Whole-Home Backup System Hub
EcoFlow Smart Home Panel 2 is the center of your whole-home backup system. Compatible with EcoFlow DELTA Pro Ultra, batteries, generators and solar panels, complete with auto-switchover for instant backup.
Smart Energy Management
Circuit control allows for more extended backup and prepares your system for outages with an hourly weather assessment.
Save Money Everyday
Customize your energy consumption based on TOU(Time Of Use) peak and off-peak rates and the amount of solar energy your home generates.
The most powerful whole-home backup solution.
- 7.2-21.6kW output
- 6kWh-90kWh capacity
- 5.6kW-16.8kW solar input
- Auto-switchover, prolonged backup, and energy bill savings with EcoFlow Smart Home Panel 2
$0
Pay 12 interest-free installation
Spread payments over 5-years*
Installation consulting service
3× EcoCredits
The $500 Installation fee reimbursed with your SHP2 purchase
30% IRA tax refund
Intelligent subpanel: outage protection and savings in one
The hub of your whole-home backup system
The Whole-Home Backup System Hub
The commanding force behind your power system.
EcoFlow Smart Home Panel 2 is the hub of the powerful EcoFlow DELTA Pro Ultra that allows you to get the full potential out of your energy system. Connect your home circuits with up to 3 plug-and-play inverters and 15 stackable 6kWh batteries, it not only takes care of your backup for even longer but allows you to control and run every single household appliance. EcoFlow Smart Home Panel 2 is not only future-proofed to work with our next-gen power solutions, but it works with EcoFlow DELTA Pro, too.*
*"To ensure compatibility with the Smart Home Panel 2, the DELTA Pro firmware must be upgraded. Please perform this update to access all available features.
Compatible with Solar and Gas Generators
Even plan B has a plan B.
EcoFlow Smart Home Panel 2 can manage your energy from various sources, including solar and gas. With the sun's rays, brighten your home with cost-effective green energy and dramatically reduce your electricity expenses. When the weather turns stormy and you're all out of sunshine, a seamless connection to any 3-12kW portable gas generator ensures your home stays energized without a hitch.
20-ms Auto-Switchover
The nights of fumbling for a torch are over.
When an outage hits, there's no need to brave the dark, cold night to switch to your backup manually. EcoFlow Smart Home Panel 2's automatic switchover feature ensures your home remains powered even when you're away. Forget spoiled food and damaged appliances. Embrace uninterrupted power so that life never stops.
Go beyond home power. Level up your experience with smart energy management.
EcoFlow App
Leave the power prep to the pro.
EcoFlow Smart Home Panel 2 ensures your home is blackout-proof with ample energy at all times. Even when an outage lingers on, it's business as usual.
Backup Extension
Categorize your home circuits into three levels of power supply priority using Circuit Control mode. Ensure protection for the most mission-critical tasks and massively extend backup time.
Emergency Weather Prep
With automatic Storm Warnings mode, batteries fully recharge 24 hours before an extreme weather event. Locking energy until an outage occurs. EcoFlow Smart Home Panel 2 monitors the weather hourly, updating the system based on the forecast, offering a more precise backup strategy.
EcoFlow App
Savings just roll on in.
With Backup Reserve mode, EcoFlow Smart Home Panel 2 secures an assigned battery percentage. Fear an impending outage? Set a higher reserve for home backup. For everyday use, set a lower portion and customize your EcoFlow Smart Home Panel 2's performance using Self-Power, Scheduled Tasks, or TOU Modes to lower your energy bills.
Longer BackupDaily Use
Based on Time Of Use peak and off-peak rates and your energy habits, EcoFlow Smart Home Panel 2 intelligently manages battery charge and discharge, significantly offsetting electricity costs.
Once battery capacity exceeds the pre-set reserve, solar begins to top up energy supplies while powering the home to lower utility bills.
EcoFlow App, PowerInsight & Web Dashboard
See your entire energy strategy at work.
View real-time energy insights for your home anywhere you go. On your phone, wall-mounted dash, or even online. Get a complete home energy consumption overview as well as solar and gas input, battery capacity, and much more. With EcoFlow Smart Home Panel 2 comes PowerInsight, a wall-mounted screen, and a web dashboard, accessible anywhere online.
EcoFlow app
Monitor, control, and customize your power usage at your fingertips.
- 10" interactive screen
- Smart home control
- Temperature auto-adjustment
- Control your EV charger
Web dashboard
A full suite of data and customizations accessible online. accessible online.
Learn MoreInnovative Design for a Hassle-Free Experience
Modular Design
Fits into your home with ease.
To work with your home layout, decor, and to save space, we've split EcoFlow Smart Home Panel 2 into two modules—a battery connection box and a distribution panel. Install each separately or together with less wiring and more flexibility to place your batteries.
Durable
10-year warranty & NEMA 3R weatherproofed enclosure
Effortless installation
By any qualified electrician
Short permit application
Easier than mounted storage or off-grid installs to keep NEM 2.0. evaluations ongoing
EcoFlow Smart Home Panel 2 vs. Traditional Subpanels
What makes EcoFlow Smart Home Panel 2 different?
EcoFlow Smart Home Panel 2 | Traditional Subpanel |
Auto-switches in an outage Automatically switches over your home power connection from the grid. | Manual breaker control Can only be managed at the panel by hand. |
Extend your backup time Circuit-level control pauses unnecessary loads to extend backup time. | No backup Only circuit distribution. |
Save everyday A smart energy usage strategy helps you to lower your electricity bills. | No savings Unable to reduce electricity bills. |
Data visualization Real-time data monitoring and holistic data analysis of your home energy. | No data insights No smart device control or data visibility. |
Future-proofed compatibility Compatible with a large range of power generation sources and will work with future EcoFlow products. | No compatibility Only grid power accessible. |
$99 FREE NOW! Also, Get a $500 Installation Fee Reimbursed with Your Purchase!
Installation Consulting Service For EcoFlow Smart Home Panel 2
With our service, you'll experience a seamless EcoFlow Smart Home Panel 2 installation. We connect you with a fully-trained local electrician and provide tracking from order to fitting. Our team is on hand to answer any technical queries, ensuring a smooth, hassle-free setup that prioritizes your convenience and satisfaction.
Step 1: Order Placement
Place an order that includes EcoFlow Smart Home Panel 2 and choose our service on the order confirmation / installation service page.
Step 2: Schedule Installation
Provide us with your general information and preferred installation time.
Step 3: Finalize Appointment
Customer service team provides the electrician's details and service appointment time.
Step 4: Share Your Feedback
Complete a short online survey once installation is complete.
Step 5: Reimburse Your Installation Fee
Contact the customer service team to reimburse the exclusive $500 installation fee after installation is completed.
What's in the box?
EcoFlow Power Input/Output Cable
Installation Guide
Marking-Off Template
Warranty Card
