How to Handle a Power Cut and Prepare for the Next One
A power cut can strike without warning, whether it’s a stormy night or a quiet afternoon. Suddenly, the lights go out, devices stop charging, and you’re left wondering what to do next. While most outages in the UK are short-lived, they can still catch you off guard—especially if you’re not prepared.
In this guide, you’ll learn the most common reasons why power cuts happen here in the UK, what steps to take during one, and how to make sure you’re ready if it happens again.
What Is a Power Cut?
A power cut, also known as a power outage or power failure, is when your electricity supply is suddenly lost, either in your home or across a wider area. Some cuts are unplanned, caused by things like damage to the network or bad weather.
Others are planned, usually when your local electricity company needs to carry out maintenance or upgrade the system.
Common Causes of Power Cuts in the UK
Power failures in the UK aren’t that common, but they do happen. Here are the common causes of power outages in the UK:
  • Severe Weather: Storms, heavy rain, snow, lightning, or strong winds can damage overhead power lines or substations. In many cases, falling trees or debris bring down the lines and cause widespread outages.
  • Equipment Failure: When infrastructure is old or overloaded, components like transformers, cables, and switches can fail due to wear, corrosion, or overheating, particularly during periods of high demand.
  • Scheduled Maintenance: Your Distribution Network Operator (DNO) might schedule a power cut to carry out work that keeps the network safe and reliable. They’re required to give you advance notice when this happens.
  • Accidental Damage: Third-party work such as road construction, traffic accidents, digging, or home renovations can damage underground cables, causing unplanned disruptions in service.
  • Grid Overload: High electricity demand, especially during cold spells or heat waves, can exceed supply in certain areas. This may lead to controlled outages to protect the grid from failure.
  • Animal Interference: Birds, rodents, or squirrels can interfere with power equipment, causing short circuits or physical damage. Though less common, these incidents still lead to localised outages.
  • Problems Inside Your Home: A tripped fuse, faulty appliance or overloaded circuit can cause you to lose power, even if your neighbours still have it.
What to Do During a Power Cut
When a power cut hits, quick action can protect your home, prevent damage, and keep you safe. Here’s what to do to manage the situation calmly and effectively.
Check your fuse box first
Before assuming there’s a wider outage, check your consumer unit (fuse box). If a switch has tripped, try resetting it after turning off any sensitive appliances. If power doesn’t come back, it’s likely an external issue.
Report the power cut and stay updated
If the lights are out in your street too, call 105—a free, UK-wide number that connects you to your local electricity network operator. You can also report outages online via your DNO’s website.
Follow your DNO on social media, check their website, or use the National Grid live power-cut map for updates and estimated restoration times.
Unplug electrical devices
During a power cut, unplug sensitive electronics such as televisions, computers, routers, and gaming consoles. When electricity is restored, sudden voltage spikes or power surges can damage internal components or shorten the lifespan of your devices.
It’s also advisable to unplug large appliances like washing machines and microwaves if the outage is prolonged. Leave one light or lamp plugged in so you can easily tell when the power comes back on.
Use a torch—not candles
Avoid using candles, as they increase the risk of accidental fires, especially during extended outages or when moving around in the dark. Instead, use battery-powered torches, headlamps, or LED lanterns, and keep them stored in a place that’s easy to access.
Keep fridge and freezer doors closed
During a power cut, it’s important to keep refrigerator and freezer doors closed as much as possible. This helps keep food cold for longer. A fridge should stay cold for around 4 hours, and a full freezer for up to 48 hours—provided the doors stay closed.
How to Prepare for Future Power Cuts
A bit of planning can make a huge difference when the power goes out unexpectedly. Here’s how to stay one step ahead:
Put together a power cut kit
Pack essentials like torches (with spare batteries), a wind-up or battery radio for updates, power banks, bottled water, tinned food, a basic first aid kit, and a bit of cash (just in case card machines are down).
Save important numbers
Add 105 and your DNO’s contact details to your phone, and keep a written copy in your kit in case your mobile battery dies or signal drops.
Use surge protection
Plug electronics into surge-protected extension leads to guard against sudden voltage spikes when power returns. For computers or internet routers, consider an uninterruptible power supply (UPS) if they’re critical.
Use EcoFlow portable power station during outage
Invest in home backup power
When the power goes out, having your own backup supply can make a huge difference. A home backup power station lets you keep the essentials running—whether that’s your phone, fridge, internet, medical equipment or a few lights.
Traditional petrol generators are loud, high-maintenance and pump out exhaust. Modern portable power stations use lithium-iron-phosphate (LFP) cells instead, delivering silent, fume-free electricity that switches on in seconds during a power cut.
Because the battery is rechargeable from the mains, solar panels, or even EV stations, you can top it up whenever tariffs are low or the sun is shining and keep it ready for the next outage.
The EcoFlow DELTA Pro 3 Portable Power Station is an excellent choice. It features a scalable capacity of 4–12 kWh, which can be tailored to your energy needs. With a powerful 4,000W output, it can simultaneously power multiple home appliances. The battery utilizes durable LFP (lithium iron phosphate) cells and is rated for over 4,000 charge cycles. Charging is fast and flexible—you can recharge it via the mains, solar panels, or even an electric car charger. Thanks to X-Stream fast-charging technology, it reaches 80% capacity from 0% in just 1 hour. Additionally, it allows you to monitor energy usage and adjust settings through the EcoFlow app, making it a practical solution to keep your home operational during any power outage.
The EcoFlow DELTA Pro 3 Portable Power Station offers scalable 4–12 kWh capacity and 4,000W output for multiple appliances. With durable LFP cells (4,000+ cycles), it charges via mains, solar, or EV chargers—reaching 80% in 1 hour with X-Stream tech. App-controlled monitoring ensures seamless home operation during outages.
Think ahead with food
Group frozen meat in one part of the freezer (usually the coldest spot) and keep a fridge thermometer inside. If the temperature rises above 5°C for more than four hours, it’s safest to throw affected food away.
Register for Priority Services
If you rely on medical equipment, are elderly, have young children, or need extra support, sign up to your DNO’s Priority Services Register. You’ll get tailored support during outages, including welfare checks and updates.
No one enjoys being left in the dark—but with a bit of planning, a power cut doesn’t have to turn into a crisis. Make sure you’ve got a torch (not just your phone), know where to check for local outage updates, and keep essential numbers to hand—like your Distribution Network Operator (DNO).
A little preparation goes a long way. Whether it’s a few hours without power or an unexpected overnight blackout, staying calm and ready can make all the difference.
How do I check if there’s a power cut in my area?
If you suspect a power cut, first check whether it’s just your home—look at your fuse box and ask neighbours if they’re affected. For a wider outage, enter your postcode on your local Distribution Network Operator (DNO) website (e.g., UK Power Networks, Western Power Distribution), or use the National Grid live power-cut map.
You can also call 105 free, any time, and you’ll be connected to your regional network operator. This line will let you report a cut or get an idea of how long it’ll last.
What is the meaning of power cut?
In everyday British usage, a “power cut” simply means an interruption in the electricity supply to homes or businesses. It’s the same as a power outage or blackout, but “power cut” is the most common UK term.
It can be local—perhaps caused by a blown fuse or street-level fault—or much bigger if caused by grid issues, severe weather, or maintenance. In short, when the power goes off unexpectedly, that’s a power cut.
How long should a power cut last?
Most unplanned power cuts in the UK are restored quickly—typically within around 30 to 50 minutes. Ofgem and network operators report average restoration times vary, but many interruptions last under an hour.
Occasionally they take several hours, especially if caused by severe weather, equipment failures, or underground cable faults. If it goes on much longer, you can call 105 for an update or check online to see progress.
Is it correct to say power cut?
Absolutely! In the UK, “power cut” is the usual term. It’s widely used in everyday speech, press bulletins, and by officials. In American English you might hear “power outage” or “power failure,” but in British English, a “power cut” is perfectly natural and correct.
Power Outages
