How Many Amps Does a Dryer Use and What Circuit Does It Need?
A clothes dryer is one of the heaviest electrical loads in the house, and that shows up in three places. Your breaker panel, your electric bill, and your backup power plan. The answer changes a lot depending on whether yours runs on gas or electricity, and whether it's a full-size unit or an apartment-sized one. Here's what a dryer actually pulls, how to check your own, and what those numbers mean day to day. The gap between a gas model and a full-size electric one is wider than most people expect.
The Short Answer on Dryer Amperage
The number depends entirely on dryer type, and the spread between them is enormous. A full-size electric dryer and a gas dryer aren't in the same league electrically. Here's how the three common types compare.
Dryer type | Voltage | Typical draw | Wattage | Circuit needed |
Full-size electric | 240V | 21 to 30 amps | 5,000 to 6,000W | Dedicated 30-amp |
Compact or ventless electric | 120V | 10 to 15 amps | 1,200 to 1,800W | 15 or 20-amp |
Gas dryer | 120V | 3 to 6 amps | 350 to 700W | Standard 15-amp |
The reason for that gap is simple. A full-size electric dryer makes heat with a resistance element, and heating elements are power hogs. Nearly all of that current goes into producing hot air.
A gas dryer burns natural gas or propane for heat instead. Electricity only runs the drum motor, the igniter, and the control panel. That's why a gas dryer sips power while an electric one gulps it.
Compact 120V units sit in between. They dry more slowly and hold less laundry, which is the tradeoff for running on a normal household outlet. For apartments and RVs, that tradeoff is usually worth it.
Amperage also moves during a cycle. The heating element switches on and off rather than running flat out, so the draw isn't constant. For any runtime or cost math, you'll want the wattage side instead. Knowing how many watts a dryer draws is what feeds those calculations.
Those are the typical ranges. Your own dryer has an exact number printed on it.
How to Find Your Dryer's Actual Amp Draw
There are four ways to get the real figure for your machine. The first takes about ten seconds and doesn't require any tools. Start there before you buy a meter or open the panel.
Check the Nameplate
Look for a sticker or small metal plate on the back of the unit or inside the door frame. It lists the voltage and either the amperage, the wattage, or both. This is the manufacturer's own number, so it beats any range you'll find online.
Do the Math From Watts and Volts
Amps equal watts divided by volts. A 5,400W dryer on a 240V circuit draws about 22.5 amps. A 4,800W model works out to 20 amps. The same formula for calculating amps from watts and volts applies to every appliance in the house, not just the dryer.
Read the Breaker
Open your panel and find the breaker labeled for the dryer. On electric models it's usually a double-pole 30-amp. Just remember the breaker is sized above the actual draw on purpose. Treat it as a ceiling, not a measurement.
Measure It Directly
A clamp meter on the supply conductor gives you a live reading mid-cycle. That's the most accurate option, though it means working inside the panel. For 120V gas and compact dryers, a smart plug with energy monitoring does the job with no risk at all.
Knowing the number is one thing. Knowing whether a battery can cover it is where most people get misled.
What Dryer Amps Mean for Backup Power
This is where the honest answer matters, because plenty of articles blur it. Most portable power stations output 120V. A full-size electric dryer runs on 240V. Those two facts don't get around each other with a bigger wattage rating.
A full-size 240V electric dryer needs a split-phase 240V source. No 120V power station will run one, regardless of how many watts it advertises. If that's your dryer and you want it covered during an outage, you need a split-phase unit or a standby generator.
A gas dryer is a completely different story. Three to six amps at 120V is a light load, and most mid-size power stations handle it without breaking a sweat. Compact 120V electric dryers sit in the middle at 1,200 to 1,800W, which a decent unit can run for a load or two.
There's also a practical point worth making. During an actual outage, dry laundry is rarely the priority. The refrigerator, the well pump, the phones, and the CPAP come first. Mapping out which appliances a power station runs before a storm saves a lot of guessing when one actually hits.
If your laundry setup is gas or compact electric, a portable power station covers it comfortably alongside the rest of your essentials. The question is just how much stored energy you need and how many things you want running at once. EcoFlow's DELTA 3 series covers both ends of that range, and the two units below are the ones most households land on.
For a gas dryer pulling three to six amps, the EcoFlow DELTA 3 Plus has plenty of margin. Its expandable capacity also means you can add runtime later without replacing the unit. Where it starts to strain is a compact 120V electric dryer. Those can draw 1,800W on their own, leaving almost nothing for the washer or the fridge. If your laundry room runs on 120V electric rather than gas, the extra output and stored energy below make a real difference.
Backup power aside, the amperage number exists mainly to tell an electrician how to wire the circuit.
Circuit, Breaker, and Outlet Requirements
The dryer circuit has its own rules, and getting them wrong causes nuisance trips at best. At worst it creates a fire risk hidden inside your walls. None of this is complicated, but none of it is optional either.
A full-size electric dryer needs a dedicated circuit. Nothing else shares it. That circuit is almost always protected by a 30-amp double-pole breaker. It's why 30 amps gets quoted as the dryer number, even though the machine usually pulls less.
Installing a smaller breaker will trip every cycle. Installing a larger one on undersized wire is the dangerous version of the same mistake, because the breaker stops protecting the wire it's attached to. Gauge matters as much as breaker size, and the wire size a 30-amp breaker needs is set by code rather than preference.
Outlets come in two flavors. Newer installations use a four-prong NEMA 14-30 receptacle with a separate ground wire. Plenty of older homes still have the three-prong NEMA 10-30. Never swap a dryer cord just to match whatever's on the wall without confirming the receptacle is properly grounded.
A Safety Note Worth Two Minutes
The U.S. Fire Administration identifies failure to clean as the leading contributing factor in residential clothes dryer fires. Lint is highly flammable and builds up in both the trap and the vent duct.
Clear the lint screen after every load. Have the vent duct cleaned once a year. And if your dryer suddenly needs two cycles to dry one load, it's usually telling you the vent is blocked rather than the machine failing.
Amperage also translates directly into what the machine costs you every month.
What a Dryer Actually Costs to Run
The amp figure becomes a dollar figure once you add run time and your electricity rate. For most households, laundry is a bigger line item than they'd guess. Here's how it works out.
A 5,000W electric dryer running 45 minutes uses about 3.75 kWh per load. At a residential average near 18 cents per kWh, that's roughly 68 cents a load before taxes and fees. One load doesn't sound like much.
The volume is what gets you. ENERGY STAR reports the average household runs more than 280 drying cycles a year. At 68 cents each, that's close to $190 annually just to dry clothes, and more if you live somewhere with high rates.
Gas dryers cost far less electricity, though you're paying for the gas instead. On the efficient end, ENERGY STAR certified heat pump dryers cut energy use by at least 28 percent versus standard models. They don't need a vent either.
There's a timing angle too. If your utility charges by time of day, running laundry outside the late-afternoon peak lowers the cost without changing anything else. Seeing what electricity costs you each month puts the laundry line item in proper context.
A full-size electric dryer pulls 21 to 30 amps on a dedicated 240V circuit. A compact 120V unit draws 10 to 15 amps, and a gas dryer needs only 3 to 6 amps for its motor and controls. Check the nameplate before you size a breaker, buy a power station, or estimate what laundry is costing you. The EcoFlow DELTA 3 Plus and EcoFlow DELTA 3 Max cover gas and compact dryers along with your other essential loads.
How many amps does a 240V electric dryer use?
Most full-size electric dryers draw 21 to 30 amps at 240 volts, which works out to roughly 5,000 to 6,000 watts. The exact figure is printed on the nameplate at the back of the unit or inside the door frame.
Can a dryer run on a 20-amp circuit?
A full-size electric dryer cannot. It needs a dedicated 30-amp circuit and will trip a 20-amp breaker every cycle. Compact 120V and ventless models are a different matter, and many of them run fine on a standard 15 or 20-amp household circuit.
How many amps does a gas dryer pull?
Only 3 to 6 amps on a standard 120V outlet. Gas handles the heating, so electricity just powers the drum motor, igniter, and controls. That's roughly 350 to 700 watts, which is less than most microwaves.
Does a dryer need its own dedicated circuit?
An electric dryer does. Nothing else should share that circuit, and it should be protected by a properly sized breaker on correctly gauged wire. Gas dryers are lighter loads and often share a laundry-room circuit, though a dedicated one is still better practice.
Can a portable power station run a clothes dryer?
It depends on the dryer. A gas dryer or compact 120V model is well within reach of the EcoFlow DELTA 3 Max. It delivers 2400W with X-Boost support up to 3400W. A full-size 240V electric dryer needs a split-phase source and won't run on a 120V power station.
How much does it cost to run a dryer per load?
Around 68 cents for a typical electric dryer at the national average rate, based on roughly 3.75 kWh per 45-minute load. Your actual cost swings with your local rate, which ranges from about 13 cents to over 50 cents per kWh depending on the state.
