EcoFlow ImageAsk a Question
Shop Now
EcoFlow DELTA 3 Ultra Plus (3072Wh)
EcoFlow Black Friday Sale
EcoFlow Black Friday Sale | Nov 4 – Nov 18
Nov 4 – Nov 18
Get Winter-Ready Early. Save up to 56%.
A New Era of Power Performance
Industry-Leading 3600W Rated Output with 7200W Surge and Smart Output Priority
Extend runtime for your essentials and stay powered through anything.
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
™ 3.0 Tech
When in bypass mode and connected to the grid or generator to power appliances via an AC outlet, X-Fusion overrides grid/generator electricity with inverter power—achieving a maximum power output of 3600W for DELTA 3 Ultra Plus.
Unlike other portable power stations limited by 1800W grid input when charging, you get higher power for your appliances, enjoying full 3600W output at all times.
™ 3.0 Tech
EcoFlow Image
Run Outdoor Gear. Power Your RV. Charge Your Essentials — One Station Powers it All
Whether you're parked at camp or on the road, the two DC ports—Anderson [3] and car cigarette port—keep 12V gear running, from portable car fridges to car vacuums and air pumps. When you need more power, the TT-30 port enables support for your entire RV setup. And for everyday use, the high-power USB-C port fast-charges laptops and phones with ease.
EcoFlow Image
  • TT-30R AC Output Port 3600W
  • Anderson Port 378W Total (Shared power with Cigarette Lighter Output Port)
  • Cigarette Lighter Output Port 126W Total (Shared power with Anderson Port)
  • USB-C 140W
A New Level of Fast
Ultra-versatile 6 charging options, 48-minute fast charge.
Remote charging control for added peace of mind.
6 Ways to Charge Up — Ready in Just 48 Mins [4]
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
Solar + Generator Dual Charging
Solar + Alternator Dual Charging
Wall Charging
Generator Charging
Alternator Charging
Easily Scales Up—From Hours to Days
3–11kWh expandable capacity[12]
Compatible with Smart Generators for unlimited runtime
EcoFlow Image
EcoFlow ImageEcoFlow ImageEcoFlow ImageEcoFlow Image
Covers essential power needs during a 4–10 hour outage—keeping food fresh, heat running, lights on, and communication devices charged. [13]
Light (10W)
3
7
hrs
Phone (11W)
1
2
times
Wi-Fi Router (10W)
3
7
hrs
50" TV (110W)
20
40
mins
Refrigerator (200W)
12
24
hrs
Microwave (1300W)
10
20
mins
Electric Blanket (50W)
3
6
hrs
Hair Dryer (1600W)
7
15
mins
  • Half-Day Outage
  • 1-Day Outage
  • 2-Day Outage
  • 3-Day Outage
Go Hybrid—Extend Backup with a Smart Generator
Pair DELTA 3 Ultra Plus (3072Wh) with an EcoFlow Smart Generator [5] to achieve longer runtime—automatically switching between fuel and battery to keep you powered through multi-day outages or off-grid adventures.
EcoFlow Image
Learn more about EcoFlow Smart GeneratorsUnlock unmatched power and reliability with the EcoFlow Smart Generators and EcoFlow DELTA 3 Ultra Plus (3072Wh) hybrid setup. Featuring fast charging and high efficiency, they excel in various scenarios, from backup power to on-the-go charging.
Monitor your energy usage, savings, and solar generation—all with one intuitive dashboard. Easily track battery status, real-time electricity rates, and financial savings.
EcoFlow Image
Output
EcoFlow Image
Solar Generation
EcoFlow Image
Earnings [16]
Cut Costs, Not Comfort
DELTA 3 Ultra Plus intelligently optimizes energy usage to help lower your electricity bills while powering your home sustainably. Set automated tasks to charge during off-peak evening hours and discharge during the day.
EcoFlow Image
TOU Mode
Charge During Off-Peak, Use During Peak TOU Mode lets you set custom charging and discharging schedules based on your local electricity rates. Charge when energy is cheapest, and discharge during peak hours to cut costs without lifting a finger. [16]
Self-Powered
Reduce Grid Dependency, Lower Electricity Costs Self-Powered mode stores solar energy and powers your home once battery levels exceed a preset reserve. It minimizes grid use while maximizing solar efficiency—ideal for managing fluctuating energy prices and enhancing your energy independence.
To use this feature, update the software to V6.15 or above and upgrade the firmware to V7.80.99.52 or above.
A New Standard of Reliability
10 Years of Reliable Power, Engineered from Cell to Unit
Delivering safe and dependable power through everyday use and outages
EcoFlow Image
Automotive-grade Full-Tab LFP Cells: Next-Level Battery Reliability
DELTA 3 Ultra Plus is equipped with automotive-grade full-tab LFP cells. The full-tab design reduces resistance, enhances efficiency and safety, and provides higher capacity with less heat, resulting in a long battery lifespan.
25% more
efficient power flow (thanks to lower resistance: 1.5 mΩ vs. 2 mΩ) [17]
25% less
self-heating [18]
EcoFlow Image
Unrivaled Balance for Unmatched Battery Longevity
With 27% fewer cells per kWh, [19] our 16-cell design runs cooler, lasts longer, and delivers greater stability. Each cell is rigorously tested for capacity, voltage, and internal resistance—resulting in a highly uniform pack that protects against overcharging, imbalance, and premature wear.
16-cell uniform set per 1 kWh
Rigorously tested for capacity, voltage, and internal resistance
Built to Last
Certified to UL 2743 standards and verified by SGS, ensuring electrical, mechanical, thermal management, and battery safety across a wide range of use scenarios. From battery chemistry to structural design, DELTA 3 Ultra Plus is engineered for extreme durability, environmental resilience, and whisper-quiet performance—delivering power you can count on for over 10 years. [2]
EcoFlow Image
Smart, 24/7 Battery Protection
EcoFlow’s advanced BMS uses a high-performance ARM Cortex chipset and intelligent algorithms to monitor your battery in real time. By tracking SOC, SOH, temperature, and more, it ensures peak performance, extended battery life, and worry-free operation.
EcoFlow Image
EV-Grade CTC Structure
Built with a cell-to-chassis (CTC) structure, DELTA 3 Ultra Plus (3072Wh) is drop-resistant (0.2m) —protecting against overnight condensation and off-road bumps during transport. You get stable power even in the most demanding conditions. [20]
EcoFlow Image
Extreme Environment Resistance
DELTA 3 Ultra Plus (3072Wh) keeps your power flowing through freezing cold, scorching heat, humid environments (95% humidity tolerance), or coastal air (5% salt spray resistance). [20]
EcoFlow Image
Class B EMC Certification
Certified to Class B EMC standards, it won’t interfere with TVs, Wi-Fi, or other home electronics.
EcoFlow Image
25dB Whisper-Quiet Operation Under Loads [21]
Powered by X-Quiet™ 3.0, EcoFlow’s stepless fan control adjusts airflow smoothly to maintain precise thermal regulation—keeping your home or workspace peacefully quiet, even under heavy loads.
Two Easy Ways to Connect to Your Home
EcoFlow Image
EcoFlow Image
Manual Transfer Switch [22]
Switch smoothly between grid and DELTA 3 Ultra Plus (3072Wh) to meet diverse energy needs, ensuring continuous reliability without interruption.
EcoFlow Image
EcoFlow Image
Inlet Box
Simply connect the built-in AC socket with an Inlet Box to power your home appliances. [23]
Explore The NEW EcoFlow DELTA Series
EcoFlow Image
EcoFlow Image
EcoFlow DELTA 3 Classic (1024Wh)
1kWh Fast-Charging Portable Power Station
Learn More
EcoFlow Image
EcoFlow DELTA 3 Max Plus (2048Wh)
2kWh Portable Power Station with 3000W Max Output
Learn More
Disclaimer
1. 0-80% in 48 minutes was measured in optimal conditions using the EcoFlow Smart Generator 4000 (Dual Fuel) and Solar Panels, total 3960W input.
2. Based on proper product usage, DELTA 3 Ultra Plus is estimated to have a lifespan of approximately 10 years, according to internal simulation test data. This information is for reference only; actual user experience may vary.
3. DELTA 3 Ultra Plus features an Anderson port, while DELTA 3 Ultra does not.
4. 0-80% in 48 minutes was measured in optimal conditions using the EcoFlow Smart Generator 4000 (Dual Fuel) and Solar Panels, total 3960W input (DELTA 3 Ultra Plus). DELTA 3 Ultra supports four charging methods and reaches 0-80% in as fast as 89 minutes via AC input or theEcoFlow Smart Generator 4000 (Dual Fuel).
5. EcoFlow Smart Generators are sold separately.
6. EcoFlow Solar Panels are sold separately.
7. All charging speed data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
8. Feature requires preset activation via the EcoFlow App.
9. To enable this feature, connect DELTA 3 Ultra Plus to the Smart Generator using the charging cable and enable the preset in the EcoFlow App. Communication is handled via Bluetooth or Wi-Fi.
10. EcoFlow Alternator Charger Plus 1000 will be launched soon and is sold separately.
11. Compared with car cigarette port charging.
12. DELTA 3 Ultra Plus is expandable, while DELTA 3 Ultra is not expandable.
13. Backup time based on ideal conditions; actual results may vary.
14. Require connecting 1*DELTA 3 Ultra Plus + 2* DELTA 3 Max Plus Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. The EcoFlow Extra Battery Expansion Adapter will be released soon.
15. Require connecting 1*DELTA 3 Ultra Plus + 2* DELTA Pro 3 Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. The EcoFlow Extra Battery Expansion Adapter will be released soon.
16. To use this feature, update the software to V6.15 or above and upgrade the firmware to V7.80.99.52 or above.
17. Refers to the internal resistance of EF Full-Tab LFP Cells being 1.5mΩ, which is 25% lower than the 2mΩ internal resistance of the previous EF #C33 Battery Cell.
18. A 25% reduction in single-cell internal resistance. According to the heat generation formula Q = I²Rt, under the same current, a 25% reduction in resistance leads to a proportional 25% decrease in heat generation.
19. Compared with the previous usage of EF #C33 Battery Cell.
20. Unless otherwise noted, all above data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
21. Noise levels measured at 1m under 25°C ambient: ≤25dB (600W) for charging/discharging.
22. Manual Transfer Swith is sold separately.
23. This accessory should be purchased separately.
24. Unless otherwise noted, all images, videos, and screen display contents about the product itself on this page are for reference only. Actual product effects (including but not limited to appearance, color, and size) and screen display contents (including but not limited to backgrounds, UI, and illustrations) may vary.
