EcoFlow x-boost
Introducing X-Boost
X-Boost is our proprietary tech that allows you to power appliances with a higher-rated power than your EcoFlow portable power station. From coffee machines and electric cookers to power tools. X-Boost gives you the flexibility to get things done. It's that simple.
Air Fryer
Coffee Maker
Electric Drills
Microwave Oven
Electric Heater
Electric Fry Pan
Hair Dryer
Electric Kettle
*The data above is for reference only.
How does X-Boost work?
Traditional battery inverters often overload when connected to appliances with higher-rated power consumption. X-Boost features an intelligent voltage control that marginally reduces voltage, allowing you to power devices with a lower-rated inverter, giving you more for less.
Complete peace of mind.
Traditional battery inverters often overload when connected to appliances that have higher-rated power consumption. X-Boost reduces the voltage of your appliances so you can power them with a lower-rated inverter, giving you more for less.
Ready to power up?
Explore the latest EcoFlow portable power stations.
EcoFlow DELTA 2Learn More
EcoFlow DELTA MaxLearn More
EcoFlow RIVER 2Learn More
Note:
1. X-Boost is enabled by default. Use the EcoFlow app to turn it on/off. 2. Do not connect the AC output to the grid when X-Boost is on, doing so will activate low-voltage protection. 3. X-Boost is not available to use when your EcoFlow portable power station is charging. 4. If you’re connecting multiple devices to your EcoFlow portable power station, the change of voltage may affect device usage performance. Please conduct a full test with your devices before usage.
