Portable Solar Panels
EcoFlow 160W Portable Solar Panel
EcoFlow 160W
Power your everyday appliances at home and off-grid with sustainable solar energy.
High-Efficiency Solar Cells
Capture more rays.
Made using highly efficient monocrystalline silicon cells. And with an exceptional energy conversion rate of 20-21%, you get more energy with every cell.
Plus, when connected to an EcoFlow solar generator, the Maximum Power Point Tracking (MPPT) algorithm auto-adjusts, guaranteeing a constant and stable power supply.
Charge a Delta mini in
Approx4hours
with 6 x 60W portable solar panels.
Approx5hours
with 2 x 110W portable solar panels.
Approx3.7hours
with 2 x 160W portable solar panels.
Approx3hours
with 1 x 400W portable solar panel.
* All data is gathered under test conditions.
Solar Connectors
The perfect power couple.
All EcoFlow portable solar panels use a universal solar connector, so they work with almost all third-party portable power stations as well as EcoFlow’s.
Lightweight & Foldable
Designed for portability.
You might also like
View more
EcoFlow RIVER 2 ProLearn More
EcoFlow DELTA 2Learn More
EcoFlow DELTA MaxLearn More
