5 Best Portable Power Stations For CPAP in 2024 Reviewed
A CPAP machine (Continuous Positive Airway Pressure) is the most common treatment for sleep apnea. Sleep apnea causes interruptions or pauses in breathing due to a temporary blockage or obstruction in the throat.
A CPAP machine sends a steady flow of pressurized air. It helps people with sleep apnea breathe easier, in addition to lowering blood pressure and reducing the risk of stroke, diabetes, and headaches.
The only downside to a CPAP machine is that it relies on a constant power source throughout the night to deliver continuous airflow to the sleeping person. Frequent power outages or living off the grid make it challenging to receive a reliable air supply.
This is where a portable power station (PPS) comes in, so you can have backup power when you need it most. Find the best portable power stations for CPAP machines in 2024 to ensure a restful and healthy night’s sleep.
5 Best CPAP Portable Power Stations
1. EcoFlow River 2 Max
Combine power and portability for any outdoor location or long trip off-grid with the EcoFlow River 2 Max. This portable power station always ensures you have extra power when needed.
The River 2 Max boasts rapid charging, and it can reach a full 100% full charge within an hour using a regular wall outlet. Fast charging means peaceful sleep, knowing you have power in a flash, whatever the location or conditions.
The River 2 Max is not just for a CPAP machine but can also power several devices simultaneously with a carport, USB-C, USB-A slots, and AC/DC outlets. This portable power station can also handle thirsty appliances up to 1000W.
Specifications
  • Capacity: 512Wh (1000 on X-Boost)
  • AC Output: 500W
  • Weight: 13.4 pounds (6.1 kg)
  • AC Outlets: 4
  • Charging time: 60 minutes to charge to 100%
  • App: Supported
Pros
  • Versatile – various outlets handle 80% of essential appliances in addition to CPAP machines
  • Powerful – Runs heavyweight household appliances up to 1000W
Cons
Not suitable for extended outages – There are bigger portable power stations that offer a longer run time for extended power outages or situations where recharging is difficult.
2. EcoFlow River 2 Pro
The EcoFlow River 2 Pro is for users who need peace of mind either for extended power outages at home or who often live off the grid. Compact and truly lightweight, this unit weighs only 17.2 pounds (7.8kg) and, for power/size ratio, is one of the best portable power supply options on the market.
The River 2 Pro offers a reliable backup solution for CPAP thanks to its higher capacity. It can run a 30-watt CPAP for up to 16 hours continuously or a 60-watt CPAP machine for up to 8 hours nonstop.
This PPS also delivers a full charge in just 1 hour. Delivering higher output with X-Boost, the River 2 Pro can power up to 80% of devices and appliances up to 1600W, so it can run your CPAP and then some.
The River 2 Pro is a robust PPS solution for long periods off-grid or extended outages. It’s a reliable backup even when you need to power several devices. A variety of outlets supports almost every type of appliance, offering a versatile power solution for all kinds of situations.
Specifications
  • Capacity: 768Wh (1600Wh on X-Boost)
  • AC Output: 800W
  • Weight: 17.2 pounds (7.8 kg)
  • AC Outlets: 4
  • Charging time: 60 minutes to reach full charge
  • App: Supported
Pros
  • Solid CPAP power backup  – The River 2 Pro is the most robust solution in the River 2 series, running your CPAP machine for upwards of 16 consecutive hours
  • Lightweight – Weighs only 17.2 pounds (7.8kg), making it super portable
  • Fast Charge – Offers a full charge in 1 hour
  • Impressive output – X-Boost power runs devices up to 1600W; that’s most household devices and appliances with impressive run times
Cons
No Uninterrupted Power Supply – A 30-millisecond lapse from the grid to battery power could disrupt the CPAP machine’s usage, although it’s highly unlikely to be noticeable
3. EcoFlow DELTA Mini
Don’t let the name fool you—the EcoFlow DELTA Mini offers mighty capacity in a compact solution. It’s the perfect go-to portable power station for CPAP to use at home or when you are away on a business trip or vacation.
This compact portable power station has a comprehensive selection of wall-style, USB, and DC outlets. It can power other devices and appliances and a CPAP machine simultaneously.
X-Stream technology means the DELTA Mini charges in just over 1.5 hours — up to four times faster than other portable power stations. Even in bad weather, when the power supply is intermittent, you can know you recharge quickly and sleep easy.
Specifications
  • Capacity: 882Wh
  • AC Output: 1400W
  • Weight: 23.6 pounds (10.7 kg)
  • Outlets:12
  • Charging time: 0-80% in 1 hour
  • App: Supported
Pros
  • Super lightweight – Highly portable at only 23.6 pounds (10.7kg), making it ideal for various indoor and outdoor locations.
  • Variety of outlets – Different styles of outlets make this portable power station suitable for many appliances and devices besides CPAP machine use
  • Hybrid charging – Designed to use a wall outlet or a 12V car adapter for outdoor camping trips
Cons
  • Not optimized for CPAP use – This PPS has less capacity than the River 2 Pro but weighs more, meaning it may not be the ideal solution for every CPAP user
4. EcoFlow DELTA
For exceptional performance and output, the EcoFlow DELTA can power your CPAP and around 12 other devices simultaneously. It’s a reliable energy source in an off-grid location or during an emergency outage.
Impressive power delivery means it’s not going to be a choice between the CPAP machine, the television, or the fridge—you can run it all. The DELTA easily powers your CPAP machine for 21 hours, a fridge for six hours, or television for eight hours.
The unique EcoFlow technology means that this portable power station can charge from 0%-80% within one hour, faster than any other battery PPS on the market, for complete peace of mind.
Specifications
  • Capacity: 1260Wh
  • AC Output: 1800W
  • Weight: 30.9 pounds (14 kg)
  • Outlets: 13
  • Charging time: 0%-80% within 1 hour
  • App: Not supported
Pros
  • Ideal CPAP backup PPS  – With 21 hours of continuous power, the DELTA is your go-to solution in an extended outage
  • Fast charging – 80% of a full charge within an hour
  • Multi-device functionality – Powers 13 devices simultaneously
  • Supports heavy-duty appliances – For home use in an outage or off-grid situation, the DELTA powers greedy appliances like fridges
Cons
  • No app control – No remote control or status monitoring
5. EcoFlow DELTA Max
The EcoFlow DELTA Max is a high-powered PPS fit for any situation and location. If you thought the DELTA was impressive, its beefed-up cousin, the DELTA Max, is even more so.
You can run your CPAP machine for 34 hours with the DELTA Max. Even in an extended power outage that lasts over a day, you can rest easy knowing your machine has the power it needs.
The DELTA Max offers dual charging speeds up to 3600W and can reach 80% charge in one hour from a wall outlet.
If that wasn’t enough, the DELTA Max also has expandable capacity. Crank up your capacity to an impressive 6kWh with an additional DELTA Max Smart Battery, and keep your home and your CPAP machine running efficiently in any emergency.
Specifications
  • Capacity: 2016Wh-6048Wh
  • AC Output: 2400W
  • Weight: 48 pounds (22 kg)
  • Outlets: 15
  • Charging time: 1.8 hours with a standard wall outlet
  • App: Supported
Pros
  • Impressive output – X Boost technology will support a CPAP machine and the rest of the household in an outage
  • Simple power boost – Smart batteries expand capacity for a whole-home backup solution
  • Real-time energy tracking  – Monitor your energy use, charging rate, and more all in one easy-to-use app
Cons
  • Not lightweight – This unit is heavy and more for stationary use in the home, rather than moving from room to room
