Keep or Bin: How Long Does Food Keep in Freezer without Power?
The power’s gone out, and now you’re wondering…how long does food keep in a freezer without power? Here’s the thing: frozen food can stay safe longer than you think. But there is a time limit and knowing it can save you from getting sick or tossing meat that’s perfectly fine.
In this guide, we’ll break down exactly how long frozen and refrigerated food lasts during an outage, how to tell if it’s spoiled, and the steps you can take to keep food safe until the power comes back on.
How Long Does Frozen and Refrigerated Food Last without Power?
When the electricity stops, the clock starts. So, how long does food keep in a freezer without power?
Well, as long as you keep the door shut:
  • A full freezer can hold its temperature for up to 48 hours.
  • A half-full freezer gives you about 24 hours.
Now, how long can food last in refrigerator without power? It’s a much smaller safety window:
A closed fridge will stay cold enough (5°C or below) for just around 4 hours. But once the temperature rises above 8°C for more than four hours, it’s safer to bin high-risk foods like dairy, cooked meats, and leftovers.
How to Preserve Food When the Power Goes Out
Now that you know the answer to “How long does food last in the freezer without power?” there’s more you can do to stretch those limits beyond merely keeping the door shut. Let’s delve into some practical strategies:
1. Keep fridge and freezer doors closed
Every time you open the door, you let cold air escape and warm air rush in. If you can resist checking, you’ll buy precious hours of safe storage in both your fridge and freezer.
2. Pack frozen food tightly together
Move items in your freezer close together, so they act like one big ice block. The denser and fuller your freezer is, the longer it will hold its temperature.
3. Freeze bottles of water in advance
Keeping a few 2-litre bottles of frozen water in the freezer can make a big difference during an outage. You can move them into the fridge to help keep it cool if needed, or use them in a cooler for milk and essentials.
4. Use ice or dry ice for longer power cuts
Bagged ice or large blocks of ice will help keep your fridge cold once you pass the four-hour mark.
If you’re facing an extended outage, 23 kg (50 lb) of dry ice can keep a standard freezer cold for two to four days. Just remember to handle it with gloves and make sure the room is well ventilated.
5. Stay powered with a portable power station
A plug-and-play portable power station can be a lifesaver during an outage. Unlike noisy petrol generators, modern battery stations are silent, safe to use indoors and fume-free.
The EcoFlow DELTA Pro 3 Portable Power Station is a solid home backup solution. It packs a massive 4 kWh LFP battery and delivers 4,000W of continuous AC power (8,000W surge). That’s enough to keep a full-sized fridge-freezer running for well over a day, along with your TV, phones, lights, and Wi-Fi router.
It recharges to 80% in about an hour from mains, accepts up to 2,600W solar input, and you can even expand it to 12 kWh with extra batteries for longer blackouts.
The EcoFlow DELTA Pro 3 is built for serious backup power. With a 4,096 Wh LFP battery and 4,000W (8,000W surge) AC output, it can run full-size fridges, kettles, TVs, or even air-conditioning units. It fast-charges to 80% in just one hour from the wall or at up to 2,600W of solar, while the plug-and-play UPS function swaps over in 10 ms to protect appliances. Its whisper-quiet fans (30 dB on light loads) and modular expandability up to 12 kWh make it ideal for multi-day outages.
6. Have a backup cooler or mini fridge
A good, insulated cooler is perfect for keeping essentials like milk, baby formula or snacks cold without opening your fridge. Load it with ice packs or frozen water bottles to stretch its cooling time.
If you’re someone who enjoys camping, road trips, or summer beach days with ice-cold drinks, consider upgrading to one of those battery-powered best mini fridges. Not only does it come in handy on off-grid adventures, but it’s also a reliable backup during a power cut.
The EcoFlow GLACIER Classic Portable Fridge Freezer is an excellent choice. It features a 298Wh built-in battery that keeps contents at 4°C for up to 43 hours. The 45L and 55L models include dual-zone cooling, so you can chill drinks on one side and freeze meat on the other. It’s compact enough for your car yet powerful enough to act as a second fridge when you need it most.
The EcoFlow GLACIER Classic is a portable compressor fridge-freezer that cools from 20°C to –20°C without messy ice, coming in 35L, 45L, and 55L sizes. The 298Wh clip-in battery keeps 4°C for up to 43 hours and recharges via mains, 12V car socket, solar panel or power station. Two-inch insulation and a high-efficiency compressor cut energy draw, while Bluetooth app control lets you tweak settings from the deck chair. Opt for the larger dual-zone cooling versions to freeze steaks on one side while chilling salads on the other—perfect for weekends away and power-cut peace of mind.
7. Cook or eat in priority order
  • First: foods that must stay chilled.
  • Next: thawed frozen items that don’t need cooking.
  • Then: room-temperature perishables.
  • Last: tinned, dried or shelf-stable goods.
How to Tell If Your Food Has Gone Bad After an Outage
When the power’s out for hours, the biggest question is whether your food has gone bad. The tricky part? Spoiled food doesn’t always look, smell, or taste bad. That’s why knowing what to check is so important.
Read appliance temperatures first
A thermometer is your first line of defence. Popping one in both compartments will give you an accurate reading. If your fridge is still 5°C or below and your freezer is holding at –18 °C, most of your food should be safe. But if either compartment has crept higher, you’ll need to check items carefully.
Sort food in the fridge:
  • If the fridge climbed beyond 8°C for four hours or more, perishable items such as dairy, cooked meat, soft cheese and leftovers should be discarded, even if they still smell fine.
  • Likewise, any refrigerated food that feels warm to the touch, shows a slimy film, or has an off odour or colour is unsafe.
Check items in the freezer:
  • Food that’s still hard-frozen or full of ice crystals is safe to refreeze, though the quality might take a hit.
  • If items have thawed to the point of being soft, dripping, or registering above –1°C, bacteria can multiply quickly. Cook them immediately if you can use them at once, otherwise bin them.
  • Be wary of packaging clues too: swollen lids, leaking bags, or bubbling jars signal microbial spoilage and must go.
  • Freezer burn (pale, leathery patches) affects taste but not safety, so you can trim those spots and still use the rest if it stayed frozen.
Above all, never sample food to “test” it; harmful bacteria often give no warning smells or flavours.
As you go through your food, take the opportunity to empty it out and give your fridge-freezer a thorough clean and sanitise. If you’re not sure where to begin, take a look at these simple steps on how to clean fridge properly and stop bacteria from spreading. Let it air dry before putting food back.
Power cuts are stressful enough without worrying about what’s sitting in your freezer. By understanding how long food keeps in freezer without power and spotting the signs of spoilage, you can make confident decisions about what’s safe to eat.
Remember: if it smells off, looks weird, or you’re second-guessing it, don’t take the risk. It’s not worth a dodgy stomach. And if outages are common in your area, consider preparing in advance with a thermometer, backup cooling options, or a portable power station. A little planning goes a long way in keeping your food and peace of mind intact.
How long before food goes bad in the freezer without power?
During a power cut, the duration for which frozen food remains safe depends on the freezer’s fullness and the ambient temperature. A full freezer can keep food frozen for up to 48 hours, while a half-full freezer typically maintains a safe temperature for about 24 hours, provided the door remains closed.
To maximise safety, avoid opening the freezer door unnecessarily. If the power outage is expected to last longer, consider using ice packs, dry ice, or investing in backup power solutions like the battery portable power stations from EcoFlow.
Can you eat food that has thawed and refrozen?
It is generally safe to eat food that has thawed and refrozen, provided it was thawed in the refrigerator and not at room temperature. However, the quality may suffer due to changes in texture and moisture content.
If the food was left at room temperature for more than two hours, it’s advisable to discard it to prevent potential foodborne illness. Always check for signs of spoilage, such as off smells or unusual textures, before consuming.
How do you know if frozen food is still good after a power cut?
After a power cut, assess the safety of frozen food by checking its temperature and appearance. If your freezer reads -18°C or lower, most contents are still good. If the food still contains ice crystals or feels as hard as it did when originally frozen, it is likely safe to refreeze or cook.
Discard any items that have an unusual colour, texture, or odour, as these are indicators of spoilage. It’s important not to taste food to determine its safety.
