EcoFlow Power Hat
Solar charging on the
GO
IP65
waterproof-rated & durable
360
degree solar paneled brim
Dual USB-A & USB-C ports
Foldable
& easy to carry
370 g
ultra-light
360
360
Foldable
& easy to carry
IP65
370 g
ultra-light
EcoFlow Power Hat
  • Solar charging on the go
  • Captures solar energy from all angles without any blind spots.
  • Dual USB-A & USB-C ports for charging two devices simultaneously.
  • Lightweight at only 370 g, easy to pack.
  • IP65 waterproof and dust proof-rated, ideal for hiking, beach trips, fishing, and outdoor activities.
  • Available in two head sizes M:58/L:61 cm with adjustable hook and loop for the perfect fit.
Learn More >
EcoFlow 12V 100Ah Lithium Trolling Motor Battery
2X energy of Lead Acid
300A@30sInstantaneous output current
Best-in-class EV-grade LFP cells with6000+cycles
50%Less Weight2xEnergy Than Lead Acid
IP65waterproof rating
X-Guard BMS with Low-Temp Cut-Off
Highest-level UL5VA Flame-retardant Casing
  • Best lithium battery for 13.6-31.8 kg trolling motors
  • 300A@30s instantaneous output current, for smoother and more precise control of the trolling motor.
  • 1280Wh capacity, 1280W continuous output
  • EV-grade LFP cells with 6000+ cycles
Learn More >
Trusted by 3,000,000+ users
EcoFlow is sold in more than 100 countries and regions, with a user base of 3,000,000+ worldwide. Our products are at the forefront of industry technology and have been certified and affirmed by tech media and awards. We are authorized as official strategic partners by major RV and outdoor industry companies.
  • 2.5M+
    Global users
  • 100+
    Countries and regions
  • 522
    Patented technologies
Our Awards
Our Partners
EcoFlow: The Ultimate Pick for Pros
EcoFlow DELTA 2 Max | Finally, a Lightweight & Compact Lithium Power Station!
Explore Bound
EcoFlow - Is It WORTH It? Can It EXPAND Our Battery System?
Five Down Under - Travelling Australia
Power Your Ham Radio Anywhere with EcoFlow DELTA 2
Ham Radio DX
Ecoflow Delta 2 And Next Gen 220 Watt Solar Panel
robbiefishing
Quality Services You Can Expect
5-year comprehensive warranty
Worry-free after-sales customer service
UL, CE, FCC, UN38.3, RoHS certified
