HP to Watts Conversion: Formula, Chart, and Real Examples
Horsepower shows up on motors, generators, pumps, and power tools. But most electrical planning, from sizing a circuit to choosing backup power, runs on watts. Converting between the two isn't hard once you know which horsepower definition applies. This guide covers the formula, a quick-reference chart, and where HP ratings actually turn up around the house and garage.
What Is Horsepower and Why Convert It to Watts?
Horsepower measures mechanical power output. James Watt came up with the term back in the day. He wanted to compare steam engines to the pulling power of actual draft horses.
Watts, on the other hand, are the standard unit of electrical power. You will see watts stamped on breaker panels, household appliances, generator ratings, and portable power stations.
Converting horsepower to watts matters most when you are sizing electrical gear. If you need to run a garage tool or well pump, the motor label usually lists HP. However, your home circuits, generator outlets, and battery inverters only calculate loads in watts. Converting between them prevents overloaded breakers and underpowered tools.
Mechanical vs. Electrical Horsepower
Not all horsepower ratings use the exact same number. Picking the right conversion factor depends on what type of equipment you are running:
  • Mechanical Horsepower: This is the standard US rating for gas engines and workshop motors. One mechanical HP equals about 745.7 watts.
  • Electric Horsepower: Used primarily for electric motors and wiring charts. Engineers round this rating to an even 746 watts.
  • Metric Horsepower: Found on European equipment and imported power tools. Often marked as PS or CV, it equals roughly 735.5 watts.
With the different horsepower types defined, the actual conversion comes down to picking the right formula.
The HP to Watts Formula
Converting horsepower to watts takes one simple step. Multiply your equipment's rated horsepower by the conversion factor.
Mechanical Horsepower Formula
Use this equation for standard American gas engines and tools:
  • Watts = HP × 745.7
Example: A 2 HP table saw motor requires:
2 × 745.7 = 1,491.4 watts
Electric Horsepower Formula
Electrician handbooks and motor nameplates often use this rounded standard:
  • Watts = HP × 746
Example: A 2 HP electric pool pump motor requires:
2 × 746 = 1,492 watts
Metric Horsepower Formula
Use this formula if you purchased an imported European power tool.
  • Watts = HP × 735.5
Example: A 2 HP imported motor requires:
2 × 735.5 = 1,471 watts
Running the math is simple, but the number that comes out only tells part of the story. A motor's HP rating usually describes mechanical output. The actual electrical draw from a battery or outlet runs higher once you factor in efficiency losses. That gap matters when a load's watts have to line up with what an inverter or power station can really deliver. That's where matching the right backup power to the job comes in.
The EcoFlow DELTA 3 Classic handles small HP motors easily. Its 3,600W surge beats startup spikes without tripping breakers. Whisper-quiet operation keeps work quiet. Fast 45-minute AC recharging gets your power tools running again quickly.
EcoFlow DELTA 3 Classic Portable Power Station (1024Wh)
•Ultra-Fast AC Recharging: Features four flexible charging methods, topping off from 0% to 80% in just 45 minutes via standard AC power. • 1,800W Output with 3,600W Surge: Delivers 1,800W continuous output (3,600W surge) and leverages X-Boost™ technology to power high-demand devices up to 2,600W, including refrigerators, microwaves, and air conditioners. •10ms Auto-Switch UPS: Provides rapid emergency switching to keep critical electronics, NAS systems, and servers running without interruption. •Whisper-Quiet Operation: Runs at an ultra-low noise level of ≤30dB at 600W output for quiet indoor and outdoor use.
Need power that lasts longer than a single job? The DELTA 3 Plus scales up for bigger loads like well pumps or shop equipment. Its expandable capacity and fast recharging keep you covered through extended outages.
•1kWh–5kWh Scalable Capacity: Expandable capacity using DELTA 3, DELTA 2, DELTA 2 Max, or DELTA Pro 3 Extra Batteries (via an Alternator Charger XT150 Output Cable). • 1,800W Output with 3,600W Surge: Delivers a continuous 1,800W AC output (3,600W surge) and reaches up to 2,200W with X-Boost™ technology. • 5 Fast Recharging Methods: Supports versatile charging via AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), and Multicharging. • 5-Year Warranty Protection: Backed by a comprehensive 5-year warranty for long-term reliability and peace of mind.
The DELTA 3 Classic is suitable for short-term driving tools, while DELTA 3 Plus is suitable for long-term external backup and fast charging.
The formulas are useful, but a quick-reference chart makes everyday conversions even faster.
HP to Watts Conversion Chart
Need to convert HP to watts quickly? Use this reference table to find standard motor ratings fast. It saves you from running calculations while sizing garage circuits or backup generators.
Horsepower
Mechanical HP (Watts)
Electric HP (Watts)
0.5 HP
372.9 W
373 W
1 HP
745.7 W
746 W
2 HP
1,491.4 W
1,492 W
3 HP
2,237.1 W
2,238 W
5 HP
3,728.5 W
3,730 W
10 HP
7,457 W
7,460 W
Understanding how amps, volts, and watts work together helps you sanity-check any HP calculation on the spot. It keeps you from overloading home outlets or draining batteries too fast.
The chart covers the math, but HP ratings show up on more household equipment than most people realize.
Common Appliances and Motors Rated in Horsepower
A lot of everyday equipment still lists horsepower instead of watts. Knowing where HP ratings actually show up makes it easier to size backup power correctly, whether you're dealing with pumps, tools, or garage motors.
Well Pumps
Residential well pumps keep water running during outages. Most setups use motors ranging from 0.5 to 1.5 HP. That translates to roughly 370 to 1,120 running watts.
Startup demands are a different story. Deep-well pumps can easily surge past 3,000 watts for a split second. Always confirm your well pump wattage before sizing any backup power source around it.
Power Tools and Shop Equipment
Home workshops push electrical circuits to their limits. Heavy appliances like table saws, air compressors, and shop vacs list HP instead of watts.
  • Most residential shop tools land between 1 and 3 HP.
  • A 1.5 HP table saw pulls around 1,100 to 1,500 running watts under load.
  • Air compressors need huge surge capacity to overcome tank pressure when kicking on.
Garage Door Openers
Garage door opener motors are usually rated between 0.5 and 1.25 HP. That works out to roughly 373 to 932 watts of mechanical power. Their actual electrical draw depends on the specific model. Startup demand can also be higher than normal running power.
Most of the time the conversion runs one direction, but it's just as useful in reverse.
Watts to HP: Converting the Other Direction
Sometimes you're working backward. A spec sheet lists watts, but the motor you're comparing it to only shows horsepower. Here's how to flip the formula.
Use this simple formula for standard mechanical equipment:
HP = Watts ÷ 745.7
Example: A heavy shop tool pulls 1,500 watts:
  • 1,500 watts ÷ 745.7 ≈ 2.01 HP
This calculation comes in handy when shopping for workshop tools. It lets you match an appliance's spec sheet wattage to an air compressor or table saw labeled only in horsepower.
Converting HP to watts comes down to a simple multiplication. Just identify the right horsepower type first, mechanical, electric, or metric, and the math takes care of itself. Mechanical HP is the one you'll use most often, with 745.7 watts as the standard value. Always plan for startup surge, not just running watts. Electric motors pull extra power the second they kick on. An undersized backup supply will trip instantly. Units like the EcoFlow DELTA 3 Classic and DELTA 3 Plus handle these spikes easily. With up to 3,600W of surge headroom, they start heavy shop tools, garage openers, and well pumps without stalling. Power your vital motors with confidence during any outage.
How many watts is 1 HP?
One mechanical horsepower equals about 745.7 watts, the value most US motors and engines use. If you're working with the electric horsepower standard instead, 1 HP rounds up to exactly 746 watts.
How do I convert watts back to horsepower?
Divide the device's wattage by 745.7 for mechanical tools, or divide by 746 for electric equipment. For example, a 1,500-watt load divided by 745.7 gives you roughly 2.01 mechanical horsepower output.
Is electric horsepower the same as mechanical horsepower?
Electric and mechanical horsepower are nearly identical, but their values differ slightly. Electric horsepower equals exactly 746 watts, while mechanical horsepower equals about 745.7 watts. The difference rarely affects everyday calculations.
Why does a motor's HP rating not match its electrical draw exactly?
A motor's HP rating usually reflects mechanical output, not raw electrical input. Efficiency losses during operation mean the actual draw from an outlet or battery typically runs higher than the converted wattage suggests.
How many watts does a typical well pump or garage door opener use?
A well pump generally draws 370 to 1,120 watts, depending on its HP rating. Garage door openers use less, typically 373 to 932 watts, though startup surge can push both figures higher briefly.
