- Overview
- Specs
- Support
60W Portable Solar Panel
Compact and Lightweight Solar Panel for Outdoor Adventures
23.4%Conversion Rate
Wide Compatibility
Ideal Power
Source for RIVER 2
3.2kgCarry Single-handed
10s SetupAdjustable 30°-60°
IP68Classification
Fast and efficient solar charging.
With a high 23.4% conversion rate, the RIVER 2 portable power station can be fully charged in just 5 hours during peak sunlight hours. This means you can charge RIVER 2 anywhere and keep your essential appliances powered up.
Take solar power on the go.
EcoFlow's RIVER 2 Solar Generator is a must-have for camping or RV trips. Our new 60W portable solar panel is the lightest and most convenient option available. With a weight of only 3.2kg and a folding design, it's easy to grab and go at any time.
3.2kg
Unfolded:
Folded:
Power up in a flash with a 10-second setup.
Our brand-new foldable solar panel design allows for easy setup, so you can start harnessing the sun's energy right away. Plus, with a flexible angle adjustment from 30° to 60°, you can optimize your charging angle for maximum efficiency.
Built to weather the storm.
Our 60W portable solar panel is built to withstand a range of environments, from humid and wet to dry and dusty. With a high IP68 waterproof rating and a protective ETFE film, the solar cells continue to collect energy even during downpours.
ETFE Flim
EVA
Polyester Fabric
EVA
PERC Cell
PCB Bottom Plate
Polyester Fabric
IP68 Classification
Compatible with virtually all power stations.
Our solar panels use an all-inclusive connector that easily pairs with all EcoFlow power stations and most third-party batteries on the market, providing a convenient and seamless charging experience.
Take control with the EcoFlow app.
60W Portable Solar Panel is compatible with the Ecoflow app when connected to an EcoFlow power station. Monitor your solar charging status with smart, easy, and customized app control in real-time.
Unleash the Sun's Power for all Your Outdoor Adventures
Discovery more on it
See it in 360°
Click and drag the image to view.
See how it works in AR
Open this page using Safari on your iPhone or iPad.
Solar to XT60i Charging Cable
60W Portable Solar Panel Bag
User manual & Warranty card
You might also like
View more
EcoFlow RIVER 2Learn More
EcoFlow RIVER 2 MaxLearn More
EcoFlow 110W Portable Solar PanelLearn More
