How to Size a Grid-Tied Solar System?
Designing a grid-tied solar system might seem complicated, but it becomes a lot easier if you break it down into simple steps. This blog will walk you through how to properly size your solar electric system so that it can meet your household’s energy needs while also ensuring you get the best value for your investment. Let’s dive into the key steps that will help you understand how to size a grid-tied solar system for your home.
Step 1. Collect Your Home’s Energy Data
To size your solar system properly, the first thing you need is data on your energy usage. You can get this information from your electricity bill. Here's what you need to know:
1.1 Monthly Electricity Usage
Look at your electricity bills for the past year. Your utility company will typically provide a breakdown of how many kilowatt-hours (kWh) you use each month. One kWh equals 1,000 watt-hours, and it’s a standard unit of measure for electricity. On average, an American home uses about 877 kWh per month. If your home uses more or less, that will help you figure out the system size.
1.2 Hourly Usage of Your Appliances
If you want to get even more specific, break down how much power each of your household appliances uses. To calculate this, multiply the wattage of each appliance by how many hours you use it in a day. For example, if your refrigerator uses 200 watts and it runs for 10 hours a day, that’s 2,000 watt-hours, or 2 kWh per day.
Once you have this information, you can calculate the total energy usage for all your appliances combined.
Step 2. Evaluate How Much Energy You Can Offset With Solar
Once you know your monthly energy usage, you’ll need to figure out how much of it you can offset with solar energy. A grid-tied system allows you to send excess electricity back to the grid, and your utility company may credit you for it.
2.1 How Much Energy Do You Want to Offset?
Most people don’t expect their solar system to provide 100% of their electricity. It's more common to aim for offsetting about 50% to 80% of your total energy consumption, depending on your goals. If you want to rely on solar for all your power needs, you’ll need a larger system.
2.2 Efficiency Improvements
Before you size your system, consider whether you can reduce your electricity usage. Buying more energy-efficient appliances, like a refrigerator or air conditioner, can reduce the size of the solar system you need. Installing energy-saving lights and better insulation will also help lower your overall energy consumption.
Step 3. Assess Solar Potential in Your Area
Solar power depends heavily on the amount of sunlight your location receives. The more sunlight, the more energy your system will produce. Some regions get more sunlight than others, which can make a big difference in the size of the system you need.
3.1 Solar Irradiance
Solar irradiance refers to the amount of solar power you can expect to receive in your area. You can check online databases to find the average amount of sunlight your location gets. For example, areas in Arizona receive more sunlight than those in Maine. This will help you determine how much energy your solar system will generate.
3.2 Consider Seasonal Variations
While your solar panels will work all year round, the amount of energy they produce can vary by season. In the winter, for example, you may get less sunlight, meaning you’ll need to depend more on the grid during those months.
Child sleeps peacefully, lamp powered by the EcoFlow RIVER 3 Plus Portable Power Station.
Step 4. Calculate the Number of Panels You Need
Once you have all your data, it’s time to calculate how many solar panels you need. Here's how you can do it:
4.1 Panel Efficiency
Each solar panel has a specific output rating, measured in watts. Most residential solar panels produce between 250 and 400 watts each. To calculate how many panels you need, you’ll first need to determine the total energy demand in watts.
4.2 Example Calculation
Let’s say your household uses 600 kWh per month, and you’re in an area that gets 5 sun hours per day on average. Here’s how you can calculate the number of panels you need:
  • 600 kWh per month = 600,000 watt-hours per month.
  • Divide by the number of days in a month (30) = 20,000 watt-hours per day.
  • Divide by the average number of sun hours per day (5 hours) = 4,000 watts per day.
  • If each panel produces 300 watts, then divide 4,000 watts by 300 watts per panel = 13.33 panels.
This means you’ll need around 14 panels to meet your energy needs.
Step 5. Determine the Inverter Size
The inverter converts the DC (direct current) electricity produced by your solar panels into AC (alternating current) electricity, which your home uses. The inverter needs to be sized properly to handle the peak load, which is the total power demand when all your appliances are running at the same time.
5.1 Sizing Your Inverter
If you’re planning to have 14 solar panels, and each panel produces 300 watts, the total peak output of your system will be 4,200 watts. Your inverter should be able to handle this peak output, plus any additional load from large appliances like air conditioners or refrigerators that require more power when they start up.
A good rule of thumb is to size the inverter to handle 25% more than the expected peak load. So, if your peak load is 4,200 watts, you should choose an inverter rated for at least 5,250 watts.
Step 6. Add Battery Backup (Optional)
If you want to store excess energy for use during the night or on cloudy days, you’ll need a battery backup system. This is not required for grid-tied systems, but it can help ensure you have power during outages.
6.1 Battery Sizing
The size of your battery bank depends on how much backup power you need. A typical home may need anywhere from 5 to 10 kilowatt-hours of storage, depending on how much energy you want to store.
6.2 Consider Future Expansion
If you plan to expand your solar system in the future, make sure your inverter and battery storage can handle additional panels and power.
Step 7. Factor in Installation and Maintenance Costs
When sizing your solar system, don’t forget to include the cost of installation and maintenance. On average, solar systems can cost anywhere from $10,000 to $30,000, depending on the size and type of system you choose. Factor in the cost of permits, installation labor, and any additional equipment like battery storage.
Solar System Size for Typical Household Energy Needs
To help you better understand how to size a grid-tied solar system, below is a table summarizing typical system sizes based on household energy needs.
Energy Usage (kWh per Month) System Size (kW) Number of Panels Needed (Assuming 300W per Panel) Inverter Size (kW) Battery Backup (kWh)
300 kWh/month 3 kW 10 panels 3.75 kW 5-6 kWh
600 kWh/month 6 kW 20 panels 7.5 kW 7-8 kWh
900 kWh/month 9 kW 30 panels 11.25 kW 10-12 kWh
1,200 kWh/month 12 kW 40 panels 15 kW 12-15 kWh
1,500 kWh/month 15 kW 50 panels 18.75 kW 15-20 kWh
How to Decide Between Grid-Tied, Off-Grid, and Hybrid Solar Systems
Feature
Grid-Tied
Off-Grid
Hybrid
Connection to the Grid
Connected to the utility grid
No connection to the grid
Connected to the grid and includes batteries
Battery Backup
No battery backup required
Requires batteries for storage
Includes batteries for backup power
Cost
Lower upfront cost
Higher upfront cost due to batteries
Higher initial cost due to batteries
Energy Independence
Depends on the grid
Fully independent from the grid
Partial independence from the grid
Ideal for Remote Areas
Not suitable for remote areas
Perfect for remote locations
Good for areas with grid reliability issues
Power During Outages
No power during outages
No power during outages unless battery reserves are available
Power available during outages if batteries are charged
Excess Energy Credit
Can sell excess energy to the grid
Cannot sell excess energy
Can sell excess energy to the grid or store it
Maintenance
Low maintenance
High maintenance for batteries
Moderate maintenance for both panels and batteries
Consider the following to decide between a grid-tied, off-grid, or hybrid solar system:
Your Location:
  • Grid-Tied. Best for urban or suburban areas where you have reliable access to the utility grid.
  • Off-Grid. Ideal if you live in a remote area without easy access to the grid.
  • Hybrid. Suitable for locations with unreliable grid power or frequent power outages.
Your Budget:
  • Grid-Tied. The most cost-effective option with the lowest upfront costs.
  • Off-Grid. Higher initial costs due to battery storage and maintenance requirements.
  • Hybrid. Mid-range cost but includes both the benefits of the grid and battery storage.
Power Reliability Needs:
  • Grid-Tied. Ideal if you don’t mind relying on the grid and want to reduce energy bills.
  • Off-Grid. Best if you want full independence from the grid, even during emergencies.
  • Hybrid. The best choice if you want the convenience of the grid with backup power for emergencies.
For those who crave reliable backup power with a twist of flexibility, the EcoFlow DELTA Pro 3 Solar Generator (PV400W) rises to the occasion.
No matter if you're setting up a grid-tied, off-grid, or hybrid solar system, the DELTA Pro 3 amplifies your energy strategy with its powerful features. Picture this: 2600W solar input, expandable battery storage, and a 99% MPPT efficiency to capture every ray of sunlight. It seamlessly integrates into both off-grid and hybrid systems, ensuring your home stays energized even when the grid falters.
If you live in a place where the grid can’t always be counted on, the EcoFlow DELTA Pro becomes your ultimate ally, keeping your devices and appliances powered up without a hitch during those unpredictable blackouts.
Sizing a grid-tied solar system goes beyond just installing panels—it's about aligning with your energy needs. Gather your energy data, assess solar potential, calculate panel numbers, and choose the right inverter and battery backup to build a system that’s as smart as it is sustainable.
