5 Best Solar Generators in 2024 Reviewed
The sun is among the best sources of energy at our disposal. It’s renewable, clean, and thanks to solar panels, it’s simple to capture and reserve. Solar power is especially beneficial if you’re off the grid, camping, or looking for the safest, most environmentally-friendly generator.
A solar generator offers low running costs and no fumes. With one, you don’t have to worry about emitting hazardous toxins into the environment like you would with a petrol-powered generator. The benefits are clear, but choosing the best solar generator can be challenging unless you’re an expert.
That’s where we come in.
We’ll go over the best EcoFlow solar generators in 2024 and what benchmarks to consider to narrow down your buying decision. Let’s get down to it!
5 Best Solar Generators Reviewed
At EcoFlow, we develop portable power stations that keep on giving. Unlike petrol-powered inverter generators, solar-powered generators use solar panels to get their fuel from the sun.
They offer an excellent solution to obtaining short-term energy when the power goes out or charging up appliances while camping.
Here’s how EcoFlow solar generators work:
  1. They convert sunlight into direct current (DC) electricity.
  2. They store this solar energy until needed.
  3. They power your devices by turning DC into AC power.
It’s that easy! However, don’t assume that all solar generators are the same. They range in running watts, peak power, recharge times, etc.
Below, you’ll find the top portable power stations in 2024. We’ll leave no stone unturned, covering each model’s features, specifications, pros, and cons.
EcoFlow River 2 Series
The EcoFlow River 2 Series is the power solution designed for outdoor adventure. Whether camping with family, setting up a motorhome, or attending a festival with friends, these solar generators have your back.
Here are the industry-leading solar generators that make part of the EcoFlow River 2 Collection.
1. River 2
The EcoFlow River 2 is a must-have for any adventure, from road trips to camping. It’s perfect for individuals looking for a robust but lightweight, portable generator that’s ready to go at a moment’s notice.
This portable power station can run a television (110W) for 2-4 hours and a refrigerator (150W) for 1.5-3 hours. It comes with a 110W solar panel to keep your devices going strong without interruption.
It’s easy and fast to recharge once you’ve used up the ample 288 Wh capacity. Thanks to the patented X-Stream Recharging technology, a full charge only takes 1.6 hours. This generator holds its power for up to a year when fully charged.
The River 2 comes with an integrated carry handle, an easy-to-read screen, and three 600W AC outlets. It also has USB-C and USB-A slots. Users can easily double the battery capacity by adding on an additional unit which will take it from 288 Wh to 576 Wh.
Specifications
  • Capacity: 256Wh
  • Weight: 3.5Kg
  • Dimensions: 245 x 214 x 142 mm
  • Battery Type: Lithium-ion
  • Battery Life Cycle: 3000 cycles to 80+% capacity
  • Solar Panel Charging Time: 1.6 to 3 hours
Pros
  • Portable & lightweight
  • Modular design for custom powering options
  • Powers up to ten devices
  • Compatible with 80% of home appliances
  • X-Stream fast charging
Cons
  • Not ideal for long off-grid adventures
Verdict: The EcoFlow River 2 is a trustworthy solar generator, strong enough to charge a smartphone 21 times or make 12 cups of coffee with a coffee machine! It’s also a reliable backup when you need power in a blackout. It’s compatible with most home appliances and recharges quickly. For powerful charging capacity in a portable package, you can’t go wrong with the River 2.
Experience the EcoFlow River 2 today!
2. River 2 Max
Portable and powerful, the EcoFlow River 2 Max has a capacity of 576 Wh. It’s a step up from the River 2 original, delivering enough juice to charge your smartphone up to 42 times!
The Max solar generator offers double the power as the River 2 original and comes with an extra battery. This battery is removable, so you won’t have to lug it around when you don’t need it.
The 512 Wh capacity is enough to run a television (110W) for 4-8 hours and a refrigerator (150W) for 3-6 hours. Count on it to power anything from your phone, laptop, home appliances, camera batteries, and more.
With the ability to charge ten devices simultaneously, it’s an excellent generator for outdoor adventures and emergencies. And, when it’s time for a recharge, you can expect it to charge completely within 1 hour. If you’re using the solar panel to charge, expect a 3-6 hour charging time.
Thanks to the X-Boost technology, you can also exceed the standard capacity. You can even run an oven, just at a lower wattage. And if you want to get really fancy with the River 2 Max, download the EcoFlow application. It will allow you to see current energy usage, remaining charge, enable quiet charging, and more!
Specifications
  • Capacity: 512 Wh
  • Weight: 6.1kg
  • Dimensions: 270 x 260 x 196mm
  • Solar Panel Charging Time: 3 to 6 hours
Pros
  • Easy-to-read display
  • Includes X-Boost technology
  • Capacity of 576 Wh
  • Removable battery
Cons
  • The LED light bar is very bright
Verdict: The River 2 Max is a cost-effective solution if you need a River 2 solar generator with an extra kick of power. The extra battery gives users a total capacity of 576 Wh. For adventures where you won’t need as much electricity, you can easily remove the extra battery, making your portable generator even lighter. Durable, mobile, and functional, River 2 Max is a winner in our book!
Make the RIVER 2 Max yours today!
EcoFlow DELTA 2 Series
Aussie electricity customers can expect about 200 minutes of power outages a year. But with extreme weather events becoming more common, that number is sure to increase. Don’t let the next power outage put your electronics out of commission for hours or even days.
The EcoFlow DELTA 2 Series offers power solutions for home backup and off-grid living. Whether your power suddenly goes out or you want to get away for a few days, these solar generators offer an eco-friendly option.
Here are the industry-leading solar generators that make part of the EcoFlow DELTA 2 Collection.
3. DELTA 2
Do you need a portable solar generator that will keep you powered for hours whenever, wherever? Look no further than EcoFlow’s solar generator DELTA 2.
Packed with 1024Wh capacity and the ability to power several devices at once, this is an excellent generator for outdoor adventures, power outages, professional work, or any other event where you need a reliable energy source.
Designed with groundbreaking charging technology, you’ll get a fast recharge when connected to a wall within one hour. If you prefer to stay off the grid completely, enjoy the EcoFlow 220W bifacial solar panel charger with monocrystalline silicon cells. Waterproof and durable, you can expect a full charge from 3-6 hours (recharge quicker by chaining several panels in series).
Users can connect the generator to EcoFlow’s free application for remote control. Use it to track how many watts an appliance is pulling or how many hours of charge you have remaining.
Specifications
  • Capacity: 1024 Wh
  • Weight: 27 lbs (12 kg)
  • Dimensions: 15.7 x 8.3 x 11.1 inches (40 x 21 x 28.1 cm)
  • Battery Type: LFP
  • Battery Life Cycle: 3000 cycles to 80%+ capacity
  • Solar Panel Charging Time: 3-6 hours
Pros
  • For indoor and outdoor use
  • Powers multiple devices simultaneously
  • Convenient companion app
  • Waterproof and durable
  • X-Stream charging technology
Cons
  • 3000 cycles mayl go by fast if used frequently
Verdict: Keep the power running for hours with the DELTA 2 solar generator. It can handle multiple devices at once, making it great for home and outdoor use. And to monitor power usage, download the EcoFlow app and keep tabs straight from your phone. It’s that easy!
Experience the DELTA 2 solar generator today!
4. DELTA Max
With a 2016 Wh capacity, the DELTA Max can handle devices up to 2400W (surge 4600W). Just enable the X-Boost technology, and you’re ready to power large, heavy-duty appliances like your refrigerator or dryer.
At 22 kg, it’s not the easiest generator to transport but definitely not the heaviest! It’s light enough to carry it between your home and RV for car and campsite. It keeps nearby appliances powered up, giving you and your family electricity for hours.
If the included power isn’t enough, know this solar generator offers the option of expandable capacity that reaches up to 6,000 Wh. All you need are two extra smart batteries.
Here are the top benefits you’ll receive with the DELTA Max:
  • 2-6K Wh expandable backup power
  • The ability to power 99% of your home devices
  • Convenient and fast dual charging
When it’s time to charge your handy device, you’ll get a fast charge from 0% to 80% in one hour with dual charging (combining AC with solar), or stick with an AC outlet for a 0-100% charge in 1.6 hours.
Specifications
  • Capacity: 2016 Wh
  • Weight: 22 kg
  • Dimensions: 49.7 x 24.2 x 30.5 cm
  • Battery Type: LFP
  • Battery Life Cycle: 800 cycles to 80%+ capacity
  • Solar Panel Charging Time: 3.2-6.3 Hours (Using 2x 400W Solar Panels)
Pros
  • Great handle design
  • Expandable backup power
  • Fast dual charging times
  • Ideal for home or outdoor use
Cons
  • Limited portability
Verdict: The DELTA Max is among the strongest portable power stations offered by EcoFlow. You’ll receive expandable backup power ranging from 2,000 Wh to 6,000 Wh. Better yet? It can power 99% of your home devices.
Enjoy the benefits of the DELTA Max today!
5. DELTA Pro
The most powerful of them all, the DELTA Pro, offers a massive capacity of 3600 Wh. And if this isn’t enough, you can expand this power up to 25K Wh with DELTA Pro Smart extra batteries.
The best solar generator in the industry, this is the world’s first portable home battery ecosystem. It offers expandable power for home emergencies, lower energy bills, and more.
When it’s time to charge the DELTA Pro, expect fast charging times of 1.8 hours when using an AC wall outlet. If you choose to utilize solar energy to charge, expect it to take 2.8 to 5.6 hours. It’s a robust, portable power station for off-the-grid adventures or if you want to bring down your home energy bill. And, with 3500 cycles per battery, expect it to last you several years to come.
EcoFlow has made it easy to control and monitor your portable power station. Simply download the EcoFlow app and control the DELTA Pro from your smartphone. Here, you can access everything from the power settings, charging levels, and more.
Specifications
  • Capacity: 3600 Wh
  • Weight: 99 lbs (45 kg)
  • Dimensions: 25 x 11.2 x 16.4 inches (63.5 x 28.5 x 41.6 cm)
  • Battery Type: LFP
  • Battery Life Cycle: 3500 cycles to 80%+ capacity
  • Solar Panel Charging Time: 4-8 hours
Pros
  • Up to 10.8K Wh capacity
  • Powers several devices simultaneously
  • Safe for indoor or outdoor use
  • Long battery life cycle (3500 cycles)
  • Includes wheels for easy transport
Cons
  • Heavy
Verdict: The DELTA Pro has your back, whether you’re camping for the weekend or dealing with a power outage. While it’s on the heavy side, the wheels and a comfortable handle enable easy transport. Overall, this is a cutting-edge portable power station that means business. Enjoy secure, reliable, and convenient power with the DELTA pro.
Try the DELTA Pro for yourself today!
What To Consider When Buying a Solar Generator
Whether you need a solar generator for camping, tailgating, or power outages, different devices will serve you better in specific situations. Here is what you want to consider when buying a solar generator:
Running Watts
Also known as rated wattage, the running watts indicate the electricity the unit can produce continuously. To find a solar generator that covers the devices you need to charge, tally up the wattage amounts for each device. Include your smartphone, tablet, laptop, power tools, appliances, etc.
Have your total wattage amount? You’ll need a generator with a running wattage greater than your total.
Watt-Hours
Next up is watt-hours (Wh) or capacity.
The Wh of the generator will determine how long a device can be powered. This measurement explains the length of time it can offer continuous power for 60 minutes at a full battery charge.
It will also help you determine how much power the solar generator can offer before it’s time to be recharged.
Peak Power
Also known as the starting wattage, the peak power output refers to the power the solar generator will need to provide before settling into the running output. This measurement is higher than running watts, but most devices only use it briefly until it settles down to running watts.
This brief surge of power is necessary to power up an electric motor on devices like refrigerators or fans. Therefore, if you plan to power a device with a motor, you’ll need to determine its starting wattage. Then, be sure the peak power or starting wattage can accommodate it.
Battery Type
Your generator will require two main types of batteries: lead-acid or lithium-ion (Li-ion). Units with lead batteries will be cheaper than those with Li-ion batteries. However, Li-ion batteries will last longer and tend to be lighter. The duration and weight are essential if portability is a top consideration.
At EcoFlow, our generators all use lithium-ion batteries. This choice offers four main benefits:
  • No petrol necessary (say goodbye to toxic fumes)
  • No maintenance required
  • No lost power
  • Low cost (users will spend 30% less when compared to regular petrol-powered inverter generators)
Recharge Time
How long will it take to recharge your solar generator? The time length is known as the recharge time.
Visit the user manual to learn how long it takes to get your generator battery to a full charge. The time depends on the charging speed of the solar generator and the solar power it’s receiving. Typically it should take less than 48 hours, but larger units will take more.
Also, factors like the size of the solar panels and the amount of sunlight they receive will affect charging times. If the weather is cloudy, charging time may take longer. Opt to charge these devices in direct sunlight for the best results.
EcoFlow offers extremely fast charging technology. Expect your generator to charge from 0% to 80% in less than an hour.
Are Solar Generators Worth the Money?
In short, yes. Solar generators are worth it because there’s no telling when your home will experience a power outage. Intense storms and winds can knock power out for hours, even days.
Plus, if you enjoy the great outdoors, a portable power station will enhance your experience. A portable solar generator can keep your devices charged and power even small appliances.
How Long Will a Solar Generator Last?
Rest easy knowing a solar generator will last between 25-35 years depending on brand and quality.
What Size Solar Generator Do I Need?
The best size solar generator is the one that is reliable for your needs. The best solar generator for you will depend on the following:
• Running watts
• Watt-hours
• Peak power
• Battery type
• Recharge time
Think about your intended use. What devices do you want to power? If you only want to power small appliances like your phone or laptop, a generator under 1,000 watts will do.
For larger appliances like your microwave or refrigerator, go with a generator between 1,000 to 3,000 watts.
And, to power an entire house, you’ll want a generator with over 5,000 watts of power.
Can a Solar Generator Power a House?
Absolutely! The right solar generator can power an entire house or off-grid cabin.
Are Solar Generators Noisy?
Solar generators make no noise. Unlike fuel-powered units, you will enjoy a quiet experience when using a solar generator. There aren’t any moving parts with solar units, and the only noise you may hear will come from the inverter. Even then, it’s minimal.
A solar generator can be a lifesaver if the power goes out. It does not require petrol and is powered directly by the sun. It’s quiet, suitable for indoor and outdoor use, and powerful enough to power an entire house. At EcoFlow, our portable power solutions offer fast charging, renewable charging, and all-around convenience. Shop our solar generator collection today!
