How Many Watts Does A Light Bulb Use?
To get a clearer picture of wattage and its relationship with light, here’s a breakdown by bulb type:
"Darkness cannot drive out darkness; only light can do that."
When you flip a light switch, you may wonder how much power your light bulb consumes. The answer varies based on the bulb’s type, size, and efficiency. Understanding how many watts a light bulb uses can help you manage energy consumption, reduce costs, and make smarter decisions about the lighting in your home or office.
What Determines Light Bulb Wattage
Wattage indicates how much electrical power a light bulb consumes. Several factors determine the wattage of a bulb, including:
  • Bulb Type: Different types of bulbs, such as LED, incandescent, and CFL, have varying wattage needs to produce similar levels of brightness.
  • Brightness (Lumens): Higher wattage typically equals greater brightness, but newer technology like LED bulbs requires less power to achieve the same brightness.
  • Energy Efficiency: More efficient bulbs, like LEDs, use less power to produce more light, resulting in lower wattage.
  • Design: Some bulbs have designs that require more energy to produce a specific type of light, like directional spotlights or decorative bulbs.
  • Voltage: Higher voltage can reduce the wattage needed for the same brightness in some bulb designs.
Light Bulb Wattage By Type
Bulb Type
Common Wattages
Brightness Equivalent (in Lumens)
Incandescent
40W, 60W, 75W, 100W
450-1600 lumens
CFL (Compact Fluorescent Lamp)
9W, 13W, 18W, 23W
450-1600 lumens
LED (Light Emitting Diode)
4W, 6W, 9W, 12W, 15W, 20W
450-1600 lumens
Incandescent bulbs are traditional bulbs, using more power for less light. For example, a 60W incandescent bulb emits around 800 lumens of light, while an LED bulb of only 8-10W can achieve the same result.CFL bulbs use less energy than incandescent but more than LEDs. They’re generally more efficient than traditional bulbs but not as energy-saving as LEDs.LED bulbs are the most energy-efficient option available today. A 10W LED bulb can produce the same amount of light as a 60W incandescent bulb, making them the ideal choice for reducing energy consumption.
How Much Electricity Does a Light Bulb Use a Day, Month, and Year?
Bulb Type
Wattage
Daily Energy Usage (kWh)
Monthly Energy Usage (kWh)
Annual Energy Usage (kWh)
Incandescent
40W
0.24 kWh
7.2 kWh
87.6 kWh
60W
0.36 kWh
10.8 kWh
130.2 kWh
75W
0.45 kWh
13.5 kWh
164.25 kWh
100W
0.60 kWh
18.0 kWh
219.0 kWh
CFL
9W
0.054 kWh
1.62 kWh
19.56 kWh
13W
0.078 kWh
2.34 kWh
28.08 kWh
18W
0.108 kWh
3.24 kWh
38.16 kWh
23W
0.138 kWh
4.14 kWh
49.68 kWh
LED
4W
0.024 kWh
0.72 kWh
8.64 kWh
6W
0.036 kWh
1.08 kWh
12.96 kWh
9W
0.054 kWh
1.62 kWh
19.44 kWh
12W
0.072 kWh
2.16 kWh
25.92 kWh
15W
0.09 kWh
2.70 kWh
32.4 kWh
The table above shows how much electricity different types of light bulbs use per day, month, and year, based on common wattages of each and an assumed usage of 6 hours per day.
How Much Does it Cost to Run a Light Bulb (By the US State)
Table 1: New England, Middle Atlantic, and East North Central
States
Daily Cost (cents)
Monthly Cost (cents)
Annual Cost (cents)
Connecticut
10.14
304.13
3700.22
Maine
9.46
283.93
3454.51
Massachusetts
11.24
337.18
4102.31
New Hampshire
8.5
255.1
3103.67
Rhode Island
9.11
273.35
3325.73
New Jersey
10.94
328.19
3973.85
New York
12.58
377.46
4599.69
Pennsylvania
8.52
255.59
3115.86
Illinois
8.7
261.04
3186.73
Indiana
7.93
237.89
2906.91
Michigan
9.83
295
3607.8
Ohio
8.69
260.68
3183.29
Wisconsin
8.92
267.69
3269.82
Table 2: South Atlantic & East South Central
States
Daily Cost (cents)
Annual Cost (cents)
Delaware
8.83
264.87
3249.93
District of Columbia
9.93
297.9
3653.79
Florida
7.56
226.84
2779.76
224.67
2748.84
Maryland
9.02
270.55
3306.6
North Carolina
7.49
224.67
2748.84
South Carolina
7.68
230.39
2823.28
Virginia
7.77
233.12
2856.11
West Virginia
7.81
234.25
2859.34
Alabama
7.94
238.15
2908.61
Kentucky
7.97
239.08
2917.11
Mississippi
8.03
241.01
2936.34
Tennessee
7.82
234.65
2858.44
Table 3: West South Central & Mountain
State
Daily Cost (cents)
Annual Cost (cents)
Arkansas
7.02
210.47
2578.61
Louisiana
7.02
210.47
2575.54
Oklahoma
6.91
207.39
2531.76
Texas
9.19
275.67
3378.73
Arizona
9.12
273.6
3356.14
Colorado
9.1
272.89
3347.12
Idaho
6.58
197.42
2429.94
Montana
7.13
213.89
2610.25
Nevada
8.83
264.87
3249.93
New Mexico
8.56
256.76
3149.8
Utah
6.61
198.29
2433.84
Wyoming
6.93
207.89
2577.66
Table 4 : Pacific Contiguous & Pacific Noncontiguous
States
Daily Cost (cents)
Annual Cost (cents)
California
10.99
329.94
4014.27
Oregon
5.08
152.5
1855.37
Washington
4.26
127.76
1554.46
Alaska
8.06
241.7
2940.73
Hawaii
15.24
457.27
5563.48
Note: The data is calulated on the basis of the 60W incandescent light bulb, the 6-hours of usage per day, 30 days a month, 365 days a year and the offical electricity rates made public by
EIA in December, 2024.
Can a Portable Power Station Run Light Bulbs?
Portable power stations can indeed run light bulbs. They are often equipped with outlets for standard AC plugs and multiple DC ports. Take the EcoFlow RIVER 2 Max. With its 512Wh capacity and 500W AC output (surge 1000W), it is more than capable of powering low-wattage bulbs like LED or CFL types.
  • For a single bulb: The RIVER 2 Max can run a 60W incandescent bulb for several hours, or a 10W LED bulb for an even longer duration.
  • For multiple bulbs: If you plan to run several 60W incandescent bulbs (for example, three of them, totaling 180W), the RIVER 2 Max would easily handle the load. Given its 512Wh battery, it could run those bulbs for several hours, depending on the specific wattage.
  • Runtime: With the EcoFlow RIVER 2 Max, you could power a 60W LED bulb for about 8-10 hours, making it an efficient choice for running light bulbs during power outages or outdoor use.
In fact, the EcoFlow RIVER 2 Max has more to offer in various settings. Take a closer look at what really enables this must-have gadget:
Feature
Battery Capacity
512Wh
Power Output
500W continuous (Surge 1000W)
Charging Speed
0-100% in 60 minutes (5x faster than most power stations)
Battery Type
LiFePO4 (LFP) Battery
80%+ capacity after 3000 cycles (about 10 years of use)
Charging Methods
AC Charging, Car Charging, Solar Charging, USB-C Charging
Emergency Power Supply (EPS)
<30ms auto-switch for ultra-fast home backup during power outages
USB Outputs
2 x USB-A (5V, 2.4A, 12W max)
Solar Input
11-50V, 13A, 220W max
DC Output
12.6V, 10A/3A, 126W max
Discharge Temperature
14°F to 113°F (-10°C to 45°C)
Car Input
12V/24V, 8A, 100W max
App Control
EcoFlow app for monitoring and control remotely
Safety Certification
TÜV Rheinland certified for safety
Portability
Weighs approximately 13.4 lbs ;10.6 x 10.2 x 7.7 inches
5-year warranty
Let There Be Light
Understanding how many watts a light bulb uses helps not only reduce energy bills but also encourages more sustainable energy choices. Switching to efficient lighting like LEDs can save a lot in the long run. If you’re on the go, portable power stations, such as the EcoFlow RIVER 2 Max, can give you the flexibility to use light bulbs wherever you need them—just make sure you select the right size to match your needs.
Portable power station outside modern wooden house
