How to Prevent Wildfires in Canada: The 2025 Safety Guide
In Canada, wildfires are becoming more frequent, more destructive, and more costly. Each year, hundreds of thousands of hectares of forests are scorched, air quality deteriorates, homes are lost, and lives are put at risk. While some fires are caused by lightning, a significant portion - nearly half - result from human activities that are entirely preventable.
So, how do you prevent wildfires? This blog will give you the answer and walk you through the causes of wildfires in Canada and provide actionable strategies to prevent them, from safe outdoor practices to fire-resilient home design and community programs. Let’s dive in to protect our forests, homes, and lives now!
Causes of Wildfires in Canada
Before we explore how to prevent wildfires, it’s important to understand what causes them in the first place. In Canada, three primary factors consistently contribute to wildfire outbreaks.
Human Activity
Human activity accounts for nearly 50% of wildfires in Canada. Common human-caused fire incidents include:
  • Unattended campfires: Leaving fires smouldering in parks or wilderness areas.
  • Discarded cigarette butts: Especially dangerous when tossed into dry grass or forest.
  • Equipment sparks: Chainsaws, ATVs, or even lawnmowers can emit sparks during operation.
  • Controlled burns gone wrong: Prescribed fires or brush burns can easily escape control.
These fires are most common near populated or recreational areas and are entirely preventable through better awareness and behaviour.
Natural Causes
Lightning is the leading natural cause of wildfires, especially in remote or forested regions of Canada. Dry lightning—when there's little or no rain—can ignite trees and underbrush instantly. Because these fires often occur in isolated areas, it may take days for firefighting teams to respond, allowing flames to spread rapidly.
While we cannot prevent lightning, we can prepare for its consequences through forest management and rapid-response infrastructure.
Climate Change and Seasonal Extremes
Canada’s wildfire season is growing longer and more intense. Warming temperatures, lower humidity, and prolonged droughts create prime conditions for wildfires. Even light winds can accelerate fire spread, turning a small spark into a devastating inferno.
Climate change has increased both the frequency and intensity of wildfires, placing even previously unaffected regions at risk. Recognizing this trend helps communities prioritize wildfire readiness and build long-term resilience.
Outdoor Practices to Prevent Wildfires
Now that we’ve identified the main causes of wildfires, let’s explore how to prevent wildfires from spreading when we are outdoors.
Outdoor recreation is deeply woven into Canadian life, but it must be approached responsibly, especially during high-risk periods. Here’s how you can prevent wildfires while enjoying the outdoors.
Campfire Safety: How to Burn Responsibly
Campfires are a popular tradition, but they are also one of the top preventable fire risks. If you’re planning a campfire:
  • Use a designated fire pit or build one in a clear area, far from trees and brush.
  • Keep fires small and manageable.Always keep a bucket of water and a shovel within arm’s reach.
  • Never leave a fire unattended.
  • Douse fires thoroughly before leaving. Pour water, stir the ashes, and repeat until it’s cold to the touch.
It’s also essential to check for local fire bans or restrictions, especially during dry or windy weather. Ignoring these can lead to heavy fines—or worse, a devastating wildfire.
Power Use in the Wild: Safer Alternatives to Generators
Many campers and outdoor adventurers rely on portable power. Traditional fuel-powered generators are convenient but carry fire risks due to heat, sparks, and flammable fuel.
A portable power station, especially one with solar recharging capability, offers a safer, cleaner, and more eco-friendly alternative. These battery-powered units provide electricity for lights, phones, fans, or even small appliances.
For example, the EcoFlow DELTA Pro 3 Portable Power Station features a robust capacity from 4kWh to 48kWh, 4000W of continuous AC output, an IP65-rated LFP battery, great for a wide variety of off-grid needs, even in rugged conditions. Paired with up to 2600W of solar panel input, it's perfect for multi-day camping trips or remote base camps.
The EcoFlow DELTA Pro 3 is the ultimate portable power solution for wilderness adventures. With up to 48kWh expandable capacity and 4000W output (6000W with X-Boost), it powers everything from RV appliances to remote workstations. Rugged yet portable, it charges fast via solar or car, perfect for reliable, off-grid energy anywhere.
Equipment Operation and Vehicle Use
When using equipment in dry conditions, take extra care:
  • Avoid mowing lawns or using metal-bladed tools during the midday heat.
  • Ensure off-road vehicles have spark arrestors.
  • Don’t park cars on dry grass—hot exhaust pipes can ignite vegetation.
  • Regularly inspect equipment for oil or fuel leaks.
Even routine chores or outdoor maintenance can create fire hazards in the right (or wrong) conditions.
Home and Property Fire Prevention Strategies
The next question is: How to prevent forest fires from affecting your home?
Beyond outdoor precautions, there are key measures you can take around and inside your home, especially if you live in or near wildfire-prone areas. These strategies can significantly reduce the risk of your property being impacted by wildfire.
Defensible Space: Your Home’s First Line of Defense
Creating a defensible space around your home reduces fire intensity and gives firefighters a better chance to save structures. This includes:
  • Zone 1 (0–1.5 metres): Remove all flammable materials next to your home, including wood piles, propane tanks, or dried plants.
  • Zone 2 (1.5–10 metres): Trim trees, mow grass, and remove shrubs. Ensure tree branches are at least 2 metres from the ground.
  • Zone 3 (10–30 metres): Thin vegetation, especially dense trees or tall grasses.
These zones help slow or redirect fires away from buildings and create safe zones for firefighting crews.
Fire-Resistant Building Materials
If you’re building or renovating in wildfire areas, consider upgrading your materials to reduce fire risk:
  • Roofing: Replace wooden shingles with metal, asphalt, or clay tile roofing.
  • Siding: Fibre-cement, stucco, or brick siding offers better resistance than vinyl or untreated wood.
  • Windows and vents: Install tempered glass and fine mesh screens to prevent ember intrusion.
Embers can travel several kilometres from an active wildfire, and even a small opening can allow them to ignite your home from within.
Ongoing Maintenance and Fire-Smart Landscaping
Regular maintenance is essential to keep your home protected from wildfire threats. Clean gutters, roofs, and decks of dried leaves and debris, which can easily ignite from flying embers. Trim tree branches, mow grass, and remove dead plants to reduce nearby fuel sources.
Choosing fire-smart landscaping adds another layer of defense. Use fire-resistant plants and space them apart with gravel or stone to slow flame spread. Avoid flammable mulch near buildings and consider non-combustible materials instead.
Additionally, keep firefighting tools like hoses and rakes easily accessible. Rain barrels or water tanks can provide an additional water source during dry spells. Together, smart landscaping and upkeep greatly reduce the risk of home ignition in wildfire-prone areas.
Community Engagement and Fire Prevention Programs
Lastly, let’s explore some of the key community engagement and fire prevention programs available across Canada. These initiatives empower individuals, neighbourhoods, and municipalities to work together in reducing wildfire risk and building long-term resilience.
FireSmart Canada
FireSmart Canada is a leading national program that equips Canadians with the tools and knowledge to mitigate wildfire threats. Through guides like FireSmart Begins at Home, the program outlines clear, practical steps for safeguarding properties.
Its mobile app and self-assessment tools make it easier for residents to identify risks and take preventive action. Educational workshops and community recognition efforts further promote engagement at the grassroots level.
Local coordinators support neighbourhood-based planning, helping tailor wildfire preparedness to specific regional needs. With expanded support from federal and provincial funding, FireSmart is growing its presence in high-risk and Indigenous communities across the country.
Canadian Fire Safety Association
The CFSA focuses on advancing fire safety through public education, professional training, and community outreach. It hosts seminars, issues newsletters, and organizes an annual conference to connect experts with the public.
By sharing best practices in fire prevention and emergency readiness, the CFSA fosters a national network of informed safety advocates. Its work strengthens both public awareness and professional capacity in fire-prone areas.
Wawanesa’s Community Wildfire Prevention Grants
Wawanesa Mutual Insurance supports wildfire risk reduction through its Community Wildfire Prevention Grants. These grants help fund local projects such as vegetation management, wildfire buffer zones, and public education initiatives.
Applicants collaborate with local fire departments, and proposals are reviewed by wildfire prevention experts. Funded projects have included spark screen installations, mobile fuel clean-up units, and community protection plans.
As part of Wawanesa’s broader Climate Champions initiative, the grant program reinforces long-term investment in wildfire resilience across Canadian communities.
So you know how to prevent wildfires. As we’ve seen, prevention requires both personal responsibility and collective action. From managing campfires and maintaining defensible spaces to supporting community programs like FireSmart, everyone plays a part.
By adopting fire-safe habits, from creating a defensible space to using solar portable power stations instead of fuel generators, we can reduce the impact of wildfires on our homes, forests, and the future. Whether you're living in a wildfire-prone area or just enjoying the outdoors, proactive choices today can help safeguard lives, property, and ecosystems for generations to come.
What is the best way to prevent wildfires?
For how to avoid forest fires, the best way is to eliminate ignition sources. Properly extinguish campfires, use electric power stations, avoid burning during dry or windy conditions, and follow local fire bans. Small changes in daily habits can greatly reduce the risk of starting a destructive wildfire.
How can fires be prevented?
Fires can be prevented through awareness, preparation, and responsible behaviour. Clear dry vegetation, choose fire-resistant materials when building, and stay updated on regional fire danger levels. At a community level, participating in wildfire prevention programs strengthens collective protection efforts.
What is the best defense against wildfires?
A layered defense is most effective. Maintain defensible space around your home, install fire-resistant building materials, and keep emergency supplies ready. Being alert, prepared, and proactive allows you to respond quickly and helps prevent fire from spreading to or from your property.
Home Backup
