How Much Does It Cost to Install Solar Panels? A Clear 2026 Breakdown
Solar prices have dropped a lot over the past decade. But the math for homeowners changed in 2026. The 30% federal tax credit for home solar ended with systems installed after 2025. That makes the sticker price matter more than ever. So how much does it cost to install solar panels today? Most homes land somewhere between $15,000 and $35,000 before any local incentives. This guide breaks down average prices, what drives them, and what incentives still exist. It also covers smart ways to lower your total.
The Average Cost to Install Solar Panels Right Now
Installers usually quote solar in dollars per watt. That makes it easy to compare systems of different sizes. Your total depends mostly on how big a system your home needs.
EnergySage marketplace data puts the average near $2.60 per watt before incentives. That figure is current as of September 2026. The average system on its platform is about 12 kW, which comes to roughly $31,000. Quotes from a single door-to-door seller often run higher. Berkeley Lab data has shown a national median closer to $3.50 per watt for cash-purchased systems.
That gap is worth knowing, because shopping around can save you thousands. Prices also shift by state. Some colder states, like Nebraska and South Dakota, sit near the top of the range.
Estimated Cost by System Size
Here's what common system sizes cost at $2.60 per watt. Treat these as ballpark numbers, since local prices vary. Bigger systems often get a slightly lower price per watt.
System Size | Estimated Cost | Good Fit For |
4 kW | About $10,400 | Small homes or low usage |
6 kW | About $15,600 | Average homes in sunny states |
8 kW | About $20,800 | Medium homes with some AC use |
10 kW | About $26,000 | Larger homes or electric heat |
12 kW | About $31,200 | Big homes, EVs, or high usage |
Your size depends on your yearly electric use and your local sun. Before you ask for quotes, figure out how many solar panels you need for your usage.
People also ask about the price of one panel. Most home panels today are rated around 400 watts. At $2.60 per watt, that's roughly $1,040 per panel, fully installed. A 12 kW system would need about 30 of them.
The panel itself is only a small slice of that cost, though. A typical quote also covers the inverter, racking, wiring, and breakers. Labor, permits, inspections, and utility fees add more. So do sales, design, and company overhead. These “soft costs” now make up a large share of the total. That's why two quotes for the same gear can look so different.
What Changed With the Federal Solar Tax Credit
The biggest cost story of 2026 is the lost tax credit. For years, homeowners could take 30% off their federal taxes. That's no longer an option for new home systems.
The Residential Clean Energy Credit, also called 25D, ended after 2025. The IRS FAQ on the credit changes explains the timing rule. An expense counts as made when the install is finished. So a system finished after December 31, 2025, doesn't qualify. Paying early didn't help if the install wrapped up in 2026.
This rule covers systems you buy with cash or a loan. It also applies to home batteries you own.
The end of the home solar credit hits a 12 kW buyer hard. At $31,000, that's more than $9,000 in lost savings. That means payback takes longer for many buyers than it did a year ago. Solar can still pay off, especially where power rates are high. But the numbers now depend much more on local rates, state incentives, and a fair installed price.
Incentives That May Still Help
The federal credit is gone, but other help may exist. Check these options:
State tax credits: Some states offer their own solar credits.
Utility rebates: Some local utilities pay cash for new systems.
Property tax breaks: Many states exempt solar from home value increases.
Sales tax exemptions: Some states skip sales tax on solar gear.
Leases and PPAs: These follow different commercial tax rules, so pricing may differ.
The Department of Energy's Homeowner's Guide to Solar is a good place to start your research. Your state energy office can tell you what's active now.
With less federal help, many homeowners now look closely at storage and smaller setups.
Adding Battery Storage and Backup Power
Solar panels alone don't keep your lights on in an outage. Most grid-tied systems shut off when the grid goes down. That's a safety rule for utility line workers.
Storage lets you use more of your own solar power. That's a big deal in places where net metering policies vary by state. If your utility pays little for extra power, storing it makes more sense. A home battery also gives you backup during storms and outages. Storage helps with time-of-use rates too, since you can save cheap daytime solar for pricey evening hours.
The catch is cost. A wall-mounted home battery with pro install can add thousands to your project. That's a lot on top of a rooftop system.
A Lower-Cost Way to Start
A portable power station is a more flexible option. It needs no roof work, no permits, and no installer. You can pair it with portable solar panels and start small. It covers key loads like a fridge, lights, and a router during an outage. Later, you can add more capacity as your budget allows. It's also handy for renters, since nothing gets bolted to the house.
The EcoFlow DELTA 3 Plus is a smart fit for smaller loads and tight budgets. But some homes need to power more at once. A fridge, a microwave, and a sump pump can push past 1 kWh fast. For longer outages and heavier use, a 2 kWh unit gives you more room.
Both paths have a place. Here's how they compare:
Feature | Rooftop Solar | Portable Solar Setup |
Upfront cost | Often $15,000 to $35,000 | A small fraction of that |
Installation | Pros, permits, inspections | Plug and play |
Outage backup | Only with a battery | Built in |
Moves with you | No | Yes |
Best for | Cutting monthly bills | Backup and flexible use |
Many homeowners end up using both. A rooftop system trims the monthly bill. A portable unit covers outages, camping trips, and backyard projects.
What Drives Your Solar Price Up or Down
Two homes on the same street can get very different quotes. Your roof, your usage, and your installer all play a part. Knowing the main factors helps you spot a fair deal.
Location: Sunny states with lots of installers, like Arizona, often have lower prices per watt.
Roof type and shape: Steep, complex, or older roofs cost more to work on.
Shade: Heavy shade may call for more panels or microinverters.
Equipment: Premium panels and inverters raise the price.
Electrical upgrades: An older breaker panel may need an upgrade.
Financing: Loans often include dealer fees that raise the total.
Some costs don't show up in the first quote. A roof near the end of its life is the big one, since replacing it first can save a costly teardown later. Tree trimming, a main panel upgrade, and future panel removal during reroofing can add up too. Inverters also tend to wear out before panels, so plan for a replacement down the road.
How to Get a Fair Quote
A little homework pays off here. Follow these steps:
Get at least three quotes from licensed local installers.
Compare the price per watt, not just the total.
Ask for the cash price and the loan price side by side.
Check warranties on panels, inverters, and labor.
Read reviews and confirm the installer's license.
Look for NABCEP certification, the industry's standard credential.
Some handy homeowners wonder about skipping the installer. Learning the real cost to install solar yourself can help you decide. Just know that permits and utility approval still apply. Your utility will also need to approve the system before you turn it on.
Most homeowners pay about $2.60 per watt to install solar, or roughly $15,000 to $35,000 total. The 30% federal credit is gone for new home systems, so shopping around matters more now. Get several quotes, compare price per watt, and check state incentives. If a full rooftop system isn't in your budget yet, start smaller. The EcoFlow DELTA 3 Plus and EcoFlow DELTA 3 Max offer flexible solar backup without the install.
Q1: How much does it cost to install solar panels on an average home?
Most homes pay between $15,000 and $35,000 before local incentives. The average 12 kW system runs about $31,000 at current marketplace prices.
Q2: Can I still get the 30% federal solar tax credit?
Not for new home systems you own. The 25D credit ended for installs finished after December 31, 2025.
Q3: How much does it cost to install a single solar panel?
Installers rarely price one panel on its own. Labor, wiring, and permits make tiny systems cost more per watt. A portable panel paired with an EcoFlow DELTA 3 Plus is a simpler way to start small.
Q4: How long does it take for solar panels to pay for themselves?
It depends on your local power rates, sun, and incentives. Without the federal credit, payback often takes longer than it did before 2026.
Q5: Is it cheaper to get solar panels installed in some states?
Yes. Prices per watt tend to be lower in sunny states with lots of installers, such as Arizona. Local labor and permit costs also play a big role.
Q6: Do solar panels need much maintenance?
Not much. Most systems need an occasional cleaning and a quick check after big storms. Inverters often wear out before the panels do, so budget for one down the road.
