grid Power
