Choose
EcoFlow STREAM Series to Scale Across Ecosystems
Compatible with existing PV systems and leading third-party meters, including Shelly, HomeWizard, Everhome, Tibber, and Homey.
Smart Home Ecosystems
Energy & Metering Partners
Solar Savings, Made Simple
Lightest. Most compact. Highest energy density
among 5kWh solutions
5000W Solar Input
Up to 3000W Output
No cloud required. Keeps working locally.
2 x Pressure relief valves v.s. industry standard
Model
Enough solar and storage to power your home all day.
No waste. Just the right fit.
Powering high-demand home appliances, even a dishwasher or a washing machine.
Did You Know?
A typical European household circuit supports up to 3.6kW (230V × 16A) of power. That's why STREAM delivers 3000W of AC output — leaving around 20% safety headroom to help avoid overload risks while covering the power needs of most households.
* Up to 3000W output is available when PV generation occurs simultaneously or when paired with an Expansion Battery.
![[object Object]](https://websiteoss.ecoflow.com/figma-uploads/1782039942780-293ath-compressed-Frame%202094655528.jpg?x-oss-process=image/resize,w_1920/format,webp/quality,Q_85/sharpen,100)
Operates Reliably From -20°C to 55°C
![[object Object]](https://websiteoss.ecoflow.com/figma-uploads/1782039951337-hqe6rh-compressed-Frame%202094655529.jpg?x-oss-process=image/resize,w_1920/format,webp/quality,Q_85/sharpen,100)
Lightning Surge Protection
![[object Object]](https://websiteoss.ecoflow.com/figma-uploads/1782039963590-gs8e8t-compressed-Frame%202094655531.jpg?x-oss-process=image/resize,w_1920/format,webp/quality,Q_85/sharpen,100)
Corrosion-Resistant
![[object Object]](https://websiteoss.ecoflow.com/figma-uploads/1782039957382-8mpk55-compressed-Frame%202094655530.jpg?x-oss-process=image/resize,w_1920/format,webp/quality,Q_85/sharpen,100)
Protected Against Standing Water⁵
Connecting solar panels can generate electricity to cover much of your family’s electricity needs.
From day to night, it supports almost all of your energy needs. Scale up to 90kWh, as easily as stacking building blocks.
Installation
Installation
Takes up to 40% less floor space, with a built-in handle for easy placement, indoors or out.¹
Designed to Help You Save from Day One
Place
Installation³
Set Up the App
Operation
No. 1 Global Smart Home Energy Storage System App by Registered Users ⁶
OASIS 3.0: A Proactive & Self-Learning Intelligent System
01 ASK
No technical expertise is needed. Just express your intent.
02 PREDICT
Tailored insights to optimise your specific energy usage.
03 ACT
EcoBot handles the heavy lifting after your confirmation.
See How Much You've Saved
No internet? No problem. With Local Mode, your system keeps working and your devices stay connected.²
Safe & Reliable
Countries & Regions
Global Patents
Global Users
![[object Object]](https://websiteoss.ecoflow.com/figma-uploads/1785228232270-7a21a4-compressed-Frame%202094656085.jpg?x-oss-process=image/resize,w_768/format,webp/quality,Q_85/sharpen,100)
0 ms UPS
![[object Object]](https://websiteoss.ecoflow.com/figma-uploads/1785228250969-dx5g40-compressed-Frame%202094655728.jpg?x-oss-process=image/resize,w_768/format,webp/quality,Q_85/sharpen,100)
100%
Depth of Discharge![[object Object]](https://websiteoss.ecoflow.com/figma-uploads/1785228273868-yamls8-compressed-%E7%88%86%E7%82%B8%E5%9B%BE.jpg?x-oss-process=image/resize,w_768/format,webp/quality,Q_85/sharpen,100)
15-year
Battery Lifespan![[object Object]](https://websiteoss.ecoflow.com/figma-uploads/1785228280153-8rjsav-compressed-Frame%202094655726.jpg?x-oss-process=image/resize,w_768/format,webp/quality,Q_85/sharpen,100)
IP65
Dust & Water Resistant![[object Object]](https://websiteoss.ecoflow.com/figma-uploads/1785228306095-0najqt-compressed-Frame%202094655725.jpg?x-oss-process=image/resize,w_768/format,webp/quality,Q_85/sharpen,100)
10,000
Charging Cycles⁴![[object Object]](https://websiteoss.ecoflow.com/figma-uploads/1785228313108-uiy7wg-compressed-Frame%202094655727.jpg?x-oss-process=image/resize,w_768/format,webp/quality,Q_85/sharpen,100)
10-year
Warrantybetter heat dissipation compared with the previous generation
24 NTC temperature sensors detect temperature deviations early, while the rear cooling structure efficiently dissipates heat. A rugged, fire-resistant, CNC-machined aluminum housing encloses the entire system and provides additional protection.
2 x
instead of the industry-standard single valve
Two valves release excess pressure faster and more effectively—providing additional safety even in the rare event of an emergency.
Reverse Current and Anti-Islanding Protection
Helps protect your home and devices during grid abnormalities
Data Logging Module
Monitors real-time performance data for smarter maintenance
Metal Plate and Steel Banding
Prevents cell swelling and dampens vibration
Thermal Runaway Containment
Helps contain heat and limit cell-to-cell propagation
Aluminum Alloy Enclosure
Corrosion-resistant and built for harsh environments
Floating Terminal Design
Protects connectors during installation and use
Fully Integrated Water Resistant Design
Seamless waterproofing from top to bottom
Ceramic Cell Coating
Resists high temperatures and helps prevent internal short circuits
Aerogel and Thermal Foam Barrier
Helps slow heat propagation between cells
Two Pressure Relief Valves
Enables safe venting during pressure build-up
Insulation Fault Detection
Continuously monitors for electrical leakage and short-circuit risks
PV Overvoltage Protection
Ultra-fast hardware cut-off helps prevent overcharging
AFE Protection Chip
80+ built-in protection protocols for safer operation
24 NTC Temperature Sensors
Continuous temperature monitoring across every cell
Enlarged Heat Sink and Optimised Thermal Structure
46% better heat dissipation — runs cooler, lasts longer
Choose
