2X energy of Lead Acid
300A@30s
Instantaneous output current
IP65
waterproof rating
X-Guard BMS with Low-Temp Cut-Off
Best-in-class EV-grade LFP cells with
6000+
cycles
50%
Less Weight
2×
Energy Than Lead Acid
Highest-level UL5VA Flame-retardant Casing
EcoFlow 12V 100Ah Lithium Trolling Motor Battery
  • Best lithium battery for 13.6-31.8 kg trolling motors
  • 300A@30s instantaneous output current, for smoother and more precise control of the trolling motor.
  • 1280Wh capacity, 1280W continuous output
  • EV-grade LFP cells with 6000+ cycles
2×
the power
Up to 2× more capacity
1/2
the weight yet
58% lighter for portability
12×
longer lifespan
12× longer lifespan
$0.03
/kWh
Only $0.03/kWh lifetime cost
Get the biggest catch of the day with a single 12V battery paired with a battery box so you can stay on the water from dawn to dusk.
5 hr/day
Trolling Motor 800W
5 hr/day
Fish Finder 100W
12V 100Ah | 1.28kWh
12V Trolling Motor
RV
Off-Grid Cabin
Workshop
6000+Cycles
$0.03/kWh
Durable and Protective
Advanced Battery Safety System
The structure system offers a sturdy fixation for battery cells, enhancing product reliability and safety significantly. High-performance fireproof foam is used for fixation between cells and the pack, isolating and protecting them, reducing vibration and friction, preventing short circuits and damage, and providing outstanding thermal insulation.
Always-safe and Reliable
Unmatched Protection
Our X-Guard BMS (Battery Management System) algorithm provides around-the-clock protection. Covering up to six monitoring and safeguard measures, including low temperature, over-discharge, overcharge, high temperature, short circuit, and overcurrent, it ensures a fail-safe recovery. Unlike most lead-acid batteries that lack a BMS, our battery mitigates the risk of damage in harsh environments. Whether facing extreme weather conditions or fault recovery, our dual-channel CMOS protection guarantees automatic overload protection and recovery.
Enhanced Safety and Reliability
Water-Resistant & Temperature Safe
Experience enhanced safety with vehicle-grade LFP battery cells. Meeting top UL9540 standards, this 12V battery is designed to minimize heat and resist water, even from low-pressure jets. With a 5VA-grade, self-extinguishing casing, it automatically extinguishes itself within 30 seconds in the unlikely event of a fire, preventing the risk of flames spreading.
AC Charger
2 Hours (14.6V 50A 0.5C)
Solar Panel
2 Hours (≥800W)
Generator
2 Hours (50A DC-DC Charger)
Charge 0-100 in Only 2 Hours
EcoFlow 12V 100Ah Lithium Battery
2
hours
Lead-acid 12V Battery
14
hours
2.5M+
Global users
100+
Countries and regions
522
Patented technologies
Our Awards
Our Partners
EcoFlow: The Ultimate Pick for Pros
EcoFlow DELTA 2 Max | Finally, a Lightweight & Compact Lithium Power Station!
Explore Bound
EcoFlow - Is It WORTH It? Can It EXPAND Our Battery System?
Five Down Under - Travelling Australia
Power Your Ham Radio Anywhere with EcoFlow DELTA 2
Ham Radio DX
Ecoflow Delta 2 And Next Gen 220 Watt Solar Panel
robbiefishing
Quality Services You Can Expect
5-Year Comprehensive Warranty
Worry-Free After-Sales Customer Service
UL, CE, FCC, UN38.3, RoHS Certified
title
DELTA Pro 3 can run a well pump in an emergency. I am ecstatic that my pressure washer works with the DP3. I absolutely adore the amazing design and game-changing quiet fans.
Luke L., Monticello, IL
title
Off Grid Stackable Solar Battery - So easy its *Almost* Cheating...
