- Overview
- Specs
- Support
The world’s first smart robotic lawn sweeping mower.
Wide Cutting Range
Wire-free Boundaries
Industry's First Robotic Lawn Sweeping Mower
X-Vision Obstacle Avoidance
Anti-theft
Rain Sensor
Comprehensive After-sales Services
The Year-Round Robot.
By THE WALL STREET JOURNAL
Leaf the hard work to us.
BLADE offers the complete lawn treatment, from a quick trim to an entire restyle. Attach the Lawn Sweeper Kit to remove unwanted debris, such as leaves, sticks, and waste, from your yard. You'll have the best-looking lawn in the neighborhood without any of the effort.
Virtually magic.
With our virtual boundary-setting technology, save time and energy without the need to lay pesky wire barriers. Set BLADE's mowing limits using the EcoFlow app within minutes, whether it's to stay within the confines of your yard, avoid specific objects, or even link two lawns. We've even got you covered if you move home or do some landscaping with easy-editable boundaries at the tap of a button.
Quickly Teach BLADE Where to Mow
Use the EcoFlow app to 'draw' a virtually map out your lawn.
Keep on Mowing With X-Vision tech
Smart obstacle avoidance.
BLADE harnesses EcoFlow's newest cutting-edge tech, X-Vision. Combining visual sensors and LiDAR, BLADE intelligently recognizes and avoids obstacles big and small, from your lawn furniture to your neighbor's prize-winning begonias.
Automatic route planning.
With Real-Time Kinematic (RTK) positioning tech, BLADE re-routes around rogue debris within an inch of the original plan, so it never gets stuck or misses a cut.
Cut above the rest.
Industry-first Design for Enhanced Cutting Performance
7.8 in omnidirectional front wheels.
With its wide, sturdy design, BLADE effortlessly traverses rough terrain, maneuvering rocks of up to 1.6 in and ascending 50% slopes.
Wide cutting width.
BLADE's additional width offers a cutting distance of over 10 in, cutting more in less time.
Cuts between 0.8-3.0 in.
To top it off, BLADE has a vast 0.8-3.0 in grass-cutting range, adjustable in seconds using the app.
Take a look at the 360° view of BLADEAnti-theft & Waterproof
Built to last.
Comprehensive Suite of Services
Open this page using Safari on your iPhone or iPad.
Put your lawn to the test.
Since every yard is different, we recommend that you take a quick quiz to ensure that BLADE is suitable for your lawn.
ChecklistEcoFlow BLADE
Power adapter (varies by region)
GNSS Antenna
Quick Start Guide
Other Accessories
Charging Station
EcoFlow GLACIERLearn More
EcoFlow WAVE 2Learn More
