EcoFlow DELTA 2 Max
Fuel Up 80% in Only 43 Mins*
With DELTA 2 Max's upgraded tech, combine up to 1000W solar input with AC for world-leading charging speeds. In only 43 min get an 80% charge. Or stick with AC for an 80% charge in a speedy 53 mins.
Ultra-fast on-the-go charging
Get faster in-vehicle portable power station charging speeds providing a full charge while you're on the road. With built-in safety features, you'll get industry-leading battery care and charging in one.
* Sold separately
120V
Home Backup Solution2400W
Huge AC Output6kWh
Connect up to 2 EcoFlow Smart Extra Batteries
Peaceful Charging
As Quiet as
10-year long-lasting LFP battery
Durable, Safe, Lightweight
LFP Battery Chemistry
Advanced BMS Protection
Robust Design
With LFP cells, DELTA 2 Max is safe, durable, and highly efficient, even in warm temperatures.
A rubber anti-slip base and a fire-resistant casing offer multiple layers of protection.
Upgraded Tech, Lighter Weight
Even with its upgraded LFP battery, DELTA 2 Max is still 30% lighter than similar 2kWh LFP power stations on the market.
*Weight 23kg
Monitor
Real-time energy insights on the go.
View battery status live anytime, anywhere.
Control
Control even from afar.
Easily turn on/off output and the connected appliances remotely.
Constant Updates
Constant updates for optimal user experience.
Regular upgrades to offer you industry-leading energy management.
Customize
Save more on electricity bills.
Optimize your home's energy use and reduce energy bills by smartly leveraging power from the sun, grid, and batteries during peak and off-peak hours.
Stay calm and powered on.
When the power's down, AC Always-On ensures a seamless transition from the grid to backup power and unwavering protection of your fridge and other mission-critical appliances.
Elevated battery lifespan and safety.
By tuning the charging speed to suit various charging environments, it's safe to use, preventing overloading and prolonging its lifespan.
You might also like
View more
