EcoFlow ImageAsk a Question
Shop Now
EcoFlow Image
EcoFlow DELTA 3 Classic (1024Wh)
Pay less. Still get enough power.
EcoFlow Image
Strong Output
1800W rated output 3600W surge output
EcoFlow Image
45 Mins Fast Charge
AC charges to 80% in just 45 minutes
EcoFlow Image
Works Anywhere You Go
EcoFlow Image
10 Years of Reliable Power[1]
EV-grade full-tab LFP batteries
EcoFlow Image
Ultra-Quiet Performance
As low as 30dB under light load — ideal for outdoor, camping, and night-time use
EcoFlow Image
Smarter & Safer Power Management with BMS
ARM Cortex chipset Cloud Intelligence Algorithm
EcoFlow Image
Fast Emergency Power Switching
<10ms UPS
EcoFlow’s Best-Value 1 kWh Portable Power Station
Smart choice for your outdoor adventures and work
X-Stream: Ready in Just 45 Mins
DELTA 3 Classic charges from 0–80% in just 45 minutes with AC charging. It keeps you powered faster, smarter, and with greater peace of mind—whether indoors, outdoors, or on the move.X-Stream enables ultra-fast charging without compromising battery life. It intelligently adjusts voltage and power to ensure safe, high-speed recharging. With X-Stream, you’re ready in just 45 minutes. [2]
EcoFlow Image
3 Ways to Charge—Anytime, Anywhere
EcoFlow Image
EcoFlow Image
EcoFlow Image
AC Charging
Car Charging
A New Era of Power Performance
1800W Output, 3600W Surge, 1kWh Capactiy
Next-level energy for next-level peace of mind.
1800W Output, 3600W Surge — Power Essentials Without Compromise
EcoFlow DELTA 3 Classic delivers a steady 1800W pure sine wave output with grid-level stability—built to handle demanding outdoor and professional equipment with confidence. [4] With X-Boost™ mode, it supports devices up to 2400W without tripping or slowing down—giving you seamless power for the moments that matter.
EcoFlow Image
EcoFlow Image
Camping light (10 W)
58 hrs
EcoFlow Image
Electri Grill (1150 W)
0.7 hrs
EcoFlow Image
Electric kettle (1500 W)
0.5 hrs
EcoFlow Image
EcoFlow Image
Camera (16 W)
60 times
EcoFlow Image
Drone (40 Wh)
25 times
EcoFlow Image
Laptop (60 W)
16 times
EcoFlow Image
EcoFlow Image
Electric Drill (1080 W)
0.7 hrs
EcoFlow Image
Circular Saw (1400 W)
0.6 hrs
EcoFlow Image
Cutting Machine (1100 W)
0.7 hrs
Camping
Outdoor Filming
Outdoor Work
EcoFlow Image
Automotive-grade full-tab LFP cells
EcoFlow Image
Automotive-grade Full-Tab LFP Cells: Next-Level Battery Reliability
DELTA 3 Classic is equipped with automotive-grade full-tab LFP cells. The full-tab design reduces resistance, enhances efficiency and safety, and provides higher capacity with less heat, resulting in a long battery lifespan.
25% lower
efficient power flow (thanks to lower resistance: 1.5 mΩ vs. 2 mΩ) [5]
25% less
self-heating [6]
EcoFlow Image
Unrivaled Balance for Unmatched Battery Longevity
With 27% fewer cells per kWh, [7] our 16-cell design runs cooler, lasts longer, and delivers greater stability. Each cell is rigorously tested for capacity, voltage, and internal resistance—resulting in a highly uniform pack that protects against overcharging, imbalance, and premature wear.
16-cell uniform set per 1 kWh
Rigorously tested for capacity, voltage, and internal resistance
Built to Last
From battery chemistry to structural design, DELTA 3 Classic is engineered for extreme durability, environmental resilience, and whisper-quiet performance—delivering power you can count on for over 10 years.
EcoFlow Image
Smart, 24/7 Battery Protection
EcoFlow’s advanced BMS uses a high-performance ARM Cortex chipset and intelligent algorithms to monitor your battery in real time. By tracking SOC, SOH, temperature, and more, it ensures peak performance, extended battery life, and worry-free operation.
EcoFlow Image
EV-Grade CTC Structure
Built with a cell-to-chassis (CTC) structure, DELTA 3 Classic is drop-resistant — protecting against overnight condensation and off-road bumps during transport. You get stable power even in the most demanding conditions.
EcoFlow Image
Extreme Environmental Resistance
DELTA 3 Classic keeps your power flowing through freezing cold, scorching heat, humid environment (95% humidity tolerance), or coastal air (5% salt spray resistance)—for reliable energy anytime, anywhere. [8]
EcoFlow Image
30dB Whisper-Quiet Operation under loads [9]
Powered by X-Quiet™ 3.0, EcoFlow’s stepless fan control adjusts airflow smoothly to maintain precise thermal regulation—keeping your home or workspace peacefully quiet, even under heavy loads.
EcoFlow Image
Monitor your energy usage and solar generation—all with one intuitive dashboard. Set timed charging/discharging missions so that you can charge during off-peak hours, discharge during peak rate periods to save costs.
Output
Output
Solar Generation
Solar Generation
Scheduled Tasks
Scheduled Tasks
Comparison
EcoFlow Image
EcoFlow DELTA 3 Classic Portable Power Station
1024Wh
398mm × 200mm × 283mm
Dimension
12.1kg±0.3kg
Weight
1800W
USB-A: 1 × 18W Max USB-C: 1 × 100W Max, 1 × 30W Max
USB Ports
NO
12V DC Output Port
5
Outlets
1400W
AC Input (Charge Only)
500W
Maximum PV Input Power(W)
YES
Storm Guard Mode
NO
Expandable Battery
EcoFlow Image
1024Wh
Approx. 397.6 × 202 × 283.6mm
Dimension
Approx. 12.5kg
Weight
1800W
USB-A: 2 × 18W Max USB-C: 2 × 100W Max
USB Ports
YES(Car Power Output and DC5521)
12V DC Output Port
13
Outlets
1500W
500W
YES
Storm Guard Mode
YES. 1-5kWh
Expandable Battery
EcoFlow Image
EcoFlow DELTA 3 PLUS Portable Power Station
1024Wh
Dimension
Approx. 12.5kg
Weight
1800W
USB-A: 2 × 36W Max USB-C: 2 × 140W Max
USB Ports
12V DC Output Port
13
Outlets
1500W
1000W
YES
Storm Guard Mode
YES. 1-5kWh
Expandable Battery
