FPL Power Outages: What You Need to Know
Power outages happen—usually when you least expect them. If you live in Florida Power & Light's service area, you're no stranger to these interruptions. Summer storms, hurricane season, or equipment issues—whatever the cause, a power outage affects your daily life. Here are the basics: why outages happen, how FPL gets them back on, what to do when the lights go out, and how to be ready beforehand. A little knowledge makes a big difference during these unexpected events.
Common Causes of FPL Power Outages
Knowing what causes power outages helps you prepare and respond better when they happen. Here are the main reasons behind FPL service disruptions:
Hurricanes, Storms, and Lightning
Florida's location makes it prone to strong storms. Hurricanes can cause widespread outages by damaging multiple parts of the power grid at once.
Florida also gets many lightning strikes, especially during summer thunderstorms. Lightning can damage transformers, while strong winds can knock trees onto power lines, causing outages in several neighborhoods.
Transformer Failures and Equipment Malfunctions
The power grid has many interconnected parts that sometimes fail:
  • Coastal equipment wears down faster due to salt air
  • Transformers can fail from age or during heatwaves when AC use increases
  • When these break down, outages usually affect smaller areas like a neighborhood or a few streets
Falling Trees and Vegetation Interference
Florida's climate supports year-round plant growth that often interferes with power lines. Despite regular trimming by FPL, falling trees and branches remain a common cause of everyday outages. Even palm fronds blown into equipment during moderate winds can cause problems.
After storms, fallen trees often block crews from accessing and repairing damaged lines.
Animal Contact with Power Equipment
Florida's animals occasionally cause outages when they contact power equipment. Squirrels, snakes, and raccoons can create shorts in electrical systems, while birds nesting on power poles can cause recurring issues.
Vehicle Accidents, Construction Damage, and Planned Maintenance
  • Vehicle crashes into utility poles immediately cut power to connected areas
  • Construction work sometimes damages underground lines, especially in developing areas
  • FPL also conducts planned outages for maintenance with advance notice through email, text, or mail
Power outages stem from various sources in Florida, with weather and vegetation being the most frequent culprits. Knowledge of these causes helps residents anticipate potential disruptions and prepare accordingly.
What Happens During an FPL Power Outage
When power goes out, FPL's response system acts immediately. Here is what happens while waiting for power to be restored:
Automated Detection Systems Identify the Problem
FPL's smart grid technology detects outages in just seconds. Digital meters and monitoring equipment alert central operations of where and probably why without requiring customer calls, though alerting them still helps verify their information.
Damage Assessment Begins
FPL sends evaluation teams to assess the situation. They establish if the outage impacts a single residence, street, neighborhood, or even an entire area. This crucial step assists in prioritizing resources and setting estimated restoration times.
Repair Crews Mobilize According to Priority
FPL follows a strategy for planned restoration, starting with critical facilities (hospitals, emergency centers), followed by primary power lines with thousands of customers, neighborhood circuits, and single connections last. The disciplined method restores as many customers as quickly as possible.
Restoration Work Follows a Clear Sequence
The real repair process involves electrical system sense - fixing giant transmission lines and substations first and then going locally to distribution lines. It is possible for multiple crews to work at once on different sections of the system. Weather, accessibility restrictions, and severity of damage factor into how rapidly your power is restored.
What to Do When the Power Goes Out
When your lights go out unexpectedly, knowing the right steps to take helps keep you safe and comfortable until power returns. This section outlines essential actions before, during, and after an outage.
Stay Away From Downed Power Lines
Power outages create unique safety hazards that require immediate attention. Always treat downed power lines as deadly hazards - stay at least 30 feet away and call FPL or 911 immediately. Never drive over power lines or through flooded areas where lines might be hidden underwater.
Choose flashlights or battery-powered lanterns over candles to eliminate fire risks, especially if you have children or pets. If you must use candles, keep them away from flammable materials and never leave them unattended.
Generator users should follow strict safety protocols - operate them outdoors only, at least 20 feet from any window or door, and never in garages, even with the door open. Carbon monoxide from generators kills silently without warning symptoms.Report Your Outa
Report Your Outage to FPL
Determine whether the outage affects just your home or the broader neighborhood by checking if streetlights and neighbors' homes are dark. This helps you know whether to check your circuit breaker first or report an outage.
Report your outage promptly through FPL's app, website, or by texting OUT to 69375. Even if you think others have reported it, your specific location information helps FPL pinpoint affected areas more accurately.
Unplug sensitive electronics like computers, TVs, and gaming systems to protect them from potential power surges when electricity returns. Leave one light switch on so you'll know when power is restored.
Preserve Food and Conserve Resources
Keep refrigerator and freezer doors closed as much as possible. An unopened refrigerator keeps food safe for about 4 hours, while a full freezer maintains temperature for approximately 48 hours (24 hours if half-full).
Conserve your phone battery by activating low-power mode, reducing screen brightness, and limiting usage to essential communications. Consider using a car charger or portable power bank if available.
Stay informed about restoration progress through FPL's app or website using mobile data. Local radio broadcasts (via battery-powered or car radio) also provide valuable updates during widespread outages.
Check on vulnerable neighbors, particularly elderly individuals, families with young children, and those with medical needs. A brief wellness check can make a significant difference during extended outages.
Four Ways to Get Real-Time FPL Outage Updates
During a power outage, timely information helps you plan accordingly and reduces anxiety. Florida Power & Light provides several reliable channels to keep you updated throughout the restoration process.
Check FPL's Power Tracker Map
FPL offers an interactive outage map at fplmaps.com that shows real-time information about affected areas with pins representing outages that you can click for details. The map displays:
  • Current outage locations
  • Number of customers affected in each area
  • Estimated restoration times when available
  • Cause of the outage (when determined)
Use the FPL Mobile App
The FPL mobile app provides the most convenient way to report outages and check status with features that let you "easily report an outage and track restoration progress with the touch of a button". To download it, text "App" to MyFPL (69375) .
Set Up FPL Text and Email Alerts
To receive automatic updates about outages affecting your address, you can sign up for FPL's notification system which will provide you with estimated restoration times, number of affected customers, and notification when the problem is resolved. Text alerts can be managed by texting to 69375 .
Call FPL's Dedicated Outage Line
For immediate reporting of outages by phone, call 1-800-4-OUTAGE (1-800-468-8243) . This line is available 24/7 and should be used especially for reporting dangerous conditions like downed power lines.
Power Outage Toolkit: What to Have on Hand
Florida homes lose electricity for a myriad of reasons, from afternoon storms to outright hurricanes. Being prepared with the right supplies on hand makes the difference between an inconvenience and an ordeal.
When Darkness Falls
The first darkness is the first challenge in an outage. Keep lighting devices in strategic places around your home:
Your bedside table ought to have a reliable LED flashlight in close proximity for when the outages occur at night. Place another one in the kitchen drawer closest to your refrigerator for the speedy examination of food. A waterproof flashlight is placed in each bathroom.
Hands-free lighting makes tasks possible during extended outages. Store headlamps in your utility closet—they're invaluable for cooking, reading, or making repairs. For ambient lighting, battery-powered lanterns work wonders on dining tables or counter spaces, creating enough light for family gatherings.
When Communication Becomes Critical
When cellular networks get congested during widespread outages, alternative communication methods become essential:
A hand-crank or battery-powered AM/FM radio is in your kitchen for restoration news and emergency announcements. Keep mobile devices alive with multiple charging options—a power bank charged and in your nightstand, a car charger in your vehicle, and maybe a solar charger placed in a sunny window provide communication protection layers.
When Temperature Control Disappears
Florida's climate makes temperature management crucial during outages:
Summer outages require battery-powered fans—affect living rooms and bedrooms. Cooling towels stored in sealed containers with a little water are always on hand to cool necks. Winter outages, not likely in Florida, require extra blankets on hand in hall closets.
When Food Preservation Matters
Protecting your perishables requires advance planning:
Keep insulated coolers in your garage or storage area for quick deployment when outages exceed several hours. Keep digital refrigerator thermometers stored inside your refrigerator door for the quick determination of whether temperatures rise into the danger zone. Freezer blocks stored in the back of your freezer provide instant cooling capacity when transferred to coolers.
When Regular Power Returns
The moment of restoration brings its own requirements:
Install surge protectors on valuable electronics to prevent damage when service is reinstated. Include a notebook and pen in your emergency kit to record the duration and impact of the outage—useful information for potential insurance claims or FPL negotiations.
This strategic placement of tools throughout your home ensures you're never stuck searching in the dark for the things you need most. Each of these items serves a function to help you make power outages manageable until FPL can turn your power back on.
Plan Ahead for FPL Power Outages!
Power outages are part of life in Florida. Knowing why they occur, how FPL responds, and what to do makes these interruptions easier to handle with less stress. Keep essential equipment on hand—flashlights, battery-powered devices, and food storage materials. When outages occur, exercise caution around downed wires, report your outage to FPL, and use their tracking tools to stay informed. With simple preparation and accurate information, you can keep your household safe and warm until power returns. FPL restores power as quickly as possible, starting with critical facilities and moving on to individual homes.
Use EcoFlow DELTA 3 Plus Portable Power Station during power outageUse EcoFlow DELTA 3 Plus Portable Power Station during power outage
