EcoFlow Portable Dual Battery System
Explore the great Aussie outdoors on or off-road with EcoFlow’s portable dual battery systems for overlanding and bush-driving adventures.
Sign up now to enjoy a 5% discount, over $1,000 in coupons, and the latest updates.
Subscribe
I agree to the Terms of Use and Privacy Policy.
Please agree to the Terms of Use and Privacy Policy.
What is a Portable Dual Battery System?
Unlike traditional 12V system for 4WD, EcoFlow’s portable dual battery system is easy DIY installation and requires no fixed installation. Enjoy record-fast charging with EcoFlow’s DELTA series portable power stations and 800W alternator charger. Generate electricity with no fumes, no noise, and no maintenance to run 99% of everyday appliances.
Portable, Take Anywhere
Get flexible, high-performance 4x4 auxiliary power that’s good for different scenarios.
  • Use in car
    EcoFlow Image
  • Use for outdoor camping
    EcoFlow Image
Pick Your On-the-Road Solution
3-in-1 Fast Charger, Maintainer, and Battery Booster | Charge 1kWh (85Ah@12V) in 1.3 Hr
EcoFlow DELTA 3 Plus + 800W Alternator
  • 1024Wh (85Ah@12V)
  • 1800W Output
  • 1.3 hrs Drive and Charge
EcoFlow DELTA 2 Max + 800W Alternator Charger
  • 2048Wh (167Ah@12V)
  • 2400W Output
  • 2.6 hrs Drive and Charge
  • 1024Wh (85Ah@12V)
  • 1800W Output
  • 2400W Output
Loved by 5,000,000+ users
EcoFlow is sold in more than 150 countries and regions, with a user base of 5,000,000+ worldwide. Our products are at the forefront of industry technology and have been certified and affirmed by tech media and awards. We are authorized as official strategic partners by major RV and outdoor industry companies.
Our Awards
Our Partners
Choice of the Pros
Work Live Play
Work Live Play
Fast Charge on the run! EcoFlow's 800W Alternator Charger & Delta 2 install in our Next Gen Ranger!
Work Live Play
Work Live Play
EcoFlow Delta 2 & Alternator charger - A Portable dual battery system
Work Live Play
Work Live Play
The Best Off Grid Power Duo EcoFlow Delta 2 & Alternator Charger Review
What Are the Main Differences Between 4WD, AWD, and 2WD?
2WD cars, trucks, etc., power the vehicle using only 2 of 4 wheels–either front (FWD) or rear (RWD). Four wheel drive vehicles–like SUVs and 4x4s–power all four wheels for improved safety and performance in rough terrain and off-road conditions. 2WD is preferable for fuel efficiency and vehicle lifespan on highways and smooth bitumen roads. Most 4WD models switch manually between 4WD and 2WD. AWD vehicles are typically low-clearance and designed to use all four wheels for better handling at high speeds and in hazardous road conditions.
