What Are the Stages of Load-Shedding?
The South African national power utility, Eskom, states that load-shedding is both a legal requirement and a controlled way to ensure the national power system remains stable in the event of major incidents. Load-shedding is a deliberate shutdown of all or portions of the electricity grid and is often scheduled in advance.
There are a total of eight load-shedding stages. The higher the load-shedding stage, the more frequently you will experience power outages. Eskom implements load-shedding for two to four hours, depending on the schedule for your area.
(Source: Eskom)
What Are the Different Stages of Load-Shedding?
Stage 1
In stage 1, Eskom must reduce electricity consumption (shed) by 1,000MW (megawatts) to balance the national power grid. When implemented, stage 1 consists of three two-hour power outages implemented over four days or three four-hour power outages implemented over eight days.
Stage 2
Eskom must schedule stage 2 load-shedding to save 2,000MW from the national power grid. Planned power outages will occur at least six times over eight days for four hours or six times over four days for two hours at a time.
Stage 3
During stage 3 load-shedding, Eskom needs to shed a total of 3,000 MW of electricity from the national power grid. You can expect nine load-shedding slots over eight days for a minimum of four hours at a time or, in some cases, nine-time slots consisting of two hours of no power over four days.
Stage 4
Stage 4 consists of shedding up to 4,000MW from the national power grid. You can expect no power for twelve four-hour outages over eight days or twelve two-hour outages to be effective over four days.
During these outages, having a reliable backup power source like the EcoFlow DELTA 2 Max can be invaluable. The EcoFlow DELTA 2 Max is an ideal solution, offering ultra-fast charging (80% in 43 minutes) and expandable capacity up to 6144Wh, perfect for extended power needs.
EcoFlow DELTA 2 Max | High-Performance Portable Power Station
EcoFlow DELTA 2 Max is a high-performance portable power source that uses lithium iron phosphate battery (LFP) technology with a base capacity of 2048Wh, expandable to 6144Wh, and a cycle life of 3000 times to ensure long-term durability. It supports 2400W output, X-Boost for 3400W devices, and ultra-fast charging (80% in 43 mins via AC/solar). With 6 outlets, EcoFlow APP control, and BMS safety, it’s ideal for outdoor adventures, home backup, and high-power needs. Features quiet operation and a 5-year warranty.
Stage 5
Stage 5 load-shedding requires Eskom to save up to 5,000MW of power from the national power grid. Stage 5 load-shedding indicates that South Africans will endure roughly eight hours of load-shedding each day the grid is within stage 5. In stage 5 load-shedding, you can expect to be without electricity for at least four days for twelve periods of two hours.
Stage 6
Stage 6 load-shedding is implemented to prevent the national power grid’s collapse and requires Eskom to shed 6,000 MW. You can expect the state-owned utility to initiate extra, unplanned power cuts wherever necessary and outside its load-shedding schedules.
You could be affected 18 times for four days for up to four-and-a-half hours at a time or 18 times over eight days for about two hours at a time.
Stage 7
Stage 7 load-shedding means that Eskom needs to shed approximately 7,000 MW of electricity, and power cuts are scheduled over four days for four hours at a time.
Stage 8
Stage 8 load-shedding doubles the frequency of stage 4, resulting in Eskom will need to shed about 8,000 MW. You can expect to be without power up to six times a day, with the power off for 12 hours daily, depending on the schedule.
For those seeking a reliable backup power solution, the EcoFlow DELTA 2 Max Portable Power Station is an excellent choice. This high-performance portable power station features a 2048Wh base capacity, expandable up to 6144Wh, and utilizes LFP battery technology for 3000+ charge cycles, ensuring long-term durability. With 2400W output and X-Boost technology, it can power devices up to 3400W, making it ideal for home backup, outdoor adventures, and high-power needs. It supports ultra-fast charging, reaching 80% in just 43 minutes via AC or solar input (up to 1000W). Additionally, it offers 6 outlets, EcoFlow APP control, and BMS safety for reliable and secure operation.
Whether you’re facing Stage 1 or Stage 8 load-shedding, the EcoFlow DELTA 2 Max ensures you stay powered through any outage. is a dependable solution to keep your essential devices running during load-shedding.
How Many Stages of Load-Shedding Are There?
There are a total of eight load-shedding stages. The principle behind load-shedding is the higher the load-shedding stage, the more frequently you will experience power outages.
For individuals and businesses seeking timely and accurate information on the load shedding schedule, Loadshedding.com stands as a premier resource. This platform offers up-to-the-minute news and schedules tailored to specific regions in South Africa. For informed planning and uninterrupted operations, choose Loadshedding.com as your trusted source.
Currently, load-shedding is a necessary process that Eskom must implement to stop the national power grid from collapsing. You should always be prepared for changes in the schedule by following Eskom and your local municipality on social media or investing in a portable power station in case of unexpected outages.
