EcoFlow Image
EcoFlow GLACIER Classic
A portable cooler, freezer, and battery in one.
Pack the Chill, Chase the Thrill
Shop Now
Keep Fresh Here, Frozen There
The dual-zone design (45L & 55L only) lets you store fresh and frozen food simultaneously with a maximum temperature difference of 39.6°F/ 22 °C. Advanced sensors maintain precise conditions (±1.8°F/±1 °C) to keep food perfectly fresh. *The 35L model features single-zone cooling, switchable between fridge and freezer modes.
Sized Down, Packed Up
40%* more compact design, giving you more space in your car—a true home on the move. The EcoFlow GLACIER Classic maximises storage efficiency, fitting 58 cans (35L), 72 cans (45L), and 90 cans (55L) of 330ml soda while staying sleek and space-saving. *Based on laboratory testing data, the external dimension is 40% smaller than that of standard electric coolers.
EcoFlow Image
EcoFlow Image
Built for Every Scenario
EcoFlow Image
Car Camping
RV Camping
Tent Camping
Tailgating
Grocery Runs
No melted ice, no soggy food
Insulated Cooler
GLACIER Classic
EcoFlow Image
EcoFlow ImageVehicle CompatibilityVehicle Compatibility
EcoFlow ImageAll-in-One SolutionAll-in-One Solution
EcoFlow ImageEasy TransportEasy Transport
EcoFlow Image
It's All on the App
Remotely monitor, control, and personalise your GLACIER via the EcoFlow app. From real-time battery status to water leak prevention alerts, mode changes, and scheduled shutdowns—everything is just a tap away on your phone.
EcoFlow Image
Max Mode
EcoFlow Image
Eco Mode
EcoFlow Image
Temperature Alert
Get notified if the internal temperature deviates by over 41°F/5℃ for 10+ minutes, keeping items like meat and dairy safe.
EcoFlow Image
Temperature History
Coolness That Never Stops
Multiple charging options
  • EcoFlow Image
    AC Charging (95W)
  • EcoFlow Image
    Car Power Outlet Charging (12V/24V, 100W)
  • EcoFlow Image
    Solar Charging (11-30V, compatible with panels ≤110W)*
  • EcoFlow Image
    EcoFlow Alternator Charger (110W)*
  • EcoFlow Image
    USB-C Charging (100W bidirectional)
Doubles as a power bank
Use the 100W USB-C port to power your phones and laptops, ensuring you stay connected to what matters most. *For optimal performance, use the plug-in battery to avoid unstable power due to inconsistent sunlight. The EcoFlow GLACIER Plug-in Battery is sold separately. *Compatible with EcoFlow 500W and 800W Alternator Chargers.
EcoFlow Image
EcoFlow Image
GLACIER Classic 35L
35L liters
Storage
58 cans 1-3 days
Width / Height / Depth: 706*400*405mm / 27.8*15.8*15.9inch
External Dimensions
Width / Height / Depth: 487*284*298.5mm / 19*11*11.7 inch
Internal Dimensions
20.5kg/43lb
Weight (Empty)
EcoFlow Image
GLACIER Classic 45L
45L liters
Storage
72 cans 1-4 days
Width / Height / Depth: 706*400*480mm / 27.8*15.8*18.9inch
External Dimensions
Width / Height / Depth: 487*284*373.5mm / 19*11*14.7 inch
Internal Dimensions
23.2kg/51 lb
Weight (Empty)
EcoFlow Image
GLACIER Classic 55L
55L liters
Storage
90 cans 1-5 days
Width / Height / Depth: 706*466*480mm / 27.8*18.4*18.9inch
External Dimensions
Width / Height / Depth: 487*350*373.5mm / 19*13.8*14.7 inch
Internal Dimensions
25.2kg/55.6 lb
Weight (Empty)
What's in the box?
EcoFlow Image
EcoFlow AC Power Adapter
EcoFlow Image
Basket
EcoFlow Image
EcoFlow Car Charging Cable
EcoFlow Image
Temperature Zone Divider (for 45L and 55L)
EcoFlow Image
Safety Instructions, Quick Start Guide, Warranty Card
EcoFlow Image
EcoFlow Glacier Classic Portable Refrigerator | EcoFlow UK
