Hydro-Québec Power Outage Map
Whenever a power outage happens, your first few thoughts are why and for how long. Instead of waiting for updates, many utility companies now provide online outage maps that quickly answer those questions. For Hydro-Québec customers, the interactive map is a useful tool to stay on top of your electricity status.
Keep reading to learn how to check the Hydro-Québec outage map, what information it provides, and how to prevent disruptions from blackouts.
What Is the Hydro-Québec Power Outage Map?
The Hydro-Québec Power Outage Map is an interactive tool that lets anyone in the region see power outages. The map shows real-time blackouts, estimated repair times, and planned service interruptions, which is useful for knowing roughly how long you'll be without power.
But an estimated restoration time doesn't actually keep your lights on while you wait. That's where a backup power source like the EcoFlow DELTA Pro 3 Portable Power Station comes in: it picks up the slack the moment the grid goes down, so the wait itself stops being a problem.
How Do You Check the Hydro-Québec Outage Map?
There are three convenient ways to check the outage map: online, mobile app, or by phone call.
The official Hydro-Québec website and the mobile app are the most interactive way to use the map tool.
You can view a regional map and local blackouts, type in your address for specific information, or zoom into other areas. This same approach with real-time maps you can search by address is how most major Canadian utilities operate, including BC Hydro’s outage tracker on the other side of the country.
A 24-hour customer line is also available for outage updates.
Source: Hydro-Québec
What Information Does the Outage Map Show You?
Planned vs. Unplanned Outages
Planned outages are scheduled power shutoffs required for maintenance, grid upgrades, or safety work. Hydro-Québec lists these ahead of time so that customers can prepare.
Unplanned outages are unexpected power failures caused by fallen trees, equipment breakdowns, or severe weather. Once they happen, Hydro-Québec updates their interactive map to inform customers and provide estimated restoration times.
Number of Customers Affected
For any type of outage, the map includes the number of customers impacted. When viewing, you can determine if the blackout is widespread or localized to a street or neighbourhood.
Estimated Time of Restoration
One of the best metrics the map provides is the estimated time of restoration. Depending on the type and cause, the power failure duration will differ. Hydro-Québec updates this figure dynamically as crews assess the damage.
With expandable 4–48kWh capacity, the DELTA Pro 3 delivers up to 6000W to run everything from central ACs to essential appliances—anywhere. Enjoy 120V/240V output even while charging, auto-recharge via generator, and ultra-fast 50-min charging. Built for 4000+ cycles, it's portable, plug-and-play, and perfect for home, RV, or off-grid use.
How Do You Report a Power Outage to Hydro-Québec?
If you suddenly find yourself in the dark, you can first check if the outage is already reported to Hydro-Québec on the outage map online or in the mobile app. If it’s not reported then you can:
  • Call 1-800-790-2424 at any time of the day to report an outage, downed lines, or equipment failures.
  • Report it via the power outage map. To the left of the map is a link to report a blackout.
  • Use the mobile app. Navigate to the button “Report an outage”, and follow the prompts.
What Causes Most Power Outages in Quebec?
Severe weather is the most common cause of disruptions. Quebec experiences all four seasons, which brings different weather conditions year-round.
High winds can knock down vegetation, damaging lines. Ice storms and heavy snow add excessive weight to electrical lines, poles, and transformers, causing them to snap and collapse. Coastal provinces face their own version of this problem, too; Nova Scotia’s grid deals with a comparable mix of storms and ice.
How Long Does Hydro-Québec Take to Restore Power?
Restoration times can vary for Hydro-Québec customers. The length of the blackout depends on the reason. Planned outages can take a few minutes to a few hours, but customers with whole home backup power are rarely disrupted.
Unplanned blackouts can last for a few hours to days. Crews come out to assess the extent of damage and identify the cause. Major grid damage from severe weather like ice storms and heavy snow can take several days, whereas smaller localized blackouts can be as short as a couple of hours.
Restoration timelines follow a similar pattern at other Canadian utilities, including Hydro Ottawa, where crew prioritize repairs the same way.
How Can Backup Power Help During a Hydro-Québec Outage?
A reliable backup power solution is the difference between comfortably waiting out a blackout at home or having to leave for somewhere else with electricity. The EcoFlow DELTA Pro 3 is built to scale with your household's needs, so whether you're keeping a few essentials running or powering the whole home, it can grow with you.
In the winter, this means reliable access to heaters, stoves, and electronics. In the summer, air conditioning, refrigerators, and fans can stay on.
How Do I Check If There Is a Power Outage in My Area?
If you are a Hydro-Québec customer, you can check if the power is out in your area through the online outage map, mobile app map, or by calling their 24/7 hotline. On the map, type in or zoom into your street address for more detailed information.
Does Hydro-Québec Have a Power Outage App?
Yes, Hydro-Québec does offer a free mobile app that contains access to the power outage map. The app works for Androids and iPhones. Download it directly onto your phone to start tracking and reporting power failures in Quebec. Sign up for push notifications to receive alerts for your address.
How Long Do Power Outages Usually Last in Quebec?
Power outages in Quebec can last from a few minutes to several hours, depending on the type of blackout. Major weather events like ice and snow can extend blackouts to several days. Use the map to follow estimated restoration times and know the cause of the blackout.
Backup Power Keeps Quebec Homes Running Through Hydro-Québec Outages
A blackout can happen at any time. Even planned blackouts can disrupt your plans. While the Hydro-Québec outage map provides customers with real-time outage updates, estimated restoration times, and access to report a blackout, it doesn’t change the fact that the electricity is out.
The best way to prevent disruptions from outages is with backup power, whether that’s a portable power unit like the EcoFlow DELTA Pro 3, or full-home coverage with EcoFlow’s whole home backup power solutions.
Power Outages
