What Is the Average Electricity Bill in Kansas? EcoFlow Can Help You Save
The cost of living in Kansas is notably lower than the national average, including housing, groceries, healthcare, and electricity. Some utilities in Kansas can be slightly higher than other areas due to its rural land and communities, but thankfully, they pay less than the national average electric bill.
Get a detailed look at what the average Kansas homeowner pays each month for electricity, learn what factors impact this cost, and find ways to potentially save on energy.
What Is The Average Electricity Bill in Kansas
Kansas residents spend an average of $187 per month on electricity, or $2,244 per year. This is lower than the national average annual cost of $2,650. Each kilowatt-hour of electricity costs 14 cents in Kansas, so houses use around 1,299 kWh of power each month, or 15,588 kWh annually.
Each electric bill covers the cost of producing the electricity you use and the maintenance of the electrical grid. Some houses may utilize time-of-use plans, including different power rates during peak and off-peak times. For example, peak pricing in the summer for Evergy, Kansas’ primary electricity provider, is from 4 to 8 pm on weekdays. Other plans offer lower rates during the night and on weekends. However, customers must opt into these plans, as Evergy will not automatically enroll anyone in these time-of-use plans.
If your home electric bill is more than this state average, there are ways to reduce electricity by 75%—including switching to solar, using smart appliances and AC systems, improving insulation, and turning off lights when not in the room.
What Factors Influence The Average Electricity Bill in Kansas
What determines the average electricity bill in Kansas? Many factors come into play, from the home’s size and location to family lifestyles and energy rates.
Size of Home
The home size dictates a few things:
  • How much square footage the HVAC system needs to heat and cool
  • How many lights there are
  • Potentially, how many people live in the home
  • How many devices and appliances are in the home
The larger the space, the harder the HVAC system has to work to regulate the temperature. The more lights there are, the more energy it uses. The more people and appliances in the home, the more electricity will be drawn.
While home size plays a significant role in how much you pay for grid power, it also influences what solar generator size you would need to run the entire house. For example, the EcoFlow DELTA 3 Plus + 220W Solar Panel can support homes with up to 1024Wh capacity and 1800W output, capable of powering 99% of household appliances.
Location
Where your home is located also matters. Homes in eastern Kansas, in particular, are subject to extreme heat during the summer, which can make the HVAC system work overtime to keep the indoors cool. On the other hand, the western half of Kansas is colder and windier than the east side, which may make western electricity bills higher in the winter.
Other aspects of location that come into play include:
  • The state’s reliance on renewable energy vs. fossil fuels
  • Utility fees
  • Local energy infrastructure
  • Regulated vs. deregulated markets (some electric companies have a monopoly over the area, while others have more options for utility providers)
Energy Tariff and Rate
The utility provider sets the energy rate, and historically, Kansas has seen a gradual increase in these rates over time. Rates are influenced by fuel costs, regulatory changes, and infrastructure costs.
Time of Year
Kansas can be hot and humid in the summers, especially in the east. Winters can also be frigid, with temperatures commonly dropping below freezing and frequent snow and ice. Extreme weather like this puts a strain on a home’s HVAC, which is the primary energy user. Because of this, electricity bills may be higher in the winter and summer.
Lifestyle
How a family uses energy and views the value of electricity also influences how much they pay each month. A budget-minded family may be more adamant about turning off lights when leaving a room, unplugging devices and appliances when not in use, keeping doors and windows closed, and maintaining a moderate indoor temperature. Families that prefer the convenience of leaving electronics plugged in, lights turned on, and especially cool or warm homes will pay more for all the electricity this uses.
Insulation and Home Age
A new home often has better insulation than an old one, which helps regulate indoor temperature. With poor insulation, the HVAC must work harder to maintain the set temperature, so homes with better insulation often see lower energy bills each month. Newer windows also perform better at keeping air indoors.
How to Calculate the Average Electricity Bill in Kansas
There are two ways to calculate an average electricity bill in Kansas: one using your personal energy usage data and another using general averages.
To calculate your average electricity bill, gather your bills from the past year. Add up the monthly electricity spending and divide that by 12 to get the average monthly cost.
To use general averages, you can multiply the average monthly kWh consumption by the average energy cost per kWh. Kansas residents pay around $0.14 per kWh, and the average residential electricity customer consumes around 1300 kWh monthly.
Using these two figures, we can multiply them to calculate:
1300 x .014 = ~$181 per month
Remember that this estimate may not reflect your home’s energy bills if you have more or fewer people in your home than the average household, a larger or smaller home than average, or use more or less energy than the average consumer.
How to Save on Electricity in Kansas
If you’re unsatisfied with the amount you pay for electricity in Kansas, here are a few ideas to help you reduce consumption and cut costs.
Finding an alternative power source that you can use to supplement grid power is an excellent first step. EcoFlow Portable Power Stations can charge devices or appliances using stored power from solar panels, allowing you to reduce your grid consumption and lower your bill.
Even if you don’t want to invest in a solar setup, EcoFlow DELTA Series Portable Power Stations can still help you save by utilizing power when it’s most affordable. For example, if you know that energy rates are lowest at night and on weekends, you can plug in the EcoFlow DELTA 3 Plus to an outlet during these times and unplug it once fully charged. Then, you can use them as a backup power source during peak periods to avoid paying electricity rates at their highest.
How Much Electricity Does the Average Family in Kansas Use?
The average Kansas family uses around 1,299 kWh of electricity annually, totaling around 15,588 kWh annually. This means they use about 4.65% more energy than the average US home but still pay less than the national average electricity bill.
Electricity costs in Kansas are moderate compared to other areas of the United States. However, some residents naturally want to minimize their monthly spending and reduce overall electricity consumption. Small lifestyle changes, like adjusting the indoor temperature by a degree or two or turning off lights when you leave a room, can add up, but there are simpler ways to make a significant difference with little effort on your part. Explore how EcoFlow DELTA Series Solar Generators can help you rely less on grid power and, thus, reduce your monthly energy costs.
Save Bills
