3000W Max Professional Power for Everywhere
3000W AC Output, surge 6000W, with Anderson port*. Powerful, efficient, and reliable for demanding off-grid tasks, from work to play
Flexible & Fast Charge,
Ready As Fast As in 47 Mins
5 charging methods, including industry-leading fast solar charging
Smart Energy Control
Innovative Smart Output Priority Tech—extends power for your most important devices
Engineered to 10 Years of Reliability
EV-grade full-tab LFP batteries.
Ultra-Fast Drive & Charge, 1 Hour to Charge 1kWh
10 Times Faster On-the-Go Charging, via the new EcoFlow Alternator Charger Plus 1000.
5 Years of Warranty
Effortless Expansion
2–10kWh expandable capacity.
<10ms UPS. <25dB Operation
No Disruption, Ultimate Peace of Mind
5 Years of Warranty
A New Era of Power Performance
25% More Power [1]: 3000W Output, 2kWh Capacity
Next-level energy for next-level peace of mind.
Covers essential power needs during a 4–8 hour outage—keeping food fresh, heat running, lights on, and communication devices charged. [2]
Light
(10W)
3
6
hrs
Phone
(11W)
0
1
times
WiFi router
(10W)
3
6
hrs
50" TV
(110W)
0.3
0.5
hrs
Refrigerator
(200W)
6
12
hrs
Microwave
(1300W)
5
10
mins
Electric Blanket (50W)
3
6
hrs
Hair Dryer
(1600W)
7
15
mins
- Half-Day Outage
- 1-Day Outage
- 2-Day Outage
- 3-Day Outage
A New Level of Fast
Ultra-versatile 5 charging options, 47-minute fast charge [5]
Remote charging control for added peace of mind.
5 Ways to Charge Up
Wall Charging
Generator Charging
Alternator Charging
Alternator + Solar Dual Charging
Easily Scales Up—From Hours to Days
Pick Your Priority Outputs, Extend What Matters Most
Smart Power Reserve | Set your desired battery threshold (%) to automatically shed non-essential loads during outages
With app-based presets, DELTA 3 Max Plus (2048Wh) automatically follows your priority settings during outages—shutting off lights while keeping your fridge running. Wake up to fresh food and plenty of power left—just like nothing happened.
Monitor your energy usage, savings, and solar generation—all with one intuitive dashboard. Easily track battery status, real-time electricity rates, and financial savings.
Output
Solar Generation
Earnings [14]
Cut Costs, Not Comfort
Via EcoFlow App, intelligently optimizes energy usage to help lower your electricity bills while powering your home sustainably. Set automated tasks to charge during off-peak evening hours and discharge during the day.
AI Mode
Charge During Off-Peak, Use During Peak
AI Mode lets you set custom charging and discharging schedules based on your local electricity rates. Charge when energy is cheapest, and discharge during peak hours to cut costs without lifting a finger. [6]
Self-Powered
Reduce Grid Dependency, Lower Electricity Costs
Self-Powered mode stores solar energy and powers your home once battery levels exceed a preset reserve. It minimizes grid use while maximizing solar efficiency—ideal for managing fluctuating energy prices and enhancing your energy independence.
.jpg?x-oss-process=image/resize,w_768/format,webp/quality,Q_85/sharpen,100)
Quiet, Seamless Power You Can Rely On
Automotive-grade Full-Tab LFP Cells: Next-Level Battery Reliability
DELTA 3 Max Plus (2,048Wh) is equipped with automotive-grade full-tab LFP cells. The full-tab design reduces resistance, enhances efficiency and safety, and provides higher capacity with less heat, resulting in a longer battery lifespan.
25% more
efficient power flow (thanks to lower resistance: 1.5 mΩ vs. 2 mΩ) [7]
25% less
self-heating [8]
Unrivaled Balance for Unmatched Battery Longevity
With 27% fewer cells per kWh, [9] our 16-cell design runs cooler, lasts longer, and delivers greater stability. Each cell is rigorously tested for capacity, voltage, and internal resistance—resulting in a highly uniform pack that protects against overcharging, imbalance, and premature wear.
16 cells/1kWh, uniformly matched
Rigorously tested for capacity, voltage, and internal resistance
Quiet, Uninterrupted Power. Built to Last.
From battery chemistry to structural design, DELTA 3 Max Plus (2048Wh) and DELTA 3 Ultra Plus (3972Wh) are engineered for extreme durability, environmental resilience, and whisper-quiet performance. Plus with <10ms uninterrupted power, they deliver everyday peace of mind you can rely on for over 10 years.
Comparison
1. Compared with EcoFlow DELTA 2 Max.
2. Multiple appliances' backup time based on ideal conditions; actual results may vary.
3. Require connecting 1 × DELTA 3 Max Plus (2,048Wh) + 2 × DELTA 3 Max Plus (2,048Wh) Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. The EcoFlow Extra Battery Expansion Adapter will be released soon.
4. Require connecting 1 × DELTA 3 Max Plus (2,048Wh) + 2 × DELTA Pro 3 Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. The EcoFlow Extra Battery Expansion Adapter will be released soon.
5. 0-80% in 47 minutes was measured in optimal conditions using X-Stream AC charging.
6. Certain features in the EcoFlow app will be available soon. Please refer to the EcoFlow app for details on feature availability.
7. Refers to the internal resistance of EF Full-Tab LFP Cells being 1.5mΩ, which is 25% lower than the 2mΩ internal resistance of the previous EF #C33 Battery Cell.
8. A 25% reduction in single-cell internal resistance. According to the heat generation formula Q = I²Rt, under the same current, a 25% reduction in resistance leads to a proportional 25% decrease in heat generation.
9. Noise levels measured at 0.5m under 25°C ambient: ≤25dB (600W) for charging/discharging.
10. Noise levels measured at 0.5m under 25°C ambient: ≤25dB (600W) for charging/discharging.
11. Unless otherwise noted, all above data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
