kVA to Amps: How to Convert, Calculate, and Apply It in Real Scenarios
If you’ve ever checked the specs of a generator, inverter, or power station, you’ve likely noticed values given in kVA. While it's a common electrical measurement, many people still wonder what it means in real terms—particularly in amps, the measurement of current that most appliances and electrical systems rely on.
Whether you're sizing a power backup system, selecting components for a solar setup, or trying to understand whether your generator can power certain appliances, converting kVA to amps is an essential skill. In this blog, we'll explain the difference between the two units, show how to convert them, and demonstrate how this applies to real-life use cases.
What is kVA?
kVA stands for kilovolt-amperes, which is a unit of apparent power in an AC (alternating current) circuit. Apparent power includes both:
Real power (kW), which performs actual work (e.g. turning on lights or running a refrigerator), and
Reactive power, which supports voltage regulation in the system but doesn't perform any physical work.
This makes kVA especially important when evaluating AC power sources, such as inverters, generators, and power stations.
A key aspect that influences the difference between kW and kVA is the power factor (PF). Most commercial systems operate at a power factor of 0.8 or higher. Residential systems may vary depending on the appliance mix.
What is an Amp?
An ampere (amp) is the unit of electric current—it measures how many electrons are flowing through a wire at any given moment. Most appliances are rated in amps because this value is used to determine cable sizing, breaker limits, and current-carrying capacity.
Understanding how many amps a system supplies is crucial to determining whether it can safely power your devices or if you're at risk of overloading your circuit.
How to Convert kVA to Amps
The conversion formula depends on whether your system is single-phase or three-phase:
🔹Single-phase formula:
Amps = (kVA × 1000) / (Volts × PF)
Single-Phase Quick Reference (120V and 240V)
kVA
Amps @ 120V
Amps @ 240V
0.5
4.17 A
2.08 A
1
8.33 A
4.17 A
2
16.67 A
8.33 A
3.5
29.17 A
14.58 A
5
41.67 A
20.83 A
7.5
62.5 A
31.25 A
10
83.33 A
41.67 A
15
125 A
62.5 A
20
166.67 A
83.33 A
25
208.33 A
104.17 A
🔹Three-phase formula:
Amps = (kVA × 1000) / (√3 × Volts × PF)
Tip: Use √3 ≈ 1.732To use these formulas, you need:
  • The kVA rating of your power source
  • The voltage of the system
  • The power factor
Carrying portable generator in outdoor setting.
Three-Phase Quick Reference (208V and 480V)
kVA
Amps @ 208V (3ϕ)
Amps @ 480V (3ϕ)
5
13.87 A
6.02 A
7.5
20.80 A
9.03 A
10
27.74 A
12.04 A
15
41.60 A
18.06 A
20
55.47 A
24.08 A
25
69.33 A
30.10 A
30
83.20 A
36.11 A
50
138.67 A
60.19 A
75
208.00 A
90.28 A
100
277.33 A
120.37 A
Quick Tip: What’s the Difference Between Single-Phase and Three-Phase?
  • Single-phase systems are common in homes and small offices. They use one active (live) wire and one neutral wire, typically delivering 120V or 230V.
  • Three-phase systems are found in industrial and commercial settings. They use three active wires and can carry higher loads more efficiently, typically at 400V.
In short: Use the single-phase formula for typical home appliances, and the three-phase formula for industrial tools, heavy machinery, or workshops.
Real-World Example with EcoFlow
Let’s look at how this applies in real life using EcoFlow’s DELTA Pro—a flagship power station designed for home backup and off-grid use.
Example 1: Running Appliances with a DELTA Pro (Single Phase)
  • System: Single-phase 240V
  • Device draw: 7.2 kVA
  • Power Factor: 0.9
Amps = (7.2 × 1000) / (240 × 0.9) = 7200 / 216 = 33.33 amps
Example 2: Three-Phase Workshop Setup
  • Load: 20 kVA
  • Voltage: 400V
  • Power Factor: 0.8
Amps = 20,000 / (1.732 × 400 × 0.8) ≈ 36.08 amps
In industrial or maker environments, kVA-to-amp conversion isn’t just a calculation—it’s a foundation for safe, compliant, and scalable electrical system design.
Tips:
  • If PF is unknown, use 0.8 as a safe default.
  • EcoFlow systems often operate near PF = 1.0, simplifying your calculations.
  • For live monitoring, use the EcoFlow app to track amps and watts directly.
Let EcoFlow Do the Math for You
If you're using EcoFlow products like the DELTA Pro or Power Kits, you don’t need to manually crunch these numbers every time. The EcoFlow app gives you real-time insight into:
  • How many amps you're currently drawing
  • Total watts consumed
  • Remaining runtime based on current load
This data-driven approach helps users manage loads, prevent overloads, and optimize system performance—all from a smartphone.
Quick Reference Table: Common Household Appliances
Appliance
kVA (PF = 0.9)
Amps (Approx)
LED Light Bulb (10W)
0.011 kVA
0.08 A
Laptop
0.067 kVA
0.5 A
Wi-Fi Router
0.017 kVA
0.13 A
Refrigerator (Modern)
0.167 kVA
1.25 A
Microwave (1000W)
1.11 kVA
8.33 A
Coffee Maker
0.89 kVA
6.67 A
Electric Kettle
1.67 kVA
12.5 A
Hair Dryer (High)
2.0 kVA
15 A
Toaster
1.22 kVA
9.2 A
Washing Machine
0.56 kVA
4.2 A
Clothes Dryer (Electric)
5.56 kVA
20.8 A
Dishwasher
1.33 kVA
10 A
TV (55")
0.13 kVA
1 A
Air Conditioner (Window)
1.1–2.2 kVA
8–16.7 A
Space Heater (Portable)
1.67 kVA
12.5 A
Vacuum Cleaner
1.56 kVA
11.7 A
Notes:
  • These values are approximations based on typical household appliance ratings.
  • Power factor (PF) is assumed to be 0.9 for general home appliances.
  • Actual values may vary depending on the efficiency and age of the device.
Tools and Resources
For quick calculations, you can use:
  • Online kVA-to-amp calculators (just Google it!)
  • EcoFlow’s app and product manuals, which offer real-time wattage and amperage estimates
  • Multimeters or clamp meters for live current measurement
Also, if you're using EcoFlow’s Power Kits for RVs or cabins, current ratings are built-in via the app interface, allowing you to monitor power draw and stay within safe thresholds.
Portable power station and electric kettle.
Knowing how to convert kVA to amps is not just useful—it’s essential when planning power systems. Whether you’re backing up your home, outfitting a mobile van, or going off-grid with solar, understanding your current draw ensures that you:
  • Select the right size of equipment
  • Prevent overloads
  • Maintain system efficiency and safety
EcoFlow’s ecosystem of power stations, modular batteries, and solar input solutions gives you the flexibility to scale your setup to your needs—and with built-in monitoring tools, you can manage power with precision. With the right knowledge and the right tools, you’re in full control of your energy.
1. Why is it necessary to convert kVA to amps?
Converting kVA to amps enables you to understand how much current a piece of equipment or system will draw. This is required for designing cables, circuit breakers, inverters, and generators optimally and safely.
2. What is the difference between kW and kVA?
  • kW (kilowatts) is a measure of real power—the usable energy that does work.
  • kVA (kilovolt-amperes) is a measure of apparent power, which comprises real power and reactive power.
Their relation is:
kW = kVA × Power Factor (PF)
3. Does power factor actually play a role in the conversion?
Yes. Power factor determines how much of the apparent power (kVA) is actually usable (kW). A low PF needs more current to deliver the same real power, and this will have some influence on efficiency and system design.
4. How can I tell if my system is single-phase or three-phase?
Single-phaseis normal for home and small business usage. You usually have one breaker per circuit.
Three-phase is used for industrial or commercial installations and is designed for heavy equipment. It will usually consist of three live wires with more voltage and more power output.
5. If I don't know the power factor of my device,
If there's no specification for power factor, a good conservative estimate for most general-purpose equipment is 0.8. But EcoFlow power stations are typically 1.0, so they're extremely efficient at converting power.
6. Can I use the same conversion equations for DC systems?
No. kVA is for AC (alternating current) systems. In DC systems, power is simply:
Watts = Volts × Amps
There is no power factor in DC because there is no reactive power.
7. Are these calculations ever required if I'm working with EcoFlow products?
Not necessarily. EcoFlow's smart app and product interface provide you with real-time current (amps), power (watts), and runtime readings—so you don't need to do the math yourself. But having the fundamentals under your belt is useful when designing or integrating EcoFlow into other electrical systems.
8. What if my power system is not rated for sufficient amps?
If your system cannot supply enough current, you risk:
  • Overheating or tripping breakers or overload protection
  • Drops in voltage
  • Powering connected appliances
Always get your system rated higher than your peak current demand.
