- 2x runtime
for <100W appliances
- 30%
smaller than the industry average
- IP54
waterproof-rated battery pack
- 1-hr fast charging
no battery damage
- <30 dB
whisper quiet
- <20 ms UPS
* RIVER 3(10ms UPS) requires only <10 ms for uninterruptible backup
- up to 600W
- 5 outlets
Up to 600W output
Your reliable companion through outages or in the wild.
<10 ms UPS solution for uninterrupted daily living
When a power outage occurs, your AC outlet will switch to the RIVER 3 (10 ms UPS) supply in a barely noticeable 10 ms*. It keeps vital home appliances running, maintaining food storage, security, and communication. Experience a seamless, automatic switchover for continuous peace of mind * Please note: RIVER 3 offers a <20 ms UPS stwitchover time.
Fridge
Desktop
NAS
Wi-Fi Router
Gaming Console
Up to 2× light and network runtime
RIVER 3 revolutionises energy efficiency, delivering double runtime for appliances under 100W, extending use at home and in the great outdoors.¹
2× runtime for a 3W light or Wi-Fi router
- 16.1 hr
Industry Standard (245Wh)
- 30.8 hr
RIVER 3 (245Wh)
- 35.0 hr
RIVER 3 Plus (286Wh)
30% more compact for on-the-go use
- AC charging
- Solar charging
- Car charging
- Generator charging
RIVER 3 fast-charges in 1 hour with X-Stream, without causing battery damage due to vehicle-grade cells and trickle charge technology.
Industry-leading intelligent battery protection
Convenient, intelligent, and customized power
Upgraded smart control
Monitoring
Enhanced with our upgraded app and a vibrant color display, RIVER 3 offers advanced charging status and battery health insights.
Custom settings
Tailored for personal use, the upgraded app offers versatile charging settings, including speed control, timed charging, power-saving mode, and low-battery alerts.
Remote control
Connect seamlessly with Bluetooth and Wi-Fi. Remote control your unit via a Wi-Fi connection when you're not at home.
< 30 dB whisper quiet for 24/7 backup
What's in the box?
EcoFlow RIVER 3 Portable Power Station
AC Charging Cable
Car Charging Cable
Quick Start Guide and Warranty
Footnotes:
All the test results displayed on the page are based on our internal testing, subject to different conditions, including temperature variations, humidity levels, and equipment calibration standards. Please note that these results are provided for informational purposes only and should not be considered as conclusive evidence for all scenarios. Data was tested in a controlled laboratory environment and actual user experience may vary. 1. The runtime is based on laboratory tests conducted with common household appliances under normal room temperature conditions. The "double runtime" claim specifically refers to tests using a 3W light or Wi-Fi router. 2. The noise level data is based on laboratory tests conducted at a room temperature of 89.6°F (32°C). Actual use may have slight deviations due to variations in the real environment and the adding of RIVER 3 Plus Smart Extra Battery. 3. The input and output wattage of the Smart Extra Battery will decrease to 100W when environment temperatue is higher than 95°F (35°C). 4. The IP54 water-proof rating applies only to the battery pack, not the entire package. It does not prevent water immersion but can prevent fire or explosion in the event of a short circuit if the battery is splashed with water or rain, ensuring user safety and property protection Terms and conditions apply. During the promotional period from Dec 6-27, 2024 (PT), you will receive the following benefits with an eligible order: Benefit 1: 30% off EcoFlow RIVER 3 Plus Benefit 2: A free EcoFlow 45W Portable Solar panel (worth $99) with EcoFlow RIVER 3 Plus, RIVER 3 Max and RIVER 3 Max Plus standalone unit (This offer does not apply to the RIVER 3 series bundle). EcoFlow reserves the right to cancel the benefits and any associated orders at any time in cases of dishonesty, fraud, or violation of these terms. When applying for a return and refund, customers must return the accompanying gift (EcoFlow 45W Portable Solar panel) as well or the corresponding amount will be deducted from the refund at the retail price.
