EcoFlow ImageAsk a Question
Shop Now
EcoFlow DELTA 3 Max(2048Wh)
EcoFlow Image
EcoFlow Image
2400W-Power Past the 1800W AC Standard
Easily power more appliances at once
EcoFlow Image
Ready in Just 51min[1]
4 charging methods
EcoFlow Image
10 Years of Reliable Power [2]
EV-grade full-tab LFP batteries
EcoFlow Image
Lightweight,Compact, Portable
20.3 kg, 13% lighter[10] for effortless portability
EcoFlow Image
Uninterrupted Power
<10ms switchover — fastest-in-class UPS
EcoFlow Image
Smarter, Safer, 24/7 Protection BMS
ARM Cortex chipset Cloud intelligence algorithm
EcoFlow Image
EcoFlow DELTA 3 Max (2048Wh)
• 2kWh capacity • 2400W rated output • 4800W surge output
R19,999.00
R26,999.00
Shop Now
All Your Essentials. All at Once.
EcoFlow DELTA 3 Max (2048Wh) delivers 2400W AC rated output. With X-Boost™ 3.0 technology, it supports devices up to 3200W—effortlessly taking on your heavy-duty appliances. That's enough to run your microwave, kettle, fridge, and blender all at once without a flicker.
EcoFlow Image
With a powerful 2400W AC output, DELTA 3 Max outperforms competing products, supporting simultaneous operation of multiple high-wattage appliances.
2400W Output, 4800W Surge — Powerful. Stable. Built to Handle It All.
The inverter samples AC voltage and current every 33μs with high precision using a DSP chip, ensuring pure sine wave output with beyond grid-level stability—ideal for powering sensitive electronics reliably.
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
Kitchen
Living Room
Office
Garage
Laundry Room
RV Camping
EcoFlow Image
A New Level of Fast
Ultra-versatile 4 charging options, 51-minute fast charge [1]
Remote charging control for added peace of mind.
4 Ways to Charge Up — Ready in Just 51 Mins [1]
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
Wall Charging
Generator Charging
Alternator Charging
Automotive-grade full-tab LFP cells
EcoFlow Image
Automotive-grade Full-Tab LFP Cells: Next-Level Battery Reliability
DELTA 3 Max (2048Wh) is equipped with automotive-grade full-tab LFP cells. The full-tab design reduces resistance, enhances efficiency and safety, and provides higher capacity with less heat, resulting in a long battery lifespan.
25% more
efficient power flow (thanks to lower resistance: 1.5 mΩ vs. 2 mΩ) [11]
25% less
self-heating [12]
Built to Last
From battery chemistry to structural design, DELTA 3 Max (2048Wh) is engineered for extreme durability, environmental resilience, and whisper-quiet performance.
EcoFlow Image
Smart, 24/7 Battery Protection
EcoFlow’s advanced BMS uses a high-performance ARM Cortex chipset and intelligent algorithms to monitor your battery in real time. By tracking SOC, SOH, temperature, and more, it ensures peak performance, extended battery life, and worry-free operation.
EcoFlow Image
EV-Grade CTC Structure
Built with a cell-to-chassis (CTC) structure, DELTA 3 Max (2048Wh) is drop-resistant and shockproof-protecting against overnight condensation and off-road bumps during transport. You get stable power even in the most demanding conditions.
EcoFlow Image
Extreme Environment Resistance
DELTA 3 Max (2048Wh) keeps your power flowing through freezing cold, scorching heat, humid environments (95% humidity tolerance), or coastal air-for reliable energy anytime, anywhere[8].
EcoFlow Image
Class B EMC Certification
Certified to Class B EMC standards, it won’t interfere with TVs, Wi-Fi, or other home electronics.
EcoFlow Image
25dB Whisper-Quiet Operation Under Loads [9]
Powered by X-Quiet™ 3.0, EcoFlow’s stepless fan control adjusts airflow smoothly to maintain precise thermal regulation—keeping your home or workspace peacefully quiet, even under heavy loads.
Power That Lasts All Day
With 2048Wh Capacity, EcoFlow DELTA 3 Max meets all your power needs in any scenario.
  • Home Backup
  • RVing & Outdoors
  • DIY Project
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
Monitor your energy usage, savings, and solar generation—all with one intuitive dashboard. Easily track battery status, real-time electricity rates, and financial savings.
EcoFlow Image
Output
EcoFlow Image
Solar Generation
EcoFlow Image
Earnings [20]
Cut Costs, Not Comfort
DELTA 3 Max (2048Wh) intelligently optimizes energy usage to help lower your electricity bills while powering your home sustainably. Set automated tasks to charge during off-peak evening hours and discharge during the day.
EcoFlow Image
TOU Mode
Charge During Off-Peak, Use During Peak TOU Mode lets you set custom charging and discharging schedules based on your local electricity rates. Charge when energy is cheapest, and discharge during peak hours to cut costs without lifting a finger. [20]
Self-Powered
Reduce Grid Dependency, Lower Electricity Costs Self-Powered mode stores solar energy and powers your home once battery levels exceed a preset reserve. It minimizes grid use while maximizing solar efficiency—ideal for managing fluctuating energy prices and enhancing your energy independence.
To use this feature, update the software to V6.14.5 or above and upgrade the firmware to V7.80.99.52 or above.
Comparison
Explore The NEW EcoFlow DELTA Series
EcoFlow Image
EcoFlow Image
EcoFlow DELTA 3 Plus(1024Wh)
1kWh Fast-Charging Portable Power Station
Learn More
EcoFlow Image
EcoFlow DELTA 3 Ultra Plus (3072Wh)
3kWh Ultra Long-lasting Portable Power Station
Shop Now
Disclaimer
1. 0-80% in 51 minutes was measured in optimal conditions using AC charging with X-Stream Fast Charging mode on.
2. Based on proper product usage, DELTA 3 Max (2048Wh) is estimated to have a lifespan of approximately 10 years, according to internal simulation test data. This information is for reference only; actual user experience may vary.
3. All charging speed data comes from EcoFlow Labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
4. Feature requires preset activation via the EcoFlow App.
5. EcoFlow Smart Generators are sold separately.
6. EcoFlow Solar Panels are sold separately.
7. EcoFlow 800W Alternator Charger is sold separately. The Alternator Charger XT60 Output Cable is required to connect the EcoFlow 800W Alternator Charger to the EcoFlow DELTA 3 Max. The cable is sold separately, but it is included when you purchase the DELTA 3 Max + 800W Alternator Charger bundle. When connected to a Alternator Charger, the DELTA 3 Max does not provide reverse charging to the vehicle’s battery.
8. Unless otherwise noted, all images, videos, and screen display contents about the product itself on this page are for reference only. Actual product effects (including but not limited to appearance, color, and size) and screen display contents (including but not limited to backgrounds, UI, and illustrations) may vary.
9. Noise levels measured at 1m under 25°C ambient: ≤25dB (600W) for charging/discharging.
10. Compared with EcoFlow DELTA 2 Max
11. Refers to the internal resistance of EF Full-Tab LFP Cells being 1.5mΩ, which is 25% lower than the 2mΩ internal resistance of the previous EF #C33 Battery Cell.
12. A 25% reduction in single-cell internal resistance. According to the heat generation formula Q = I²Rt, under the same current, a 25% reduction in resistance leads to a proportional 25% decrease in heat generation.
