Average Electric Bill Ohio: Lower Your Energy Dependence with EcoFlow
When it comes to owning or renting a home in Ohio, there are tons of living expenses that you need to consider. Utilities, like electricity and water, are necessary costs that can quickly get out of hand if you do not have a solid understanding of what influences them.
If you’re looking for a way to lower your energy dependence, or at the very least, lower your monthly bills, you’ve come to the right spot. Below, we’ll dive into some basic information surrounding average electricity costs throughout the state of Ohio, as well as some tips you can use to reduce your monthly expenses.
What Is The Average Electricity Bill in Ohio
When speaking of averages, it is important to understand that there will always be outliers that may skew the data. In Ohio, for instance, there are many large cities that consume larger amounts of energy and, therefore, have higher electricity bills to manage each month.
For the purposes of this discussion, it is safe to assume that the average Ohio household's energy bills will range from $130 to $200 per month.
What Factors Influence The Average Electricity Bill in Ohio
With the relatively large range of electricity costs that Ohio residents can expect to pay, you may be left wondering what factors could cause such a varied average. Below, we will dive into some of the most influential factors that will have an impact on how high or low your monthly electric bill may be.
Size of Home
Larger homes require a lot more energy to power than smaller homes. Keeping your space at a comfortable temperature while also supplying power to every single appliance throughout your home will impact your electricity bill, which is why the size of your home is a key factor.
The square footage and layout will also indicate your energy consumption, so it is important to understand that while a larger home may seem like a nice concept, it comes with its own drawbacks, which are typically in the form of higher living expenses, including, but certainly not limited to, high electricity bills.
For some with larger families or other related circumstances, having a larger living space is a necessity. If you find yourself in this situation, there are still ways to help bring your monthly costs down. With EcoFlow DELTA Series Portable Power Stations, you can reduce your overall energy consumption from the grid and work to lower your electricity costs with this one simple investment.
Location
If you live in a central hub in Ohio, it’s likely that your energy costs will run at a higher rate than if you were to live on the outskirts of town.
Ohio city centers like Columbus, Cincinnati, and Cleveland attract dense populations of residents, and energy consumption, as a result, is much higher. To better regulate the large output of energy use in these populated cities, it is a safe assumption that prime locations like these will have higher electricity costs.
Rural towns, like Loveland and Marietta, will generally see lower energy costs as the grid is not quite as densely populated. Therefore, they won’t have to deal with the higher costs and stricter energy regulations that are required in larger cities.
Appliance Use
Small and large appliances alike can impact how high your energy bills will be. While smaller units like fans, computers, and other portable, plug-in devices may not be responsible for increased costs, they do play a part and can add up quickly, especially if you have a ton of them in use throughout your home.
The larger appliances, such as air conditioners and refrigerators, are more influential. Some people prefer to keep their homes at a higher, more moderate temperature, while others may wish to cool their interior space like an ice box. Your side of the spectrum will greatly influence your monthly electricity costs.
Large appliances like air conditioning and heating units are some of the most costly appliances to run, especially when used for extended periods. However, shifting to a portable power unit can help you save on these expenses over time.
The EcoFlow DELTA 3 Plus is designed to support over 99% of all household appliances and is a great backup or alternative power source to consider if you’re looking to reduce monthly costs. Conversely, the EcoFlow DELTA Pro 3 provides even greater backup, from one day to a whole week of home power during outages.
Energy Tariff and Rate
Energy usage rates will also vary throughout the state and are a key factor influencing energy costs on your monthly bills.
These rates or tariffs are typically decided by electricity companies. You will have the chance to go over these rates at the time you sign on with your electric company, so be sure to have a solid understanding of whether your rate is firm or variable and how this may impact your monthly expenses.
Time of Year
Summer and winter are typically the most expensive months when looking at averages across energy bills. This is due to the extreme hot and cold temperatures that are common during these periods.
As mentioned above, air conditioning and heating units are some of the largest, most expensive appliances in your home. They can be incredibly influential on your energy use and are typically the number one culprit in hiking up your electric bill.
How to Calculate the Average Electricity Bill in Ohio
Calculating average electricity bills is relatively easy to do once you gather a few key pieces of information.
First, you’ll need to take a look at your past few electricity bills. From these statements, you will be able to find your average usage in kWh. We recommend pulling this information from at least the past 6 months to ensure you are getting a more accurate average to use.
On your bill, you will also need to locate your energy rate. While this rate may vary slightly from household to household, you can use 15.98 cents per kWh, which is the average residential electricity rate in Ohio as of April 2025.
Now, all that’s left to do is multiply the average monthly consumption by the average rate. With this total, you will then need to divide by 100 to get the average monthly cost.
How Much Electricity Does the Average Family in Ohio Use?
While average electricity consumption can vary greatly from house to house, it is generally assumed that Ohio households use approximately 811 kilowatt-hours (kWh) of electricity per month. However, the size and location of the home, appliance use, and season, among many other factors, can dramatically influence this average.
Electricity costs, while expensive, are a necessary commitment when owning or renting a home in Ohio. Many factors can influence just how much your electricity bill costs each month, and we hope this guide has helped you gain a better understanding of what may be racking up your energy consumption and costs.
The good news is that there are so many ways for you to take control and lower your energy dependence. With EcoFlow Portable Power Stations, you will quickly reap the rewards of your investment and see just how influential portable power stations can be in helping you save on your monthly bills.
Save Bills
